Activating Boot Loader for LPC2000 Flash Untility
2004-07-07 by Owen Mooney
I am building a product that will be encapulated in a blob of epoxy. I live in the real world so I know that with any new product firmware upgrades are almost inevitable. These can be loaded into a LPC2106 PROVIDED that the P0.14 can be accessed Tricky from inside the blob. Is it possible to to activate the code that does the boot loading from within my old program, ie jump to some location like we do for IAP programming Thanks Owen Mooney
2004-07-07 by Robert Adsett
>blob.
Well you are bringing out the serial lines already so that would be just
one extra pin on your connector. However, I presume there are reasons you
are reluctant to do that.
>programming
There was an earlier thread (loading hex-es) where we speculated about
simply clearing the first area of flash and then resetting to induce the
LPC to enter program mode as if it were a new (or misprogrammed)
part. Since no one has done this yet AFAIK you should test this before
committing to using it with encapsulated boards. It does look like a
reasonable idea though.
Robert
" 'Freedom' has no meaning of itself. There are always restrictions,
be they legal, genetic, or physical. If you don't believe me, try to
chew a radio signal. "
Kelvin Throop, III2004-07-07 by lpc2100
Owen Try this sequence from your program which needs to be updated. Make bootloader vectors visible Write 0x0 to the MEMMAP (0xE01FC040) Select P0.14 as output. You may want to do a read-modify-write here. Write 0x4000 to the IODIR (0xE0028008) Make P0.14 Low Write 0x4000 to the IOCLR (0xE002800C) Branch to address 0x0 in ARM mode. This should invoke the bootloader in ISP mode. Update the code via serial ISP and the next reset should execute the new code. Hope this works for you. Tom --- In lpc2000@yahoogroups.com, Owen Mooney <ojm@s...> wrote: > I am building a product that will be encapulated in a blob of epoxy. > > I live in the real world so I know that with any new product firmware > upgrades are almost inevitable. These can be loaded into > a LPC2106 PROVIDED that the P0.14 can be accessed Tricky from inside the > blob. > > Is it possible to to activate the code that does the boot loading from
> within my old program, ie jump to some location like we do for IAP > programming > > Thanks > > Owen Mooney
2004-07-07 by Richard
Hmmm, Branching to 0x00 is not the same as a reset, IOW you will not end up in the bootloader that samples P0.14 and enters ISP mode etc. Rich --- In lpc2000@yahoogroups.com, "lpc2100" <lpc2100@y...> wrote: > Owen > > Try this sequence from your program which needs to be updated. > > Make bootloader vectors visible > Write 0x0 to the MEMMAP (0xE01FC040) > > Select P0.14 as output. You may want to do a read-modify-write here. > Write 0x4000 to the IODIR (0xE0028008) > > Make P0.14 Low > Write 0x4000 to the IOCLR (0xE002800C) > > Branch to address 0x0 in ARM mode. > > This should invoke the bootloader in ISP mode. Update the code via > serial ISP and the next reset should execute the new code. > > Hope this works for you. > > Tom > > > --- In lpc2000@yahoogroups.com, Owen Mooney <ojm@s...> wrote: > > I am building a product that will be encapulated in a blob of epoxy. > > > > I live in the real world so I know that with any new product > firmware > > upgrades are almost inevitable. These can be loaded into > > a LPC2106 PROVIDED that the P0.14 can be accessed Tricky from > inside the > > blob. > > > > Is it possible to to activate the code that does the boot loading > from > > within my old program, ie jump to some location like we do for IAP
> > programming > > > > Thanks > > > > Owen Mooney
2004-07-08 by Leighton Rowe
