Lpc2000
GPIO output voltage
GPIO output voltage
2005-09-20 by vineet jain
Hello,
  Can I connect any TTL chip working at 5V to the LPC2104 GPIO's???
Vineet.
Do You Yahoo!?
http://mail.yahoo.com
Re: GPIO output voltage
2005-09-20 by fbpmania
--- In lpc2000@yahoogroups.com, vineet jain <vineetrvce@y...> wrote:
> Hello,
> Regards,
> Vineet.
> Do You Yahoo!?
Hello Vineet,
this depends on your TTL Chip.
Check your Datasheet what your IC will interprete als "high". There is
always a min. Voltage given.
Greetings.
2005-09-20 by Karl Olsen
> Hello,
Chips that use TTL levels can be connected directly.
Karl Olsen
Re: [lpc2000] Re: GPIO output voltage
2005-09-20 by Blagoj Kupev
Be aware that external TTL chip has to be powered from +5V. You can use
74HCT versions without any problem.
This way you can connect GPIO's only if it is configured as output
(connected to 74HCT input), but if you want to use TTL output connected
to GPIO configured as input, check if your processor has 5V tolerant inputs.
BR,
Blagoj Kupev
Na 20.09.2005 12:04 Karl Olsen rece:
>>Hello,
>Karl Olsen
>Yahoo! Groups Links
>__________ NOD32 1.1224 (20050920) Information __________
>This message was checked by NOD32 antivirus system.
>http://www.eset.com
