Lpc2000
OT: SJA2020
OT: SJA2020
2005-07-13 by Gus
Does anyone have any information about SJA2020?
Gus
Re: OT: SJA2020
2005-07-13 by lpc2100_fan
> Gus
Gus,
this is not so much OT, after all the SDA2020 is a Philips ARM7
microcontroller.
The little things I know are:
- 6 CAN channels  (had the same problems as LPC2294 because it is the
same module)
- 4 UARTs with hardware LIN support
- 256k Flash
- 24k SRAM (not sure but it was more than 16k)
- available (if at all) in 144-pin only
This device is from a different group within Philips than the LPC2000
microcontrollers. Unfortunately there has not been a lot of
information about it and the other two rumors that I heared are:
1. device is significantly higher price than e.g. LPC2294
2. There will be new devices with more memory and CAN fixes from the
SDA20xx series out soon (whenever soon is).
My information is based on what Philips showed at the Embedded World
tradeshow in Nuremberg this spring.
Hope this helps a little, Bob
