Lpc2000
Two layer PCB and LPC2000 and EMC
2005-07-10 by Owen Mooney
What I did (with an LPC2138) was to put a ground layer (polygon) under
the  board (top and component side) extended out to under the Xtal. In
the 2138 this ground plane was divided into 3 segments by the VCC lines
which came to the center. I joined the segments  by three vias and a
smaller polygon on the other side of the board, putting a 0.1 uf cap
right under the chip for decoupling.
I'm not expecing significant EMC except in the Houdini band.
Owen Mooney
Re: [lpc2000] Two layer PCB and LPC2000 and EMC
2005-07-10 by Alexandre Guimaraes
Hi, Owen
    Would it be possible to have a image of this part of the board ? It
would help a lot many of us that are starting to work with the LPC's.
Best regards,
Alexandre Guimaraes
To: <lpc2000@yahoogroups.com>
Sent: Sunday, July 10, 2005 6:17 PM
Subject: [lpc2000] Two layer PCB and LPC2000 and EMC
> Owen Mooney
Re: Two layer PCB and LPC2000 and EMC
2005-07-11 by Owen Mooney
Uploaded as pdf to the files section crt diagram + images.
Owen
Hi, Owen
Best regards,
Alexandre Guimaraes
Re: [lpc2000] Re: Two layer PCB and LPC2000 and EMC
2005-07-12 by Alexandre Guimaraes
Hi, Owen
    Nice layout...  Thanks..
    Is just one 0.1uf cap enough for decoupling the LPC2138 ?? Wouldn't it
be necessary to use one cap for each power pair ?
Best regards,
Alexandre Guimaraes
Sent: Monday, July 11, 2005 6:45 PM
Subject: [lpc2000] Re: Two layer PCB and LPC2000 and EMC
> Owen
> Hi, Owen
> Best regards,
> Alexandre Guimaraes
2005-07-12 by tonalbuilder2002
The number of despiking caps you need is affected by issues such as
how much current you are drawing from the pins to drive things like
led's and other low-impedance loads.  You might get away with less
than one cap on each power pin when the I/O pins are lightly loaded,
but for safety don't count on it.
I like empirical experimentation.  If you're interested in finding
out what's really needed set up a proto board with the kind of loads
you anticipate using, then start pulling off despiking caps until the
system gets erratic.
Bill T.
http://www.kueprcontrols.com
--- In lpc2000@yahoogroups.com, "Alexandre Guimaraes" <listas@l...>
wrote:
> Hi, Owen
Wouldn't it
> Best regards,
> Alexandre Guimaraes
> From: "Owen Mooney" <ojm@s...>
> > Owen
> > Hi, Owen
board ? It
LPC's.
> > Best regards,
> > Alexandre Guimaraes
> > Yahoo! Groups Links
2005-07-13 by Owen Mooney
Why number ?
A single 0.5 uf cap will do exactly the same job as 5 x 0.1 uf caps provided the distances remain short, and the capacitor ESR characteristics are the same.
Its not the number of capacitors but the capacitance and distance that matters. Capacitance and distance also have a relationship with frequency.
The choice for decoupling is multilayer ceramics becase of their low ESR at high frequencies. Someone correct me if I'm wrong, but I think the reason that designers scatter 0.1 caps every where, is that once that was the largest size available. You can now get them in up to 10uf size in 0805 packages.
I am only clocking at 14 MHz with no appreciable loads on the pins. I use a 0.1 cap under the micro and a 10 uf ceramic at the power supply nearby (about 3 cm). I examined the specs of the caps. The 10uF has an ESR of 1 ohm at 100Mhz, 0.15 at 10 Mhz. The addition of the 0.1 was just paranoia.
If you are driving leds etc Alexandre, use 1 or 10 uf ceramic caps in the same layout.
Don't forget that at 100Mz has a wavelength of 3m, so a short stub of about 3mm has very little ablity to radiate EMC. I think harmonics will drop off rapidly after 100 Mhz.
Owen Mooney
Bill T.
wrote:
>Hi, Owen
Wouldn't it
>Best regards,
>Alexandre Guimaraes
>----- Original Message -----
>>Owen
>>Hi, Owen
board ? It
LPC's.
>>Best regards,
>>Alexandre Guimaraes
RE: [lpc2000] Re: Two layer PCB and LPC2000 and EMC
2005-07-13 by Dan Beadle
In a perfect world, 5 x 0.1 uF caps = 1 x .5uF cap.  But that doesn't
take into consideration the inductance of the leads and the traces.
With a dedicated ground and power plane, the inductance is less of an
issue, but still comes into play.
This is the reason you don't simply put one 1000 uF cap on the board and
forget it.
Many designs require 0.01uf and 0.1 uf scatter across the board (one on
each Vcc pin).
  _____
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf
Of Owen Mooney
Sent: Wednesday, July 13, 2005 3:11 PM
To: lpc2000@yahoogroups.com
Why number ?
frequency.
in 0805 packages.
paranoia.
the same layout.
Owen Mooney
Bill T.
wrote:
>Hi, Owen
Wouldn't it
>Best regards,
>Alexandre Guimaraes
>>Owen
>>Hi, Owen
board ? It
LPC's.
>>Best regards,
>>Alexandre Guimaraes
  _____
YAHOO! GROUPS LINKS
*	 Visit your group "lpc2000
<http://groups.yahoo.com/group/lpc2000> " on the web.
*	 To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
  _____
2005-07-14 by Leon Heller
Sent: Wednesday, July 13, 2005 11:11 PM
> Why number ?
> are the same.
> 0805 packages.
> same layout.
It might only be 10 MHz, but the edges will be very sharp, resulting in odd
harmonics up into the VHF region, causing EMC problems. That is why several
smaller capacitors are best. They also have less inductance making them more
effective.
Leon
Checked by AVG Anti-Virus.
Version: 7.0.323 / Virus Database: 267.8.13/47 - Release Date: 12/07/2005
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
