2106 as a SPI slave
2005-07-15 by jay_pni
We are using the 2106 as a SPI slave device with CPOL = 0, CPHA = 0, MSB. We are able to always receive commands OK, but are having problems sending commands back. If the master provides the SCLK at too SLOW of a rate, the data from the 2106 is shifted to the left by 1 after the fist byte sent back. Having the master speed up the SCLK takes care of this problem and data sent from the 2106 on the MISO line is fine, however smaller processors are unable to provide a fast enough clock rate (bit banging). Other than the SPI registers, are there any other registers (powering off other peripherals not being used) that should be set? Thanks Jay
