Lpc2000
Questions about librarys
2004-11-05 by ricardooliveirasouza
I'm a beginner in LPC2000 and I'm developing a program for lpc2210. I
have
these questions:
1) Is newlib the best library option for memory allocation usage?
2) Does anyone have expecience with uclibc or diet libc? what's the
best?
3) Does memory allocation with newlib need sbrk implementation with
compiler arm-elf-gcc? Does anybody have any examples? Is there any
fragmentation problem?
4) How can I determine my program stack size? I tried avrora and
stacktool, but both are for atmel.
Re: [lpc2000] Questions about librarys
2004-11-05 by Robert Adsett
>have
>these questions:
Define best.  It depends on what you are doing.  I believe it is a general
purpose allocator and so subject to all the usual concerns.  Personally for
an embedded system I wouldn't use mallac and company except at startup to
provide memory blocks.  On going uses would either use fixed preallocated
blocks or allocate out of a pool to avoid fragmentation issues.
>best?
No experience with either, make sure the license is compatible with your use.
>the
It does need an sbrk implementation (newlib-lpc provides one), but they are
not difficult.
Count :)
Actually, I'm at least half serious about that.  If you are not doing
recursive calls it's relatively straightforward, if a little tedious, to
simple count up the stack usage.
The other obvious approach is to mark the stack and see how far down it
descends by looking for the stack end while running,  Not as foolproof
against rarely executed paths but more robust against arithmetic errors.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Re: [lpc2000] Interrupt Handline
2004-11-07 by microbit
Hi Robert,
I went through the same "wondering".
I noticed that the VICVectAddr gets reset after the vector to weak
irq_handler. I just copped out and replaced
>   ldr pc, [pc, #irq_handler_address - . - 8]
with the classic :
ldr    pc, [pc , # -0xFF0]
That sets up VIC to directly vector to your IRQ handler address programnmed
in.
PS : Don;t forget to update your bootloader checksum in vector table when
you change it !
-- Kris
To: <lpc2000@yahoogroups.com>
Sent: Sunday, November 07, 2004 11:17 PM
Subject: [lpc2000] Interrupt Handline
> Hi folks,
> I'm struggling to understand how to handle interrupts for the 2294. I can
see
> that when I get an interrupt, the processor jumps off to the following
line
> of code in the startup assembly file:
> This then jumps off to the following line of code:
> irq_handler:
>   b irq_handler
> There is a comment that these are defined as weak variables and can be
> redefined in user code. So, at the moment, it's quite easy to see that
when
> there's an interrupt the program just gets stuck on this line of code. It
> seems obvious that I then have to redirect this code to the appropriate
> interrupt handler. I would have thought that I need to read the
VICVectAddr
> which should contain the address of one of the registers VICVectAddr0 to
> VICVectAddr15. I assume that the program would jump to that VICVectAddrX
> register and then from there to the user code which has been written to
deal
> with the interrupt.
> What I'm not clear about is how to replace this line of code:
> irq_handler:
>   b irq_handler
> To something like:
> irq_handler:
>   b (VICVectAddr)
> In other words, when I get to the line of code
> irq_handler:
> Then jump to the location pointed to be the contents of VICVectAddr. I
assume
> that if I can set that up, the compiler will sorted out jumping to
wherever
> VICVectAddrX points to.
> Am I basically correct in my assumptions, or way off line?!
> Many thanks,
> Rob
>       Yahoo! Groups Sponsor
>             ADVERTISEMENT
>   a.. To visit your group on the web, go to:
>   http://groups.yahoo.com/group/lpc2000/
>   b.. To unsubscribe from this group, send an email to:
>   lpc2000-unsubscribe@yahoogroups.com
>   c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Interrupt Handline
2004-11-07 by Robert Wood
Hi folks,
I'm struggling to understand how to handle interrupts for the 2294. I can see
that when I get an interrupt, the processor jumps off to the following line
irq_handler:
  b irq_handler
redefined in user code. So, at the moment, it's quite easy to see that when
interrupt handler. I would have thought that I need to read the  VICVectAddr
register and then from there to the user code which has been written to deal
with the interrupt.
irq_handler:
  b irq_handler
To something like:
irq_handler:
  b (VICVectAddr)
irq_handler:
Then jump to the location pointed to be the contents of VICVectAddr. I assume
that if I can set that up, the compiler will sorted out jumping to wherever
Many thanks,
Rob
Re: [lpc2000] Interrupt Handling
What toolchain are you using ?
Depending on toolchain, I could send you the modfied startup file directly..
Sent: Sunday, November 07, 2004 11:42 PM
Subject: Re: [lpc2000] Interrupt Handling
> Thanks, Kris.
when
> you change it ! <<
> Erm, I'm embarrassed to say I don't know how to work out what to change it
to!
