Lpc2000
Two layer PCB and LPC2000
2005-07-09 by varuzhandanielyan
Does anybody succeeded with design of two layer PCB
with LPC2138 or similar chip?
There was an opinion on this forum, that at least 4
layers are necessary.
But such an approach is highly decreasing the advantage
of the low cost of the LPC2000 series.
Varuzhan
Re: Two layer PCB and LPC2000
2005-07-09 by valdef78
> Varuzhan
why not ??
here is a two layer example :
http://www.geocities.com/leon_heller/lpc2104.html
as for any high speed mcu, you should be careful at the way you route
your board, but I don't see why it couldn't be possible with LPC..
Re: [lpc2000] Two layer PCB and LPC2000
2005-07-09 by sudip nag
Hi Varuzhan,
I have tested LPC2138 both in single layer and double layer PCB. In double layer I had run it at 55.296MHz cclk. It was absolutely reliable. 4 layer and above PCBs are recommended for highly sophisticated designs. Its always preferable to use multilayer PCBs, but compromise between high performance and low cost is always there.
Sudip
Varuzhan
SPONSORED LINKS
Microcontrollers Microprocessor Intel microprocessors Pic microcontrollers
YAHOO! GROUPS LINKS
 Free antispam, antivirus and 1GB to save all your messages
 Only in Yahoo! Mail: http://in.mail.yahoo.com
2005-07-09 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Saturday, July 09, 2005 4:48 AM
Subject: [lpc2000] Two layer PCB and LPC2000
With careful layout two layers are OK, as with most microcontrollers. It
will be difficult to meet EMC requirements with two layers, however, and
four layers are probably mandatory for a product that is to be sold in
Europe.
Leon
Leon Heller, G1HSM
leon.heller@...
Checked by AVG Anti-Virus.
Version: 7.0.323 / Virus Database: 267.8.11/44 - Release Date: 08/07/2005
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
2005-07-09 by Boris Králik
I am working with fourth layer board. More spaces for
ground and power supplies.
BorisK
> advantage
> Varuzhan
Regards / S pozdravom Boris Kralik
http://www.geocities.com/kralikbo/
___________________________________________________________
Yahoo! Messenger - NEW crystal clear PC to PC calling worldwide with voicemail http://uk.messenger.yahoo.com
2005-07-09 by Gus
All our boards are 2 layers!!!
www.ghielectronics.com
> > Varuzhan
> why not ??
route
2005-07-09 by tonalbuilder2002
> But such an approach <4 layer> highly decreasing the advantage
Almost any board can be laid out with just 2 layers if you have
enough
room.  But keep in my mind that is it possible to make a 4 layer
board
a lot smaller than the same board as a 2 layer, since you don't have
to
leave room for power traces.  Also, it usually takes less time to lay
out a 4 layer board which may affect economies on small runs.
Keep down the cost of 4 layer boards by "panelizing" them.  Place a
matrix of small boards on the most economical large board size your
supplier offers, then cut them apart with a band saw.  Most layout
software packages have a panelizing feature or macro.  Place long XY
traces on the panelized board to guide the cuts, then smooth the cut
edges with sandpaper.
Bill T.
http://www.kupercontrols.com
2005-07-10 by Charles Manning
If you are using a system where your memory bus is going out of the chip to
access other chips, then a 4 layer board is a good idea.
With single-chip systems all the real fast stuff is happening inside the chip
and there is no real need for a 4 layer board.
2005-07-11 by Jack Yu
All our boards are 2 layers andwith gsm/cdma module.
JackYu
2005/7/11
 Sell on Yahoo! Auctions  - No fees. Bid on great items.
2005-07-11 by Grzegorz
Our design - smart card reader, based on LPC2104/6, failed with 2-
layer pcb. High voltage spikes (although with proper ESD
guarding/decoupling on socket/MCU side) sometimes generated processor
exceptions. 4-layer pcb completely solve this problem.
Similar design (also on '2106), operated inside high electromagneic
field (RFID reader), is comercially produced on 2-layer pcb, with no
afford.
So, question - 2 or more layers for LPC, strongly depends of target
application. My 'home made' LPC starter kit was single layer pcb and
worked perfectly ...
Grzegorz
> JackYu
> 2005/7/11