How about implementing the watchdog? That's closest thing to a hardware reset (without pressing the switch). You might run into a few issues using the watchdog timer, especially if it's an lpc2114 or lower...I'm not sure which lpc has the improved version of watchdog timer though. --- Richard <richas@...> wrote: > Hmmm, > Branching to 0x00 is not the same as a reset, IOW > you will not end > up in the bootloader that samples P0.14 and enters > ISP mode etc. > > Rich > > --- In lpc2000@yahoogroups.com, "lpc2100" > <lpc2100@y...> wrote: > > Owen > > > > Try this sequence from your program which needs to > be updated. > > > > Make bootloader vectors visible > > Write 0x0 to the MEMMAP (0xE01FC040) > > > > Select P0.14 as output. You may want to do a > read-modify-write here. > > Write 0x4000 to the IODIR (0xE0028008) > > > > Make P0.14 Low > > Write 0x4000 to the IOCLR (0xE002800C) > > > > Branch to address 0x0 in ARM mode. > > > > This should invoke the bootloader in ISP mode. > Update the code via > > serial ISP and the next reset should execute the > new code. > > > > Hope this works for you. > > > > Tom > > > > > > --- In lpc2000@yahoogroups.com, Owen Mooney > <ojm@s...> wrote: > > > I am building a product that will be encapulated > in a blob of > epoxy. > > > > > > I live in the real world so I know that with any > new product > > firmware > > > upgrades are almost inevitable. These can be > loaded into > > > a LPC2106 PROVIDED that the P0.14 can be > accessed Tricky from > > inside the > > > blob. > > > > > > Is it possible to to activate the code that does > the boot loading > > from > > > within my old program, ie jump to some location > like we do for > IAP > > > programming > > > > > > Thanks > > > > > > Owen Mooney > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
2004-07-08 by lpc2100
The idea here is to fool the bootloader when it samples P0.14. If serial port 0 is used in the application then it also needs to clear the bit 2-3 of PINSEL0 and bits 1 of the IODIR register. I have verified the concept on the Ashling board running ledtest image. --- In lpc2000@yahoogroups.com, "Richard" <richas@y...> wrote: > Hmmm, > Branching to 0x00 is not the same as a reset, IOW you will not end > up in the bootloader that samples P0.14 and enters ISP mode etc. > > Rich > > --- In lpc2000@yahoogroups.com, "lpc2100" <lpc2100@y...> wrote: > > Owen > > > > Try this sequence from your program which needs to be updated. > > > > Make bootloader vectors visible > > Write 0x0 to the MEMMAP (0xE01FC040) > > > > Select P0.14 as output. You may want to do a read-modify-write here. > > Write 0x4000 to the IODIR (0xE0028008) > > > > Make P0.14 Low > > Write 0x4000 to the IOCLR (0xE002800C) > > > > Branch to address 0x0 in ARM mode. > > > > This should invoke the bootloader in ISP mode. Update the code via > > serial ISP and the next reset should execute the new code. > > > > Hope this works for you. > > > > Tom > > > > > > --- In lpc2000@yahoogroups.com, Owen Mooney <ojm@s...> wrote: > > > I am building a product that will be encapulated in a blob of > epoxy. > > > > > > I live in the real world so I know that with any new product > > firmware > > > upgrades are almost inevitable. These can be loaded into > > > a LPC2106 PROVIDED that the P0.14 can be accessed Tricky from > > inside the > > > blob. > > > > > > Is it possible to to activate the code that does the boot loading
> > from > > > within my old program, ie jump to some location like we do for > IAP > > > programming > > > > > > Thanks > > > > > > Owen Mooney
The watchdog reset won't work because the bootloader skips P0.14 sampling when WDTOF bit is set as indicated in the bootloader flowchart. --- In lpc2000@yahoogroups.com, Leighton Rowe <leightonsrowe@y...> wrote:
