Lpc2000
FIQ tuning
FIQ tuning
2005-07-26 by 42Bastian Schick
while investigating the max. FIQ latency on a LPC2294 (other LPC should
be similar), I wrote following code which fits completly into the
vector table and allows a total of 7 (or 5 with synchronisation with
an RTOS or higher layer) instructions to be executed without a branch.
It uses vectaddr14 and vectaddr15 of the VIC to store the Abort and
Undefined Handler addresses.
I used EXTINT1 to trigger interrupts.
	.section .init,"ax"
         .align	2
         .code	32
	.extern	Undefined_Handler
	.extern Abort_Handler
	.extern Prefetch_Handler
	@ Start Vector
VectorTable:
Undefined_Addr:	.long Undefined_Handler // reset-vector, not used
	LDR	PC, Undefined_Addr
	LDR	PC, SWI_Addr
	LDR	PC, [pc,#-0xedc]	// Prefetch_Addr (0xfffff138, vectaddr14)
	LDR	PC, [pc,#-0xedc]	// Abort_Addr    (0xfffff13c, vectaddr15)
SWI_Addr:	.long sc_sysSWI		// reserved vector
	ldr     pc, [pc, #-0xff0]	// IRQ
	nop
	nop
	nop
	nop
	nop
** synchronise SCIOPTA world via soft irq every 32 FIQ
	adds	r8,r8,#0x08000000
       streq   r10,[r9,#0x18]		// _VIC_SOFTINT = 1
	str	r10,[r11,#0]		// EXTINT1
	subs	pc,lr,#4		// return to interrupted function
To extend this, more code has to be linked to the flash at 0x40.
The setup looks like this:
	MSR	cpsr_c,#PSR_FIQ_MODE|PSR_I_BIT|PSR_F_BIT
       ldr     r13,=0xe0028000	    // no FIQ stack,so r13 is GP register
       mov     r12,#0x104          // scrath registers
	ldr	r11,=0xe01fc140		// EXTINT
	mov	r10,#2			// EINT1
	mvn	r9,#0
	mov	r9,r9,lsl #12		// r9 = VIC-base == 0xfffff000
	mov	r8,#0				// used to synchronize
	mov	r1,#0x4000
	str	r1,[r9,#0x0c]		// EINT1 == FIQ
	str	r1,[r9,#0x10]           // enable EINT1
	ldr	r1,=Prefetch_Handler
	str	r1,[r9,#0x138]
	ldr	r1,=Abort_Handler
	str	r1,[r9,#0x13c]
Ah, and I found a latency of max. 400ns (VPB == CPU == 60MHz),
which is 24 cycles. Strangely I found a jitter of 50ns even if nothing
else is running.
42Bastian Schick
