Lpc2000
Re: Supply Current of LPC213x
2005-02-03 by Owen Mooney
Well - this all rips my socks!!
I put a post in a few weeks ago asking about power consumption of the LPC213x series
for use in a data logger.
Robert said then about 150uA. This was too much for a logger with a 10 year battery life on a Lithium.
So - I have just done a layout using a PIC !
Now I understand the latest run of chips is about 50uA. Quite some difference, and worth while ripping the PIC out of the circuit and putting in an LPC2132
Please confirm. For an LPCLPC213x series microprocessor with 32768 Xtal running powern consumption is 50+18uA in Powerdown mode and when I wake up from an external interupt I can read the current Xtal osc value in the CTC register ?
If so I will rip out the PIC anbd use one of these - even if I have to go to a C size cell.
What is the expected power consumptin of these devices in future production runs?
Owen Mooney
 Date: Wed, 02 Feb 2005 14:29:09 -0000
Subject: Re: Supply Current. Lots additional information
I didn't see an explanantion for the 350uA sleep current or my
questions 1 and 2 concerning the I/O. Do I need to try a new device
on the evaluation board?
50uA sleep current is perfect, 140uA is tolerable, and 350uA is a
show stopper.
--- In lpc2000@yahoogroups.com, "philips_apps" <philips_apps@y...>
wrote:
>> Tim,
>> I guess the 350 mA (the "m" should be a "u")was a typo. What you
>> measured in power down for the RTC is correct between 15 and 20
uAs.
>> Logic in this process needs to run at 1.8V \ufffd 10 %. A pin like
Vbat
>> needs a wider spec and a different voltage. The spec for Vbat will
be
>> significantly extended to probably 2.0V-3.6V (characterization is
>> ongoing). To not damage the logic we need to convert the external
>> voltage down to 1.8V The converter uses most of the 18 uAs you
measured.
>> The higher current during active mode is due to an chip failure on
>> first devices, which have been used to build evaluation boards. New
>> devices will not draw higher current during active mode on Vbat but
>> still draw the 15-20 uAs.
>> THIS INFORMATION IS SPECIFIC FOR THE LPC2130 series
>> Power down current on the first devices was measured around 140
uAs,
>> keeping all the RAM intact. Our latest lot with some fixes brings
this
>> value down to approx 50 uAs.
>> While this value might be too high for some of you, it might be
good
>> enough for others and it is for sure a lot better than the previous
>> option to go into idle mode using the RTC.
>> Comparing an ARM build in 0.18um process to an AVR, PIC, MSP430 or
you
>> name them is really comparing apples to oranges. New processes
enable
>> the chip vendors to put more memory and build faster devices but
>> leakage goes up.
>> In the end the only thing I can tell you, this is as good as it
gets
>> right now. Will let everybody know if we find ways to improve the
>> power down behavior. Keep in mind that active current is as low or
>> lower than an 8-bit running at the same clock rate delivering a lot
>> less performance.
>> Regards, Robert
>> --- In lpc2000@yahoogroups.com, "tah2k" <tah2k@y...> wrote:
>>> > I finally got to the point of shutting down the LPC2138 on the
Keil
>>> > development board. Battery life is critical to my application,
>>> > therefore I need to verify the sleep specification. At room
>>> > temperature, with all I/O configured as input except for JTAG, I
am
>>> > measuring 350mA just on the VDD pins! Far from 10uA. All
peripheral
>>> > clocks are disabled except the RTC which is configured to use
>>> > 32kHz.
>>> > FYI:
>>> > Vbat: ~31uA while processor is on, ~18uA during powerdown. (Just
for
>>> > the RTC?!?!)
>>> > When it comes to sleep current issues, the first thing vendors
>>> > usually question is the I/O state. The following are the
relevant
>>> > register values:
>>> > PINSEL0: 0x0
>>> > PINSEL1: 0x0
>>> > PINSEL2: 0x4
>>> > IODIR0: 0x0
>>> > IODIR1: 0x0
>>> > IOPIN0: 0x7EFFF7F8
>>> > IOPIN1: 0x03FF0000
>>> > I'm puzzled about the I/O:
>>> > 1.) The IOPIN register does not necessarily reflect the state of
>>> > I/O line. For example, P0.4 is not connected on the Keil board.
>>> > Since this pin is configured as an input, I would suspect the
>>> > voltage on the pin to reflect the internal pullup, but it
measures
>>> > 0V. Even more puzzling, IOPIN0 states this input is high. Go
figure.
>>> > 2.) Another concern: P0.31 is not connected, but configured as
an
>>> > input. If I measure the pin voltage it is 2.3 instead of 3.3V.