> How about implementing the watchdog? That's closest > thing to a hardware reset (without pressing the > switch). > > You might run into a few issues using the watchdog > timer, especially if it's an lpc2114 or lower...I'm > not sure which lpc has the improved version of > watchdog timer though. > > --- Richard <richas@y...> wrote: > > Hmmm, > > Branching to 0x00 is not the same as a reset, IOW > > you will not end > > up in the bootloader that samples P0.14 and enters > > ISP mode etc. > > > > Rich > > > > --- In lpc2000@yahoogroups.com, "lpc2100" > > <lpc2100@y...> wrote: > > > Owen > > > > > > Try this sequence from your program which needs to > > be updated. > > > > > > Make bootloader vectors visible > > > Write 0x0 to the MEMMAP (0xE01FC040) > > > > > > Select P0.14 as output. You may want to do a > > read-modify-write here. > > > Write 0x4000 to the IODIR (0xE0028008) > > > > > > Make P0.14 Low > > > Write 0x4000 to the IOCLR (0xE002800C) > > > > > > Branch to address 0x0 in ARM mode. > > > > > > This should invoke the bootloader in ISP mode. > > Update the code via > > > serial ISP and the next reset should execute the > > new code. > > > > > > Hope this works for you. > > > > > > Tom > > > > > > > > > --- In lpc2000@yahoogroups.com, Owen Mooney > > <ojm@s...> wrote: > > > > I am building a product that will be encapulated > > in a blob of > > epoxy. > > > > > > > > I live in the real world so I know that with any > > new product > > > firmware > > > > upgrades are almost inevitable. These can be > > loaded into > > > > a LPC2106 PROVIDED that the P0.14 can be > > accessed Tricky from > > > inside the > > > > blob. > > > > > > > > Is it possible to to activate the code that does > > the boot loading > > > from > > > > within my old program, ie jump to some location > > like we do for > > IAP > > > > programming > > > > > > > > Thanks > > > > > > > > Owen Mooney > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com
2004-07-08 by Shannon Holland
On Jul 7, 2004, at 7:37 PM, lpc2100 wrote: > The idea here is to fool the bootloader when it samples P0.14. If > serial port 0 is used in the application then it also needs to clear > the bit 2-3 of PINSEL0 and bits 1 of the IODIR register. > > I have verified the concept on the Ashling board running ledtest > image. > Did you remap memory to put the bootloader back at address 0, or something else? Only thing I would be concerned about is if Philips changed the bootloader so that it reset the iodir on P0.14. It would be nice if Philips provided a reliable (as in supported) mechanism to get back into the bootloader from user code. Shannon
2004-07-08 by Robert Adsett
Sorry, I've lost track somewhere here. What, exactly, did you verify?
Robert
Kelvin Throop, III2004-07-08 by Robert Adsett
Not to pick on you in particular, but this seems an awful lot of angst over
bringing out one more connection. If you are going to allow ISP after
potting you have bring out a minimum of 3 signals anyway (TxD, RxD and
Gnd), 5 if you provide power and control the reset. Adding 1 to control
P0.14 really doesn't seem like a big deal. Actually the only element that
comes to mind is if you are reusing a connector with predefined meanings
and can't reuse an existing pin definition for programming.
In addition, it is possible to get into a situation where the part is
partially programmed and therefore won't enter ISP mode automatically but
there isn't a valid user program to force a shift to ISP mode. If P0.14 is
not brought out in some fashion then any boards that get stuck here will
have to be tossed.
I think if you need to be able to program parts reliably w/o using P0.14
you will need to devote the first sector to a code that is never erased and
provides a way to program the remaining 14 sectors with the application
code. The first sector might also provide other support code (maybe
diagnostics, a way to initialize the hardware to a good, safe start
condition etc...
