Lpc2000
SPI Interrupt not firing?
2005-10-11 by ee_gary
Long time lurker, first time poster...
I've set the SPIE bit in the Control Register.  I can see the SPIF bit
get set in the Status Register.  However, I do NOT see the SPI
Interrupt bit get set in the Interrupt Register.  Shouldn't this occur
as soon as the SPIF bit is set, regardless of how the VIC is set up?
I have the VIC set up "correctly", but the ISR never executes
(presumably because the SPI Interrupt never fires).  I've had
interrupts working correctly for UART0 and a timer, so I know that
interrupts can work (they just aren't in this occasion).
I can do non-interrupt SPI transmits (i.e. the 1st byte of an
interrupt-based multibye transfer) so I know the hardware is ok (SSEL
= 1).  I've duplicated this on the MCB2130 and a LPC2214 dev board.
Any insight from those that have implemented interrupt based SPI is
appreciated.
Stumped in Seattle...
Re: [lpc2000] SPI Interrupt not firing?
2005-10-12 by Sten
> appreciated.
Please can you send a small portion of source code? It sounds unbelievable.
  Sten
 Do you need a tiny and efficient real time
 operating system (RTOS) with a preemtive
 multitasking for LPC2000 or AT91SAM7?
   http://nanortos.net-attack.de/
 Or some open-source tools and code for LPC2000?
   http://www.net-attack.de/
Re: SPI Interrupt not firing?
2005-10-12 by ee_gary
> > appreciated.
unbelievable.
>   Sten
It'd be my pleasure.  Here's the init function:
void spi0Init(void)
  // Set port pins for SPI0
  PINSEL0 = (PINSEL0 & ~S0_PINMASK) | S0_PINSEL;
  // Set SPI Registers
  S0SPCR = 0;           // Clear all bits
  S0SPCR |= SPCR_CPHA;  // Data sampled on rising edge
  S0SPCR |= SPCR_CPOL;	// SCK active low
  S0SPCR |= SPCR_MSTR;	// Master mode
  S0SPSR;         // Cleared by a read of this register
  S0SPDR;         // Cleared by a read of this register
  S0SPCCR = 128;  // 8 is max speed
  S0SPINT = 1;    // Cleared by writing a 1 to it
  // initialize the interrupt vector
  VICIntSelect = 0;  // Select IRQ
  VICIntEnable = 0x00000400;
  VICVectAddr0 = (unsigned long)spi0ISR;
  VICVectCntl0 = 0x0000002A;
  // initialize the transmit data queue
  spi0_tx_extract_idx = spi0_tx_insert_idx = 0;
  spi0_tx_running = 0;
and the transmit function:
int spi0Putch(int ch)
  uint16_t temp;
  unsigned cpsr;
  temp = (spi0_tx_insert_idx + 1) % SPI0_TX_BUFFER_SIZE;
  if (temp == spi0_tx_extract_idx)
    return -1;                          // no room
  cpsr = disableIRQ();                  // disable global interrupts
  S0SPCR &= ~SPCR_SPIE;                 // disable TX interrupts
  restoreIRQ(cpsr);                     // restore global interrupts
  // check if in process of sending data
  if (spi0_tx_running){
    // add to queue
    spi0_tx_buffer[spi0_tx_insert_idx] = (uint8_t)ch;
    spi0_tx_insert_idx = temp;
  else{
    // set running flag and write to output register
    spi0_tx_running = 1;
    S0SPDR = (uint8_t)ch;
  S0SPCR |= SPCR_SPIE;                  // enable TX interrupts
  return (uint8_t)ch;
and finally, the ISR that never fires...
void spi0ISR(void)
  // perform proper ISR entry so thumb-interwork works properly
  ISR_ENTRY();
  // check if more data to send
  if (spi0_tx_insert_idx != spi0_tx_extract_idx){
    S0SPDR = spi0_tx_buffer[spi0_tx_extract_idx++];
    spi0_tx_extract_idx %= SPI0_TX_BUFFER_SIZE;
  else{ // No more to transmit
  S0SPINT = 1;
  VICVectAddr = 0x00000000;
  ISR_EXIT();
It seems like it should be something simple.  Everything looks okay,
but the ISR never fires.
Gary
RE: SPI Interrupt not firing?
2005-10-12 by wdimitroff@netbg.com
This is from the LPC2106 errata sheet:
         SPI.1Unintentional clearing of SPI interrupt flagIntroduction:
The SPI interrupt flag is set by the SPI interface to generate an interrupt. It is cleared by writing a 1 to this bit.
         Problem:A write to any register associated with the SPI peripheral will clear the SPI interrupt register.
         work-around:Avoid writing to SPI registers while transmissions are in progress or while SPI interrupts are pending
2005-10-12 by drb5599
I believe you Gary.  I had the same problem.  I have been using the
MCB2130 (2138) and LPC2131 (my hardware).  I finally gave up on the
SPI interrupt and now just use polling.  Not very efficient, but in
my application it is acceptable.
Strange thing to me was the fact that it is just the SPI interrupt
that has caused problems.  I have been able to configure and use
every other interrupt available, no problem.
