Lpc2000
Handling interrupts on RAM (debug) version
2006-05-26 by stefano_m_a
Hi group,
i'm studying ARM stuff on Olimex LPC-E2294 and, in particular, i'm
testing interrupts.
My problem is the following:
if i compile for RAM_RUN configuration (MEMMAP=2), on interrupt event
the board stucks;
if i compile for ROM_RUN configuration, everything is ok.
This behavoiur is both for timer interrupt and uart interrupt.
Can anyone help me ?
Thanks !!
SM
Re: [lpc2000] Handling interrupts on RAM (debug) version
2006-05-27 by 3gpabko
Ensure that you have copied a correct exeption vectors
table into RAM(0x40000000) at startup.
Zdravko
--- stefano_m_a <stefano_mora@...> wrote:
> Hi group,
> particular, i'm
> testing interrupts.
> on interrupt event
> the board stucks;
> is ok.
> interrupt.
> Thanks !!
> SM
\u0417\u043d\u0430\u043d\u0438\u0435\u0442\u043e \u0435 \u043b\u0438\u0447\u043d\u043e \u043f\u0440\u0435\u0436\u0438\u0432\u044f\u043d\u0430 \u0438\u0441\u0442\u0438\u043d\u0430.
Do You Yahoo!?
http://mail.yahoo.com
Re: Handling interrupts on RAM (debug) version
2006-05-29 by stefano_m_a
MEMMAP=2 is not enought ??
Thanks !
> Regards
> Zdravko
> > Hi group,
> > particular, i'm
> > testing interrupts.
> > on interrupt event
> > the board stucks;
> > is ok.
> > interrupt.
> > Thanks !!
> > SM
> \u0417\u043d\u0430\u043d\u0438\u0435\u0442\u043e \u0435;
> Do You Yahoo!?
Re: [lpc2000] Re: Handling interrupts on RAM (debug) version
2006-05-29 by 3gpabko
When you have set MEMMAP=2 and an exception occurs the
ARM core will fetch from addresses 0x40000000 -
0x4000001C  instead of 0x00000000 - 0x0000001C. That's
why you have to be sure that before this happens you
already have at address 0x40000000 a correct Exception
Vectors Table.
With my tools I am doing this with manually written
code in the startup file(reset handler) and linker
scripts.
Zdravko
> Thanks !
> vectors
> > Regards
> > Zdravko
> > > Hi group,
> in
> > > particular, i'm
> > > testing interrupts.
> (MEMMAP=2),
> > > on interrupt event
> > > the board stucks;
> everything
> > > is ok.
> uart
> > > interrupt.
> > > Thanks !!
> > > SM
> \u0435
> > Do You Yahoo!?
> protection around
Do You Yahoo!?
My code has a classic startup written in assembly code that run the C
main() function.
Into the main() function i have:
#ifdef RAM_RUN
	// Per la compilazione in RAM รจ necessario reimpostare
	// anche la zona degli interrupt (se usati...)
	SCB_MEMMAP = 2;
#endif
	VIC_Init();
	initTimer0(1000); // set up the timer0
	enableIRQ();
	while(1) .....
If i take a look into the main.lss i see:
40000000 <startup>:
.section .startup, "ax"
	.code 32
	.align 0
	b     _start
40000000:	ea000083 	b	40000214 <start>
	ldr   pc, _undf
40000004:	e59ff014 	ldr	pc, [pc, #20]	; 40000020
<_undf>
	ldr   pc, _swi
40000008:	e59ff014 	ldr	pc, [pc, #20]	; 40000024
<_swi>
	ldr   pc, _pabt
4000000c:	e59ff014 	ldr	pc, [pc, #20]	; 40000028
<_pabt>
	ldr   pc, _dabt
40000010:	e59ff014 	ldr	pc, [pc, #20]	; 4000002c
<_dabt>
	nop
40000014:	e1a00000 	nop			(mov r0,r0)
	ldr   pc, [pc,#-0xFF0]
So I think this it is correcty mapped ...
My dubt is: when the interrupt is fired, the flow should go to
0x4000.0018 address to read the IRQ VIC address (0xFFFF.F030)
containing the service routine.
When the vectors are based on 0x0 (Flash) then pc,#-0xFF0 =>
0xFFFF.F030 but when the vectors are based on 0x4000.000 (RAM) the
difference is equal to 0x3FFF.F030 that's incorrect !!
Thanks again !!
> Vectors Table.
> scripts.
> Regards
> Zdravko
> > Thanks !
> code that run the C
> main() function.
> #ifdef RAM_RUN
> 	// Per la compilazione in RAM \ufffd necessario
> reimpostare
> 	SCB_MEMMAP = 2;
> #endif
> 	VIC_Init();
> 	enableIRQ();
> 	while(1) .....
> 40000000 <startup>:
> 	.code 32
> 	.align 0
> 	b     _start
> 	ldr   pc, _undf
> <_undf>
> 	ldr   pc, _swi
> <_swi>
> 	ldr   pc, _pabt
> <_pabt>
> 	ldr   pc, _dabt
> <_dabt>
> 	nop
Yes this seems to be OK.
> should go to
> (0xFFFF.F030)
> pc,#-0xFF0 =>
No. You are making a mistake. The remapping does not
affect the program counter.
In my code I have also:
at IRQ vector location and it works placed in RAM or
FLASH.
So this is not the case.