Robert
Kelvin Throop, III2004-07-08 by Shannon Holland
On Wednesday, July 7, 2004, at 08:30 PM, Robert Adsett wrote: > At 07:47 PM 7/7/04 -0700, you wrote: >> It would be nice if Philips provided a reliable (as in supported) >> mechanism to get back into the bootloader from user code. > > Not to pick on you in particular, but this seems an awful lot of angst > over > bringing out one more connection. If you are going to allow ISP after > potting you have bring out a minimum of 3 signals anyway (TxD, RxD and > Gnd), 5 if you provide power and control the reset. Adding 1 to > control > P0.14 really doesn't seem like a big deal. Actually the only element > that > comes to mind is if you are reusing a connector with predefined > meanings > and can't reuse an existing pin definition for programming. > > In addition, it is possible to get into a situation where the part is > partially programmed and therefore won't enter ISP mode automatically > but > there isn't a valid user program to force a shift to ISP mode. If > P0.14 is > not brought out in some fashion then any boards that get stuck here > will > have to be tossed. > > I think if you need to be able to program parts reliably w/o using > P0.14 > you will need to devote the first sector to a code that is never > erased and > provides a way to program the remaining 14 sectors with the application > code. The first sector might also provide other support code (maybe > diagnostics, a way to initialize the hardware to a good, safe start > condition etc... > > I would agree! I have no angst on this issue, it just seemed like it might be a useful thing which wouldn't be that hard to do from the bootloader side. In my particular case I have a separate chip driving the programming - I'm using a TUSB3410 to provide a usb->uart interface and then driving P0.14 and RST with two of it's GPIO's. So far it works well. The LPC210x parts are pretty tight on GPIO, in that sense a non-external bootloader entry would be nice (except that you would still have to guarantee logic high on reset), but as you point out it would only work if you can get to it reliably (or are willing to accept some amount of un-reliablity). If you did devote the first sector towards an additional bootloader you could just have it do diags and then call the philips bootloader for programming. Still seems like a lot of work. Shannon
2004-07-08 by Richard
Here's a thought, how about reading sector zero into RAM and erasing the location corresponding to location 0x14 in flash (valid code ID). Then erase sector zero and write back the modified version from RAM. That way you have cleared the valid code ID and the next reset will result in entry into ISP mode. Rich --- In lpc2000@yahoogroups.com, Shannon Holland <holland@l...> wrote: > > On Wednesday, July 7, 2004, at 08:30 PM, Robert Adsett wrote: > > > At 07:47 PM 7/7/04 -0700, you wrote: > >> It would be nice if Philips provided a reliable (as in supported) > >> mechanism to get back into the bootloader from user code. > > > > Not to pick on you in particular, but this seems an awful lot of angst > > over > > bringing out one more connection. If you are going to allow ISP after > > potting you have bring out a minimum of 3 signals anyway (TxD, RxD and > > Gnd), 5 if you provide power and control the reset. Adding 1 to > > control > > P0.14 really doesn't seem like a big deal. Actually the only element > > that > > comes to mind is if you are reusing a connector with predefined > > meanings > > and can't reuse an existing pin definition for programming. > > > > In addition, it is possible to get into a situation where the part is > > partially programmed and therefore won't enter ISP mode automatically > > but > > there isn't a valid user program to force a shift to ISP mode. If > > P0.14 is > > not brought out in some fashion then any boards that get stuck here > > will > > have to be tossed. > > > > I think if you need to be able to program parts reliably w/o using > > P0.14 > > you will need to devote the first sector to a code that is never > > erased and > > provides a way to program the remaining 14 sectors with the application > > code. The first sector might also provide other support code (maybe > > diagnostics, a way to initialize the hardware to a good, safe start > > condition etc... > > > > > > I would agree! I have no angst on this issue, it just seemed like it > might be a useful thing which wouldn't be that hard to do from the > bootloader side. In my particular case I have a separate chip driving > the programming - I'm using a TUSB3410 to provide a usb->uart interface > and then driving P0.14 and RST with two of it's GPIO's. So far it works > well. > > The LPC210x parts are pretty tight on GPIO, in that sense a > non-external bootloader entry would be nice (except that you would > still have to guarantee logic high on reset), but as you point out it > would only work if you can get to it reliably (or are willing to accept > some amount of un-reliablity). If you did devote the first sector > towards an additional bootloader you could just have it do diags and > then call the philips bootloader for programming. Still seems like a
> lot of work. > > Shannon
verify?
Re-entry in to bootloader ISP without touching the P0.14 pin when the
device already had a valid user code.
re_enter_bootloader_isp
volatile unsigned long * memmap;
volatile unsigned long * ioclr;
volatile unsigned long * iodir;
volatile unsigned long * pinsel0;
void (*bootloader_entry)(void);
unsigned long temp;
memmap = (volatile unsigned long *)0xE01FC040;
ioclr = (volatile unsigned long *)0xE002800C;
iodir = (volatile unsigned long *)0xE0028008;
pinsel0 = (volatile unsigned long *)0xE002C000;
*memmap = 0x0;
temp = *pinsel0;
*pinsel0 = temp & 0xFFFFFFF3;
temp = *iodir;
temp = temp | 0x4000;
temp = temp & 0xFFFFFFFD;
*iodir = temp;
*ioclr = 0x4000;
bootloader_entry = (void (*)(void))(0x0);
bootloader_entry();
}2004-07-08 by Robert Adsett
>verify?
