Lpc2000
I want to use an I/O port to control an SPI clock and its data.
2005-07-25 by fangneu
Because my MCU has not enough SPI pins so I can only use I/O pins as
control SPI.But I'm not sure that the way of the IO pins simulate
SPI.Should I send a pluse(0),follow it send a datum then send another
pluse(1).At I/O port,I can only send a datum at the same time and can
not send a byte or two byte data?
Re: [lpc2000] I want to use an I/O port to control an SPI clock and its data.
2005-07-26 by Charles Manning
I will let you into a little secret of mine. I have been using SPI for over
ten years and have never used an SPI peripheral. I have always bit-banged the
SPI mastering. I will be changing that for a project I just started though,
because I need faster speed.
The easiest way to do this is to  the data sheet for the device you are
talking to and look at the timing diagrams.
