SCK SPI
2005-04-08 by dasbento@aeiou.pt
Hello, Is it possible to generate a continuous serial clock on the SPI? _________________________________________________________ CEAC Cursos de forma\ufffd\ufffdo profissional - pe\ufffda informa\ufffd\ufffdes aqui.: http://ceac.online.pt/
2005-04-08 by Robert Adsett
At 04:32 PM 4/8/05 +0100, dasbento@... wrote: >Is it possible to generate a continuous serial clock on the SPI? I don't believe so. It would only result in missing data. Robert " 'Freedom' has no meaning of itself. There are always restrictions, be they legal, genetic, or physical. If you don't believe me, try to chew a radio signal. " -- Kelvin Throop, III http://www.aeolusdevelopment.com/
Thanks Robert!
I'm using an AD (ADS8325, texas instruments) and i want to comunicate
with SPI. But i don't know how. The ADS8325 not have an internal clock
. Therefore, it is necessary to use the SPI clock to make the conversions.
Any solution to my problem?
Domingos
Citando Robert Adsett <subscriptions@...>:
> Robert
restrictions, be
chew a
http://ceac.online.pt/2005-04-08 by valdef78
--- In lpc2000@yahoogroups.com, dasbento@a... wrote: > Thanks Robert! > > > I'm using an AD (ADS8325, texas instruments) and i want to comunicate > with SPI. But i don't know how. The ADS8325 not have an internal clock > . Therefore, it is necessary to use the SPI clock to make the conversions. > Any solution to my problem? > > Domingos > you had to send/read 3 bytes on the SPI to give the necessary clock to the ADS8325 and take the data from it.. you should have a look to the application notes at the bottom of the page here : http://focus.ti.com/docs/prod/folders/print/ads8325.html look at the "Interfacing the MSOP8EVM to MSP430 Processors". you should find the explanation here and sample code..
At 05:06 PM 4/8/05 +0100, dasbento@... wrote: >I'm using an AD (ADS8325, texas instruments) and i want to comunicate >with SPI. But i don't know how. The ADS8325 not have an internal clock >. Therefore, it is necessary to use the SPI clock to make the conversions. >Any solution to my problem? It depends on how it works Option 1 - The device only works when connected. IE the select line must be held low during conversion. In that case the A/D would presumably have a period where dummy bytes were clocked in to perform the conversion. I would expect it to be documented that way, something like send 1 byte configuration followed by two dummy bytes for conversion, On the third dummy byte the actual converted data is clocked out. Option 2 - The device clocks data in/out during the period the select is low but requires a continuing clock when select is high to actually perform the conversion. In that case you could select the device as normal when setting up and reading. Then deselect it and send out dummy bytes during the period it is deselected. In any case you will be sending & receiving data while the clock is running. Robert " 'Freedom' has no meaning of itself. There are always restrictions, be they legal, genetic, or physical. If you don't believe me, try to chew a radio signal. " -- Kelvin Throop, III http://www.aeolusdevelopment.com/
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@a...> wrote: > At 05:06 PM 4/8/05 +0100, dasbento@a... wrote: > >I'm using an AD (ADS8325, texas instruments) and i want to comunicate > >with SPI. But i don't know how. The ADS8325 not have an internal clock > >. Therefore, it is necessary to use the SPI clock to make the conversions. > >Any solution to my problem? > > It depends on how it works > > Option 1 - The device only works when connected. IE the select line must > be held low during conversion. In that case the A/D would presumably have > a period where dummy bytes were clocked in to perform the conversion. I > would expect it to be documented that way, something like send 1 byte > configuration followed by two dummy bytes for conversion, On the third > dummy byte the actual converted data is clocked out. > > Option 2 - The device clocks data in/out during the period the select is > low but requires a continuing clock when select is high to actually perform > the conversion. In that case you could select the device as normal when > setting up and reading. Then deselect it and send out dummy bytes during > the period it is deselected. In any case you will be sending & receiving > data while the clock is running. > > Robert the clock is not needed continuously. it just need to send/receive 3 bytes to get the data. that's the way it's done in the application note I pointed in my precedent post.. description from the datasheet : "A falling /CS signal initiates the conversion and data transfer. The first 4.5 to 5.0 clock periods of the conversion cycle are used to sample the input signal. After the fifth falling DCLOCK edge, DOUT is enabled and will output a LOW value for one clock period. For the next 16 DCLOCK periods, DOUT will output the conversion result, most significant bit first. After the least significant bit (B0) has been output, subsequent clocks will repeat the output data, but in a least significant bit first format. After the most significant bit (B15) has been repeated, DOUT will tri-state. Subsequent clocks will have no effect on the converter. A new conversion is initiated only when CS has been taken HIGH and returned LOW."