<snip>
OK, that's clearer. Neat parlour trick. I don't know whether to be amused
or distressed that it works. It does open up a whole new class of symptoms
for null function pointer bugs :)
I don't think that's any more effective than simply erasing the first
sector, although it does give it a longer period to run between being made
invalid and actually requiring a reload. It doesn't get rid of the basic
vulnerability of trying to set up ISP w/o access to P0.14 though. If you
only get partway through reloading the flash (say you erase the device and
program the first two sectors) you end up with a device with an invalid
program that 'thinks' it has a valid program. You can't force it into ISP
mode in hardware and there isn't enough program left to shift it into ISP
mode in software.
Just to contribute my own angst to the subject. If you really are in a
situation where you can't afford the extra pin then something like the
following might work.
Add a small cheap micro to snoop on the incoming (RxD) serial line of the
LPC. When it detects some unique sequence that is not valid for the
program in the LPC it asserts the reset line and pulls P0.14 low. It can
then deassert the reset line and voila you are in ISP mode. On reset (or
another unique sequence) it simply lets the reset and P0.14 lines float
free again.
That doesn't require any more care on P0.14 than it already requires and
the micro needed should be relatively inexpensive. Still seems like a lot
of work to avoid a pin though.
Robert
Kelvin Throop, III2004-07-08 by Alex Holden
Robert Adsett wrote: > I don't think that's any more effective than simply erasing the first > sector, although it does give it a longer period to run between being made > invalid and actually requiring a reload. It doesn't get rid of the basic > vulnerability of trying to set up ISP w/o access to P0.14 though. If you > only get partway through reloading the flash (say you erase the device and > program the first two sectors) you end up with a device with an invalid > program that 'thinks' it has a valid program. You can't force it into ISP > mode in hardware and there isn't enough program left to shift it into ISP > mode in software. You could reduce the failure window by doing a checksum of the entire flash at the beginning of the init code in the first sector, and erasing the first sector again if it fails (of course you'd have to add a checksum word to the end of your flash image for this to work). > Add a small cheap micro to snoop on the incoming (RxD) serial line of the > LPC. When it detects some unique sequence that is not valid for the > program in the LPC it asserts the reset line and pulls P0.14 low. It can > then deassert the reset line and voila you are in ISP mode. On reset (or > another unique sequence) it simply lets the reset and P0.14 lines float > free again. Good idea, especially if the simple uC can perform some other useful task as well. My current LPC2100 design has a couple of PIC12C508s in it performing various simple tasks with fairly tight timing requirements that in the past might have used a bunch of R/C timers and TTL logic chips. They interface to the the LPC with a home-brewed 1 wire communication protocol. -- ------------ Alex Holden - http://www.linuxhacker.org ------------ If it doesn't work, you're not hitting it with a big enough hammer
> > free again.
>task as well.
The one that occurred to me is, since it's already hooked up to the the
reset line, it could make a pretty sophisticated application specific
watchdog timer.