>             ADVERTISEMENT
Thanks, Kris.
you change it ! <<
Erm, I'm embarrassed to say I don't know how to work out what to change it to!
Apart from the VIC handler, you shouldn't have a pressing need to
change the vector table, they're all weak symbols, so you just need to
define
a handler with the same name to override, doesn't affect your table.
Eg : An swi_handler :
# ifdef    EXCEPTIONS
void swi_handler (void )
// do your own thing
#endif
the address of your swi_handler function will override
in the linker, so you don't need to change the vector table for that.
-- Kris
Sent: Sunday, November 07, 2004 11:51 PM
> >> What toolchain are you using ? <<
> Crossworks.
> directly.. <<
> The datasheet says:
> "The reserved ARM interrupt vector location (0x0000 0014) should contain
the 2
> s complement of the check-sum of the remaining interrupt vectors. This
causes
> the checksum of all of the vectors together to be 0."
> So, I'm thinking it shouldn't be that difficult to actually work out, but
I'm
> don't understand whether it's just talking about the first few memory
> locations, all the interrupt vectors, both, or something else again.
> I should work out how to calculate it really, as there's every chance I'll
> want to mod it again!
>             ADVERTISEMENT
Crossworks.
directly.. <<
The datasheet says:
"The reserved ARM interrupt vector location (0x0000 0014) should contain the 2
s complement of the check-sum of the remaining interrupt vectors. This causes
So, I'm thinking it shouldn't be that difficult to actually work out, but I'm
2004-11-07 by Robert Adsett
>Crossworks.
>directly.. <<
>The datasheet says:
>the 2
That really shouldn't be necessary, the download tool should take care of
that.  I've never modified it directly myself.
Robert
                         Kelvin Throop, III
Re: Interrupt Handline
2004-11-08 by Randy Ott
--- In lpc2000@yahoogroups.com, "microbit" <microbit@c...> wrote:
> Hi Robert,
> with the classic :
programnmed
> in.
table when
> you change it !
> -- Kris
Here's the way I do it:
// IRQ exception handler. Calls the interrupt handlers.
__irq __arm void irq_handler(void)
	void (*interrupt_function)();
	unsigned int vector;
	vector = VICVectAddr;	 // Get interrupt vector.
	interrupt_function = (void(*)())vector;
	(*interrupt_function)(); // Call vectored interrupt function.
	VICVectAddr = 0;	 // Clear interrupt in VIC.
That way you can write the individual ISRs in thumb mode.  The IRQ
handler must be written in ARM mode because the processor is in that
mode when an exception occurs.  During linking the weak link to
irq_handler (or whatever it is called) gets replaced with the C
function.
Randy Ott
Re: [lpc2000] Re: Interrupt Handline
2004-11-08 by microbit
Hi Randy,
Thanks, I must have overlooked something, because I was in the belief that
the VICVectAddr was "lost" once in the "irq_handler", thought could only
handle
it in ASM - must have gotten confused somewhere.
B rgds
Kris
> function.
> Randy Ott
2004-11-09 by Randy Ott
It also keeps you from fiddling with the startup code when you want
to write apps with or without IRQ.
I should also mention that if you are using GCC you will need to use
something like "__attribute__((interrupt)(IRQ))" instead of
the "__irq" and "__arm" modifiers.
Randy
> Hi Randy,
belief that
could only
> handle
> B rgds
> Kris
function.
IRQ
that
> > function.
> > Randy Ott
Re: Interrupt Handling (Vector checksum)
2004-11-18 by tom_laffey
Hi Robert,
Did you ever solve the vector table checksum problem?  Like you, I've
tried the algorithm described in the manual (the one you typed below)
and the boot code won't start when the file is loaded with IAP.  From
the description, the checksum covers the first 8 words.
My application uses IAP for firmware updates, so long-term dependency
on the Philips downloader is not an option.
Tom
> Crossworks.
file
> directly.. <<
> The datasheet says:
contain the 2
This causes
out, but I'm
memory
again.
chance I'll
Re: [lpc2000] Re: Interrupt Handling (Vector checksum)
2004-11-18 by Robert Adsett
Take a look at the source for Martin's LPC21ISP.  It does the calculation
and it should be simple to adapt.
