Lpc2000
Rx Identifier Register problem
2005-04-07 by burner_itfi
Hello,
I use the LPC2119.
When i get an receive interrupt, i'm looking in the frame status
register (RFS), if the received msg is a standard or extended msg. The
frame format bit is 0 and indicates that the received msg is an 11-bit
identifier but when i read the identifier register (RID), the
identifer is larger than 0x7FF. This happen only by high busload on
both can interfaces.
I hope someone can help me. Thanks!
Tobi