This
>>> > is also true for P1.16-23 and P1.24-25. Could I be leaking
current
>>> > through the pullup resistor?
>>> > -Tim
>> ---  snip   -----
2005-02-03 by philips_apps
--- In lpc2000@yahoogroups.com, Owen Mooney <ojm@s...> wrote:
---snip ----
Owen,
when we designed the LPC2130 series we expected to see Ipd in the
neighborhood of 50 uAs. Unfortunately the first lot came out with an
average of 150 uAs and we were all p.....ed.
There were 2 minor changes to the latest rev "A" which is not in the
filed yet and now we are measuring the devices between 40 and 60 uAs.
This does not include the 15-20 uAs for Vbat as you pointed out
correctly. Also keep in mind that a current from Vbat will also be
drawn during active mode. The rev "A" will draw the same current from
Vbat no matter teh CPU is active or not. The first devices that you
would have right now draw much higher current while the CPU is running
proportional to bus activity.
Ipd is a very difficult value to specify in this process because small
changes in the process will move the point where the Ipd takes off
based on temperature from around 70 C to a temp close to 25C. In this
case Ipd goes up.
If you look in different specifications also from competitors selling
highly integrated ARM chips, you will see a significant difference
between typical Ipd and max Ipd because of this big temperature effect.
Hope this little background information helps,
It's late here, good night, Robert
production runs?
> Owen Mooney
----  snip  ---
2005-03-08 by Richard
My LPC2138 RTC is drawing ~16uA through Vbat, nice.  Your mileage may
vary.
Richard
the LPC213x series
production runs?
> Owen Mooney
>    From: "tah2k" <tah2k@y...>
> show stopper.
> wrote:
> >> Tim,
> uAs.
> >> Logic in this process needs to run at 1.8V ± 10 %. A pin like
> Vbat
> be
> measured.
> the
> uAs,
> this
> good
> you
> enable
> the
> >> leakage goes up.
> gets
> >> less performance.
> >> Regards, Robert
> Keil
> am
> peripheral
> the
> >>> > 32kHz.
> >>> > FYI:
> for
> >>> > the RTC?!?!)
> relevant
> >>> > register values:
> >>> > PINSEL0: 0x0
> >>> > PINSEL1: 0x0
> >>> > PINSEL2: 0x4
> >>> > IODIR0: 0x0
> >>> > IODIR1: 0x0
> >>> > IOPIN0: 0x7EFFF7F8
> >>> > IOPIN1: 0x03FF0000
> the
> measures
> figure.
> an
> This
> current
> >>> > -Tim
> >> ---  snip   -----
2005-03-08 by Jan Szymanski
for a very low power datalogger have a look at msp430...
the LPC213x series
production runs?
> Owen Mooney
> show stopper.
> wrote:
> >> Tim,
> uAs.
> Vbat
will
> be
> measured.
on
> the
New
but
> uAs,
brings
> this
> good
previous
or
> you
> enable
> the
> >> leakage goes up.
> gets
or
lot
> >> less performance.
> >> Regards, Robert
> Keil
application,
JTAG, I
> am
> peripheral
> the
> >>> > 32kHz.
> >>> > FYI:
(Just
> for
> >>> > the RTC?!?!)
vendors
> relevant
> >>> > register values:
> >>> > PINSEL0: 0x0
> >>> > PINSEL1: 0x0
> >>> > PINSEL2: 0x4
> >>> > IODIR0: 0x0
> >>> > IODIR1: 0x0
> >>> > IOPIN0: 0x7EFFF7F8
> >>> > IOPIN1: 0x03FF0000
of
> the
board.
> measures
> figure.
as
> an
3.3V.
> This
> current
> >>> > -Tim
> >> ---  snip   -----
2005-03-09 by Owen Mooney
Thanks
And the Power down current? or arn't you going there. I beleve Vbat gets
added to VCC
Owen
>vary.
>Richard
Nah !
Thanks Jan, but I've had a look at some of these and I don't think this one supports SPI (for logging storage)
Also I've painted myself into a development corner in the past (you know - can i get a bit more ram or a bit more rom or a bit more speed) and i'm not doing it again. I would rather pay for a C Lithium which will give 10 years operation.
Owen
Subject:
2005-03-09 by Richard
No, that is 16uA with Vcc off/removed.  Yes, I believe you are
correct, Vbat current gets added to Vcc current.  Perhaps the apps
types can add to this, I know there were some peculiarities.
Richard
> Thanks
gets
> added to VCC
> Owen
> >vary.
> >Richard
