Lpc2000
USB host and ARM
USB host and ARM
2004-11-30 by Gus
Hello,
I am looking for ARM chip with built-in USB "host"! I know there are
hundreds out there but I am looking for one with built in FLASH and
RAM, just like LPC2000 chips.
Any ideas?
Gus
RE: [lpc2000] USB host and ARM
2004-11-30 by James Dabbs
About a year ago I couldn't find any.  Manufacturers seemed to assume
that the host would require a larger OS & application framework (like
WinCE and Linux) to support the USB stack, and it's hard to fit this
into on-chip FLASH.
The closest I found was an ATMEL AT91RM9200.  It has a ROM that can be
mask programmed, and it can boot from an external serial device.  If you
paired your code down to hard support for a single device, this could
give you a *reasonably* small system footprint.
Re: [lpc2000] USB host and ARM
2004-11-30 by Robert Wood
Atmel AT91SAM7A3 might be what you want. It's brand new, datasheet's not on
the web site. Engineering samples are available, so if it's a decent volume
project and you don't need to have it production within a couple of months it
might be fine for you.
I'm not sure about the "host" bit. I've never done USB, but isn't usually the
PC that's the host? Bear in mind I could be talking bollocks! ;-)
Rob
Hello,
Any ideas?
Gus
Yahoo! Groups Links
2004-11-30 by Robert Adsett
AT91SAM7S64? - It claims a transceiver for USB, but I don't know that there
is enough room for a host implementation (I'm not even tempted).  It's data
sheet is now available though.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
>> AT91SAM7S64? <<
Nope, definitely 7A3.  As I said, it's not yet on the website, but I'm sure
your local disty would help you out.
is enough room for a host implementation (I'm not even tempted). \ufffdIt's data
sheet is now available though. <<
<Checks data sheet for 7A3>
It says it has "USB 2.0 Full Speed Device Port".
My (very) limited knowledge of USB suggests this is not a "host". AFAIK, the
host is what initiates comms and embedded devices tend to be slaves (or
whatever the term might be).
The only embedded device I know of which I *think* has a host controller is
one of the Freescale Coldfire MCF4 summat or another!
All this is subject to the caveat that I know next to Jack about USB. :-)
Rob.
2004-12-01 by Larsen, Morten ActeNO
I use the AT91SAM7S64 (in the form of "AT91SAM7S64-EK" evalboard + IAR
SW)
and it has indeed USB transceiver, but *device* (function) controller
only - no host.
Two device/function-side examples are given by Atmel;
std.2-button mouse(emulated by pushbuttons),
and USB-to-serial bridge - none of which need any special SW on the
PC/Mac/Linux (host) side.
This works (surprisingly) well - hasn't discovered any flaws yet.
The sourcecode originates from Atmel's C51-variants(AT89-family) MCUs
w.USB-deviceport,
so it's quite portable above the UDP HW-driver level.
My suggestion for host controller would be the Atmel AT43USB380.
It's far easier to use than it's TransDimension and Cypress counterparts
(and sorry Phillips, yours seem to be awkward as well ...)
since it carries an onboard RISC core to do lowlevel protocol handling
(a.k.a. 'arbitration').
Atmel has done quite extensive porting of their SW to both different
architectures(ARM7&9/XScale, SuperH, ++)
and different compilers (ARM, GreenHills, and recently GNU, for the
ARM), and it is *royalty free*:-)
But; you get another LQFP-100 package into your design though ...
-Morten
> From: Robert Adsett [mailto:subscriptions@...]
> Sent: Tuesday, November 30, 2004 10:06 PM
> To: lpc2000@yahoogroups.com
> Subject: Re: [lpc2000] USB host and ARM
> >not on the web site. Engineering samples are available, so if it's a
> >decent volume project and you don't need to have it
> production within a
> >couple of months it might be fine for you.
> know that there is enough room for a host implementation (I'm
> not even tempted).  It's data sheet is now available though.
> Robert
> restrictions, be they legal, genetic, or physical.  If you
> don't believe me, try to chew a radio signal. "
>                          Kelvin Throop, III
> $9.95 domain names from Yahoo!. Register anything.
