I have looked through the file section and found an EAGLE lbr uploaded
by richas. I modified the symbol so it would be compatible to the one
used by Olimex.
The module is ready. It is called LPC-M416. It is compatible to the
Olimex H40 and carries a 16 pin connector that matches the used pins
of the Wigler 20 pin JTAG adaptor.
I uploaded a pdf of the schematic. It would be nice to get a comment
on the schematic by someone who has used the Wiggler JTAG before I
upload the board.
Eduardo
--- In lpc2100@yahoogroups.com, "leon_heller" <leon_heller@h...>
wrote:
> --- In lpc2100@yahoogroups.com, "eduardo_de_mier" <e.demier@g...>
wrote:
> > I need a couple of boards compatible to the Olimex LPC-H40. My
> > customer has access to free LPC samples from Philips. However
Tsvetan
> > told me that he would not sell the blank pcbs. On the other hand
David
> > Willmore posted that he would like a version with low diameter
pins
> > that fit in a DIP40-socket.
> > For these reasons I am planing to design a LPC-H40 pin compatible
pcb
> > with EAGLE.
> > If someone would join me doing the part library f.e. I would not
mind
> > to post the result for free download, similar to the way Leon has
done
> > it.
> > Still there is the possibility that Tsvetan would change his mind
> > Eduardo
> I was halfway through designing a 40 pin module when Olimex
announced
> their's, so I lost interest. It wouldn't take long to finish it off.
> As it stands it isn't compatible with the Olimex one. I was
intending
> to make it a bit wider (1"), but could make it fit a 0.6" wide
socket.
> I'll upload the schematic and preliminary PCB layout.
> Leon