You are telling that only interrupts are not working
Do You Yahoo!?
OK :)
> FLASH.
OK :)
Yes, both uart interrupts and timer interrupts, so i also think any
interrups will work  :(   (not tested)
Any other ideas ?
I try with GDB, i see a jump to location 0x18 but i can't see any
code; if i step one more time, i jump to location 0x1C (FIQ??)
Thanks again !
SM
2006-05-30 by 3gpabko
> Any other ideas ?
> can't see any
> 0x1C (FIQ??)
If you can verify with the debugger that MEMMAP is
correctly set to 0x02 and that you have the correct
exception vectors table at 0x40000000 pointing
correctly to some exception handlers... there are a
few more ideas:
* Be sure that you are starting your program from
0x40000000;
* Be sure that on your board BOOT[1:0] pins and pin
P0.14 are pulled up on reset;
* Try starting your code from RAM after erasing
completely the FLASH of the device;
Do You Yahoo!?
2006-05-30 by stefano_m_a
When the location 0x18 is called MEMMAP=2 and i see the same vector
table on 0x4000.0000 and 0x0000.0000.
But i don't understand: the correct location for irq handler is
0x0000.0018 or 0x4000.0018 ? (i'm lost in mapping modes....)
> 0x40000000;
On the GDB window i see that starting point is 0x4000.0214 => first
instruction of my startup code (labelled as '_start').
On location 0x4000.0000 i found {0xea000083} value that is
b     _start  (from the main.lss file)
Is it possible to point 0x4000.0000 with the GDB code window to view
disassembled code ?
All the BOOT pins are pulled to +3.3V through jumpers.
But P0.14 is jumped in a voltage partition (22k to +3.3, 1k to
ground, so the value is low) but i need it to work with RAM and ISP
commands ......
Now i'm debugging with a JTAG cable, i think that is regardless from
the P0.14 value ..
Now, i'm trying ....
Thanks again !
SM
I erased the Flash: nothing changed.
Thanks again !
SM
2006-05-30 by rtstofer
> Thanks again !
> SM
In James Lynch's tutorial, this topic is covered beginning around page
109.  Click http://tinyurl.com/camje to download.
While it may not apply to your exact setup, it does explain how to
modify the linker file and the example is known to work.
Richard
Good news !
If i use this code for vectors table it works !
#if ROM_RUN
	ldr   pc, [pc,#-0xFF0]	/* .18 IRQ - read the VIC	*/
#else
	ldr   pc, _irq		/* .18 IRQ - _irq		*/
	//ldr   pc, [pc,#-0xFF0] /* .18 IRQ - read the VIC	*/
#endif
	ldr   pc, _fiq		/* .1c FIQ - _fiq		*/
_undf:  .word __undf     /* undefined		*/
_swi:   .word __undf     /* SWI			*/
_pabt:  .word __pabt     /* program abort	*/
_dabt:  .word __dabt     /* data abort		*/
_fiq:   .word __fiq      /* FIQ			*/
__undf:
	b     .       /* undefined		*/
__pabt:
	b     .       /* program abort		*/
__dabt:
	b     .       /* data abort		*/
__fiq:
	b     .       /* FIQ			*/
_irq:
	b timer0ISR
So the problem seems to be into:
If i break the code when pc==0x18 and i inspect register 0xffff.f030
i found the address of my routine timer0ISR() !!!
SM
2006-05-31 by stefano_m_a
It's incredible, i found an error on the code i wrote (and i posted)
and the code should be not running, but i saw it running !!
> _irq:
> 	b timer0ISR
_irq label should define an address and not an instruction ...
I corrected the code as following:
_irq:
	.word __irq
__irq:
	b timer0ISR
But now the running is bad.....
When the IRQ is fired the PC is pointing 0x18 or 0x4000.0018 ?????
Regards !
SM
2006-05-31 by Karl Olsen
> posted) and the code should be not running, but i saw it running !!
> > _irq:
> > 	b timer0ISR
> _irq:
> 	.word __irq
Or just:
_irq:
  .word timer0ISR
> __irq:
> 	b timer0ISR
0x18.  The ARM7 always reads the vectors at address 0x00-0x1C.  The
Philips MEMMAP feature makes the first 64 bytes of RAM readable at
both address 0x00 and 0x4000.0000.
Karl Olsen
> Or just:
> _irq:
>   .word timer0ISR
> > __irq:
> > 	b timer0ISR
I must use your solution cause:
- PC is pointing low addresses
- timer0ISR function is located on RAM range
- b instruction is able to jump over 24 bit offsets.
Is it right ?
SM
wrote:
> > Or just:
> > _irq:
> >   .word timer0ISR
> > > __irq:
> > > 	b timer0ISR
> Is it right ?
Yes.  You could also just have a LDR pc, [pc, #-0x0FF0] at address
0x18, and have the timer0ISR address loaded into the right
VICVectAddrxx register.  This also works with the handler at any
address.
Karl Olsen
> address.
> Karl Olsen
OK, thanks Karl.
Yes, usually the code uses 'LDR pc, [pc, #-0x0FF0]' but now i'm
investigating why my code does not work. This is driving me crazy ...
I see the call on 0x18 but i can't see the code with GDB (it thinks
this location is outside my program....), if i step again i fall into
0x1c (but FIQs are disabled ..), my irq_isr code is not called, into ..
I'm loosing a lot af time on interrupts and i'm not able to solve... :(
SM
