Lpc2000
Missing PWM Match Interrupt
2006-05-31 by stephen_osborn_co
I have been reading the errata and many of the messages on this board
and still cannot find out what is going on.
I have a PWM match interrupt (FIQ) that happens about every 300 system
clock cycles or 5uS. The ISR takes about 2.2uS as indicated by the
GPIO that is high during the ISR. I set a test at the beginning of the
ISR to look at another timer value and if it has be greater than 400
clocks set another GPIO. This indicates that I missed an interrupt.
When I look at the scope I see two different conditions. First, I
usually see a gap in the interrupt indicator just before the missing
interrupt indicator. All interrupts before and after this gap are
properly timed. There are no overlaps of interrupts. There are no
other interrupts firing at this time. If this were a latency issue, I
would expect to see the interrupt enter late and overlap the next
interrupt. Any clues?
The second condition is that the test if(!(PWMIR & 0x01)) indicates
that it entered the interrupt without knowing why, but it does enter
the interrupt with the proper timing, exactly as if it were the PWMIR
interrupt.
The missing interrup causes the PWM to cycle 1 time too many messing
up some critical timing. Any help is appreciated.