> http://us.click.yahoo.com/J8kdrA/y20IAA/yQLSAA/dN_tlB/TM
Re: USB host and ARM
2004-12-01 by lpc2100_fan
Gus,
got some information about the Atmel devices. All that I have seen are
DEVICE only. No host functionality.
Cheers, Bob
--- In lpc2000@yahoogroups.com, "Gus" <gus_is_working@y...> wrote:
> Hello,
> Any ideas?
> Thanks,
> Gus
2004-12-01 by Gus
Bob and all,
Thanks for all the replies. You are right Bob. Everything said was
for device not a host!!
I am looking for HOST (same as PC) where you can plug a device (mose
or keyboard) in.
I am not aware of any low cost chip with USB host function! Maybe
they make hosts only for chips that run linux and windows, too bad!
Gus
--- In lpc2000@yahoogroups.com, "lpc2100_fan" <lpc2100_fan@y...>
wrote:
> Gus,
are
> Cheers, Bob
> > Hello,
are
and
> > Any ideas?
> > Thanks,
> > Gus
RE: [lpc2000] Re: USB host and ARM
2004-12-01 by Messal, Art
Hi Gus,
Rumor has it that Philips will soon have an LPCxxxx device which can act as
both a USB slave and host.  But
this is only rumor. LPC23xx with USB on-the-go.
   -Art-
  _____
Sent: Wednesday, December 01, 2004 11:07 AM
Subject: [lpc2000] Re: USB host and ARM
Bob and all,
or keyboard) in.
Gus
wrote:
> Gus,
are
> Cheers, Bob
> > Hello,
are
and
> > Any ideas?
> > Thanks,
> > Gus
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129aspcv7/M=298184.5639630.6699735.3001176/D=gr
oups/S=1706554205:HM/EXP=1102010920/A=2434971/R=0/SIG=11eeoolb0/*http://www.
netflix.com/Default?mqso=60185400> click here
<http://us.adserver.yahoo.com/l?M=298184.5639630.6699735.3001176/D=groups/S=
:HM/A=2434971/rand=822081700>
  _____
Yahoo! Groups Links
*	To visit your group on the web, go to:
http://groups.yahoo.com/group/lpc2000/
<http://groups.yahoo.com/group/lpc2000/>
*	To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
2004-12-01 by Gus
Philips already have USB hosts that are none-PCI so adding one to
the LPC family is not impossible.
--- In lpc2000@yahoogroups.com, "Messal, Art" <art.messal@e...>
wrote:
> Hi Gus,
can act as
>    -Art-
>   _____
> From: Gus [mailto:gus_is_working@y...]
> Bob and all,
(mose
> or keyboard) in.
> Thanks,
> Gus
> wrote:
> > Gus,
seen
> are
> > Cheers, Bob
wrote:
> > > Hello,
there
> are
FLASH
> and
> > > Any ideas?
> > > Thanks,
> > > Gus
> ADVERTISEMENT
76/D=gr
://www.
>   _____
Service
Re: [lpc2000] Re: USB host and ARM
2004-12-01 by Marko Panger
Hi all,
As Larsen said Atmel has a nice USB Host/OTG chip AT43USB380. Recently I
have set up a discussion group about Atmel USB products in particular
about the 380 device. If you or maybe someone else is interested is
invited to join the group.
Working with this device is very nice. Atmel provides a good library for
device/host mode as well as a mass storage device driver. The
documentation is well written. The only bad point is that the library is
compiled with ADS1.2, but I have been told that Atmel is working hard to
release a GCC library in these days.
The link to the group is:
http://groups.yahoo.com/group/atusb
I will be using this device with the LPC2214.
Marko Panger
>wrote:
>>Hi Gus,
>can act as
>>   -Art-
>>  _____
>>Bob and all,
>(mose
>>or keyboard) in.
>>Thanks,
>>Gus
>>wrote:
>>>Gus,
>seen
>>are
>>>Cheers, Bob
>wrote:
>>>>Hello,
>there
>>are
>FLASH
>>and
>>>>Any ideas?
>>>>Thanks,
>>>>Gus
>>ADVERTISEMENT
>76/D=gr
>://www.
>>  _____
>>Yahoo! Groups Links
>Service
>Yahoo! Groups Links
