I'm trying to get my LPC21xx running as reliable
as possible. I did:
- Good power supply de-coupling and PCB layout.
- Flash fetch cycle at 3-4 clocks
- Using external 50Mhz OSC clock and avoid
turning on the internal PLL (Philips 51RD2 x2 PLL is
very reliable but I'm still not comfortable with
LPC2K PLL of 200-300Mhz at 1.8V). I actually do
not even like the crystal oscillator at 1.8V so
I used a 5V OSC module and clamp down the amplitude.
(Power consumption issue less important)
The next thing I would like to look into is the
core voltage increased to 1.95V. My "feeling"
is chip might run more reliable at that voltage.
(And hoping that philips has fully test out the
internal flash program + charge pump reliability at
that 1.95V max core voltage)
Anybody who had done a full stress test of the chip
(Max Clock freq, Voltage, temperature range etc) and
understand how to further improve the reliability,
please let me know. I'm lack of good "burn-in"
facilities.
Many THANKS in Advance /MH
--- In lpc2000@yahoogroups.com, "top4e" <top4e@y...> wrote:
> > > I have better rezults. I'm using LPC2124 at 103,2192 MHz with
> > 14,7456
> > > MHz quartz. The best result was with 10MHz quartz at 110MHz,
but
> > > works unstable.
> > Hi,
> > Questions: What's your supply voltage for CPU core?
> > Is that exact 1.8V or Higher? like 2.5V??
> > I believe you should run faster at higher core voltage.
> > Actually, I'm just thinking of supply slightly higher
> > than 1.8V for my 50MHz operation. That should improve
> > the reliability.
> > Thanks /MH
> Hi unity0724,
> The core voltage is 1.83V. I think the limit is peripherial clock
> limeted around the 25MHZ. I think that the higher voltage is not
good
> idea, when you wark in normal freqency range. The controler must
be
> fully tested in this range of frequencis. The result woud be
higher
> chip temperature, I think.
