Lpc2000
Uart FIFOs being disabled
2004-11-19 by peterburdine
Has anyone had experience with their UART fifos being randomly
disabled?  For some reason, my UART0 fifo is being diabled seemingly
randomly.  The application itself is not that complex, it receives a 2
byte command and sends back 10 bytes of status.  Somehow, the fifos
get disabled, then a CTI interrupt occurs that I cannot get rid of.
In the manual it says to clear CTI I need to read RSR.  I don't see an
RSR register, but I would assume that they meant RBR.
Any suggestions?
Peter
Re: Uart FIFOs being disabled
2004-11-20 by emerg_reanimator
--- In lpc2000@yahoogroups.com, "peterburdine" <lordofdawn@h...>
a 2
an
RSR stands for Receiver Shift Register. It's program invisible and
connected directly to RBR (See UART architecture block diagram). So
reading should update RSR status.
> Any suggestions?
> Thanks,
> Peter
Hi, Peter
I am interesting which "UART interrupt handling" (U?IIR[3:0]) mode you
use?
2004-11-22 by peterburdine
--- In lpc2000@yahoogroups.com, "emerg_reanimator"
> a 2
> an
> > Any suggestions?
> > Thanks,
> > Peter
> Hi, Peter
> use?
I am using RBR and THRE.  I probably should have also noted that this
is a motor control board so the data receveived on UART0 is commands
to change the PWM (2&5).
2004-11-23 by Randy Ott
seemingly
receives
> > a 2
fifos
rid of.
don't see
> > an
and
So
> > > Any suggestions?
> > > Thanks,
> > > Peter
> > Hi, Peter
mode you
> > use?
this
commands
Peter,
You are correct that you "read the RSR" by reading a character from
the RBR.  You must, however handle CTI interrupts.  These can be
handled using the same code as the RDA handler.  If the FIFO has a
few characters in it for the length of the timeout period, the CTI
interrupt will fire and, if the characters are not read, CTI will
not clear and the FIFOs will cease to operate.  Sounds like this
might be the problem.
Good luck,
Randy Ott