Robert
                         Kelvin Throop, III
Hi Robert,
Thanks for your reply.  I found Martin's checksum code, which is
        ivt_CRC = 0;
        for(i = 0;i < 8; i++)
            if(i == 5) continue;            // Jump over address 0x14
            ivt_CRC += BinaryContent_as_unsigned_long[i];
        ivt_CRC = 0 - ivt_CRC;              // Negate result
        BinaryContent_as_unsigned_long[5] = ivt_CRC;
The code I am using is in a program to add this checksum to a
binary program file before downloading:
	// pBuf is char *, aligned 4
	unsigned long * pVectors = (unsigned long *) pBuf;
        pVectors[5] = 0;
        for( checksum = index = 0; index < 8; index++)
            checksum += pVectors[index];
        pVectors[5] = ~checksum + 1;
which looks like it does the same thing as Martin's.
This has me wondering what I am missing.  When I modify the binary
image and load it with my ISP program, it is not recognized by the
Philips boot loader.  I can tell by stopping the CPU and looking at
the PC: pc=0x7fffef32.  Downloading the same image using the Philips
downloader (and a hex version of the executable), the program boots.
Tom
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@a...>
I've
below)
From
dependency
calculation
> Robert
restrictions,
to
>                          Kelvin Throop, III
2004-11-18 by capiman@t-online.de
Have you compared what value you get with your routine and perhaps load the
same with my routine ?
Is it really the same ? I see you are doing a +1 at the end ?
        Martin
Sent: Thursday, November 18, 2004 8:40 PM
Subject: [lpc2000] Re: Interrupt Handling (Vector checksum)
> Hi Robert,
>        ivt_CRC = 0;
>        pVectors[5] = 0;
> Thanks,
> Tom
> I've
> below)
> From
> dependency
> calculation
>> Robert
> restrictions,
> to
>>                          Kelvin Throop, III
Endian-Problem ?
Sent: Thursday, November 18, 2004 9:42 PM
Subject: Re: [lpc2000] Re: Interrupt Handling (Vector checksum)
> the
> Regards,
>        Martin
> From: "tom_laffey" <tom_laffey@...>
>> Hi Robert,
>>        ivt_CRC = 0;
>>        pVectors[5] = 0;
>> Thanks,
>> Tom
>> I've
>> below)
>> From
>> dependency
>> calculation
>>> Robert
>> restrictions,
>> to
>>>                          Kelvin Throop, III
>> Yahoo! Groups Links
Inverting and adding 1 is a twos complement negation so I would expect it
to be that same.  I think you are right though a comparison would be useful.
Tom what processor are you running this on?
Robert
                         Kelvin Throop, III
Martin,
2's complement can be generated a few ways; I chose the
textbook "flip the bits and add 1".  Subtracting from 0 as you have
done produces the same value.
I'm generating the checksum on a PC (little endian) and the LPC is
little endian, so no trouble found there.
I'm thinking that the checksum is a red herring, so I'm looking at my
IAP flash write function to see where there could be a problem.  If I
find something, I'll post here.
Tom
--- In lpc2000@yahoogroups.com, capiman@t... wrote:
> Endian-Problem ?
> From: <capiman@t...>
perhaps load
> > the
> > Regards,
> >        Martin
> > From: "tom_laffey" <tom_laffey@y...>
> >> Hi Robert,
> >>        ivt_CRC = 0;
0x14
> >>        pVectors[5] = 0;
binary
at
Philips
boots.
> >> Thanks,
> >> Tom
Re: Interrupt Handling (Vector checksum, Flash over-writing)
This turns out to be what I think is an interesting result.
I am maintaining state of each image in flash by clearing bits in a
state word.  This includes the boot program, which has a little
header offset from the vector table by a few bytes.
I noticed the other day that when I over-write the flash with a value
that writes '0's where there are already '0's, I will get a "disturb"
elsewhere in the word.  In the specific case I found, I was writing
0xFFF0 to a value (alread in flash) of 0xFFF5 and getting 0xF7F0 when
I read the result back.
What was happening with my vector table is that some bit(s) in the
first 32 bytes were being corrupted by the over-writing of a word in
the header, outside of the vector table.
To correct the problem, I now fill my write buffer with 0xFF's and
zero the exact bit(s) I need to, and then write the whole page to the
flash.  End of problem--the board boots.
I am using an LPC2294, but I suspect that this behavior would likely
be common to all parts in the LPC2xxx family.
Thanks to those who provided pointers while I was tracking this down.
Tom
--- In lpc2000@yahoogroups.com, "tom_laffey" <tom_laffey@y...> wrote:
> Martin,
my
I
> Thanks,
> Tom
> > Endian-Problem ?
> perhaps load
> > > the
> > > Regards,
> > >        Martin
> > >> Hi Robert,
is
> > >>        ivt_CRC = 0;
address
> 0x14
> > >>        pVectors[5] = 0;
> binary
> the
looking
> at
> Philips
> boots.
> > >> Thanks,
> > >> Tom