Robert
Kelvin Throop, III2004-07-08 by mjbcswitzerland
You're getting me worried.. I also have to support ISP without P0.14 - absolutely no choice and not an issue of saving a pin - it is the fact that the chip is in a sealed and protected casing containing a high security key (which gets wiped out if the case is opened, drilled into, sujected to to high/low temperatures etc. It is too dangerous to allow the ISP line to be accessible from outside otherwise some smart-alec will use it to load a program to simply read and send out the secret key. First I was monitoring the Rx line using a PIC but it got too messy and space requirements made me remove it and connect the ISP line to VDD - the solution being to request the processor to go to download mode before which it also destroys the key information and then deletes the first sector. Turning one and off power then automatically enters the ISP mode and new code can be loaded (of course a new key will also have to be loaded afterwards, but that is what we want - only when the key has been loaded is the issue safely sensitive again..) I thought that the check sum over the interrupt vectors was calculated and written automatically by the device at the end of an ISP download. Is there evidence that this technique can fail if the ISP download is aborted before it has completed? (valid interrupt vector check sum without any code). Perhaps we should experiment a little to avoid getting caught out. Any expert out there who know the exact answer???? Cherrs Mark Butcher www.mjbc.ch Replying to the comment... > >Here's a thought, how about reading sector zero into RAM and erasing > >the location corresponding to location 0x14 in flash (valid code > >ID). Then erase sector zero and write back the modified version from > >RAM. That way you have cleared the valid code ID and the next reset > >will result in entry into ISP mode. > > I don't think that's any more effective than simply erasing the first > sector, although it does give it a longer period to run between being made > invalid and actually requiring a reload. It doesn't get rid of the basic > vulnerability of trying to set up ISP w/o access to P0.14 though. If you > only get partway through reloading the flash (say you erase the device and > program the first two sectors) you end up with a device with an invalid > program that 'thinks' it has a valid program. You can't force it into ISP > mode in hardware and there isn't enough program left to shift it into ISP > mode in software. >
mjbcswitzerland wrote: > I thought that the check sum over the interrupt vectors was > calculated and written automatically by the device at the end of an > ISP download. No, the ISP uploader program calculates the checksum before uploading the code to the device. Another way of reducing the risk of a partial upload with a valid vector checksum might be to use a modified version of lpc21isp that uploads the first sector last. -- ------------ Alex Holden - http://www.linuxhacker.org ------------ If it doesn't work, you're not hitting it with a big enough hammer
Now there is a reason not to bring a pin out.
I've already experienced it (not deliberately). An interrupted download
must be re-programed by pulling P0.14 low, otherwise the LPC attempts to
run whatever portion of the application is already programmed in the
chip. I've only noted this because the Philips download program can't
communicate with the chip to perform a download unless P0.14 is pulled low
and the chip is reset.
The checksum is definitely calculated by the download software not the
LPC. The ISP support on the LPC simply writes arbitrary blocks at given
locations, it has no concept of a process with a beginning and an end. The
order of writes depends on the download software. From what I remember of
reviewing the lpc2isp software it calculates the checksum at the beginning
(seems straight forward enough) and then simply programs the sectors in
sequence.
From the visible behaviour it looks like Philips program does the same but
I'd have to snoop the serial line to be sure. You could write a custom
program that programmed the first sector last. That would reduce the
window, especially if the block containing the checksum was the last to be
written. I'm not sure even that absolutely eliminates the possibility of
ending up with a problem but the probability becomes quite small.
Robert
Kelvin Throop, III2004-07-09 by Owen Mooney
Thanks for the various replys on this and I will try them. It may seem like angst over an external pin, BUT I have made one product (with motorola chip) which used an external pin to force it into boot loader mode. I had one customer who kept sending units back for repair as someone in his organisation had a misswired serial lead!!!!! His fault, BUT who gets the blame for an unreliable product. I never had that problems with another product with software activated flashing code. Thanks Owen
2004-07-09 by Robert Adsett
You mean that the unit was actually erased or programmed? All the serial
downloads I've seen require a reasonably lengthy sequence before you could
do either. It's rather hard to envision getting that far simply because of
a cable problem.
If it was simply a matter of not communicating, then I have run into that
as an enduser. But it doesn't take the addition of a programming line to
cause that. Serial breakout boxes exist for a reason you know :)
Of course all the pins have predefined and used functionality for a serial
9-pin d-sub which makes an off the shelf cable more of a potential problem,
but the 25 pin has a number of pins that are not usually used (or you could
us some other connector entirely).
Well if simply hooking up the pin caused the unit to cease functioning
until re-programmed I'd have concerns about it's functioning in the real
world. But if just means they don't operate until the cable is
corrected? A lot of equipment won't operate correctly with a bad cable.
>flashing code.
The biggest problems I've seen or had to worry about with software
activated code occur when the activation code is part of the downloaded
image and then you have to worry about
- what happens when the download is interrupted before completion
- what happens if there is a bug in the new image that doesn't allow
another download to occur. Hopefully through test and review makes this
possibility unlikely but I seem to remember stories of products this has
occured to (I seem to remember compuserve or AOL having a problem like this
many moons ago)
Robert
Kelvin Throop, III
