On 5 Apr 2005 at 22:19, ntfreak2000 wrote:
> --- In lpc2000@yahoogroups.com, "Anton Erasmus" <antone@s...> wrote: >
> On 5 Apr 2005 at 9:02, ntfreak2000 wrote: > > > > > > > --- In
> lpc2000@yahoogroups.com, Leonardo Santos <lsantos@p...> wrote: > > >
> Rebuilding my toolchain and searching where _udivsi3.o was compiled, >
> > I noticed > that there are four versions of libgcc.a: > > > >
> lib/gcc/arm-elf/3.4.3 > lib/gcc/arm-elf/3.4.3/thumb > > >
> lib/gcc/arm-elf/3.4.3/interwork > > >
> lib/gcc/arm-elf/3.4.3/thumb/interwork > > The first is compiled with >
> > no options. The second with -mthumb, the third with > > >
> -mthumb-interwork and the last one with -mthumb -mthumb- interwork. By
> > > using > -L to include the appropriate one (in my case, > > >
> lib/gcc/arm-elf/3.4.3/interwork), all erros went away. So sorry for >
> > raising a > flag for no reason. > Thanks a lot! > > On Monday 04
> April > > 2005 13:01, Robert Adsett wrote: > > At 12:00 PM 4/4/05
> -0300, > > Leonardo Santos wrote: > > > First, than you all
> for the > > answers on my previous question about > > > a C union > >
> >not working > > for IO access. I'm now compiling some programs with
> GCC 3.4.3 > > > > > and newlib 1.12. I've download the source packages
> from > > > > > http://rod.info/arm.html and used his build script to
> build the > > > > > toolchain. All went very smooth. I've been able to
> compile FreeRTOS > > for > > > LPC2106 and tried to blink some LEDs >
> > >(hence the > > question about the C union), but when I try to use
> any code > > > from > > the newlib, I get the following warning: > > >
> > > >arm-elf-ld: > > Warning: /opt/arm/lib/gcc/arm-elf/3.4.3//libgcc.a
> (_udivsi3.o) > > > > >does > > >not support interworking, whereas
> test2.prg does > > > > > > It's complaining that the C compiler
> library is not compiled with > > > > internetworking. In this case
> it's trying to link in a division > > > > routine. Newlib does not
> provide these, they are built with gcc > > normally. > > > > Robert >
> > > > > > It sounds like you are calling ld directly on the command
> line. > > If you use gcc to perform the link then the correct libs
> will always > > be used. > > > > Unfortunately that does not appear to
> be the case. I have a similar problem in that > the correct libraries
> are not automatically being used. I am definitely linking using gcc >
> and not ld. When using the arm-elf binary toolset from
> http://www.gnuarm.com under > cygwin, my code links with the correct
> libraries. If I use the linux binaries from the same > site under RH9,
> I get similar errors. When using tools built from source using Rod >
> Moffit's excellent buildscript, I also get the errors. I can also
> manually force the link with > the correct libraries, but this is a
> pain. Where / How does gcc decide which libraries > to use when
> linking ? Also if one wants to use some of the less common compile >
> options, that result in binary incompatibilities, how can one build a
> libgcc with the same > options ? e.g. if one wants to use the option
> -fpack-struct. > > Regards > Anton Erasmus > -- > A J Erasmus
> Just had a look at the build script you are using, its not the
> process I have been using to build a cross-compiler.
> My only comments are he performs a make all before he has built his c
> library (newlib), normally you need to do a make all-gcc install-gcc
> to build the bootstrap compiler then build newlib - then back to do a
> make all install.
I will modify the script to first build the bootstrap compiler, then newlib,
and then the final compiler. Do I need to run configure for the compiler
again after building newlib ?
Anton Erasmus
A J Erasmus