-Dave
--- In lpc2000@yahoogroups.com, "ee_gary" <ee_gary@y...> wrote:
SPIF bit
this occur
set up?
that
(SSEL
board.
SPI is
> > > appreciated.
> unbelievable.
> >   Sten
> void spi0Init(void)
>   uint16_t temp;
>   unsigned cpsr;
>     // add to queue
>   else{
>   return (uint8_t)ch;
> void spi0ISR(void)
>   ISR_ENTRY();
>   S0SPINT = 1;
>   ISR_EXIT();
> Thanks,
> Gary
Re: [lpc2000] Re: SPI Interrupt not firing?
2005-10-12 by Richard Duits
Same experience here. Tried to do the interrupt thing, now I just start
the SPI transfer, do some other stuff and then poll until the transfer
is ready. Is there anybody that has used the SPI interrupt successfully???
Richard Duits.
> -Dave
> SPIF bit
> this occur
> set up?
> that
> (SSEL
> board.
> SPI is
> > > > appreciated.
> > unbelievable.
> > >   Sten
> > void spi0Init(void)
> >   uint16_t temp;
> >   unsigned cpsr;
> >     // add to queue
> >   else{
> >   return (uint8_t)ch;
> > void spi0ISR(void)
> >   ISR_ENTRY();
> >   S0SPINT = 1;
> >   ISR_EXIT();
> > Thanks,
> > Gary
> SPONSORED LINKS
> Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>
> 	Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>
> 	Pic microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
> 8051 microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
I've been able to configure and use the uart and timer interrupts no
problem.  That's why this SPI interrupt not firing has me so stumped.
Gary
> -Dave
> SPIF bit
> this occur
> set up?
> that
> (SSEL
> board.
> SPI is
> > > > appreciated.
> > unbelievable.
> > >   Sten
> > void spi0Init(void)
> >   uint16_t temp;
> >   unsigned cpsr;
> >     // add to queue
> >   else{
> >   return (uint8_t)ch;
> > void spi0ISR(void)
> >   ISR_ENTRY();
> >   S0SPINT = 1;
> >   ISR_EXIT();
> > Thanks,
> > Gary
RE: [lpc2000] Re: SPI Interrupt not firing?
2005-10-13 by Bruce Paterson
> just start the SPI transfer, do some other stuff and then
> poll until the transfer is ready. Is there anybody that has
I use SPI interrupts for SPI transactions and haven't run into any
issues as yet.
Mind you it's on a lpc2124, not an lpc2138. My SPI module is part of the
lpc newlib extensions.
> Richard Duits.
> efficient, but in my
> and use every
> > -Dave
> > SPIF bit
> see the SPI
> > this occur
> > set up?
> > that
> hardware is ok
> > (SSEL
> > board.
> > SPI is
> > > > > appreciated.
> > > unbelievable.
> > > >   Sten
> > > >  Do you need a tiny and efficient real time  operating system
> > > > (RTOS) with a preemtive  multitasking for LPC2000 or AT91SAM7?
> > > void spi0Init(void)
> > >   uint16_t temp;
> > >   unsigned cpsr;
> interrupts
> interrupts
> > >     // add to queue
> > >   else{
> interrupts
> interrupts
> > >   return (uint8_t)ch;
> > > void spi0ISR(void)
> > >   ISR_ENTRY();
> > >   S0SPINT = 1;
> > >   ISR_EXIT();
> looks okay,
> > > Thanks,
> > > Gary
> > SPONSORED LINKS
> > Microprocessor
ocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051>
> > 	Microcontrollers
processor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051>
> > 8051 microprocessor
> > YAHOO! GROUPS LINKS
> --------------------~--> Get Bzzzy! (real tools to help you
> find a job). Welcome to the Sweet Life.
> http://us.click.yahoo.com/A77XvD/vlQLAA/TtwFAA/dN_tlB/TM
2005-10-13 by David Hawkins
> issues as yet. Mind you it's on a lpc2124, not an lpc2138. My SPI
> module is part of the lpc newlib extensions.
Hey Bruce,
Care to enlighten me about that last comment.
I've been meaning to go through the newlib re-entrancy configuration
etc to see what needs to be turned on for uCOS-II thread-safe usage,
and to create some sort of device operations table interface
(as per Bill Gatliff's docs from Embedded Systems Programming).
I saw a post the other day from someone at Aeolus regarding their
newlib port layer (perhaps that was you)
http://www.aeolusdevelopment.com/Articles/download.html
anyways, if you have a nice clean way of implementing a device
layer, let us know and people can contribute with a common
interface.
Cheers
Dave
> > > start the SPI transfer, do some other stuff and then poll
> until the
> > > transfer is ready. Is there anybody that has used the SPI
> interrupt
> > > successfully???
> Hey Bruce,
> configuration etc to see what needs to be turned on for
> uCOS-II thread-safe usage, and to create some sort of device
> operations table interface (as per Bill Gatliff's docs from
> their newlib port layer (perhaps that was you)
> device layer, let us know and people can contribute with a
> common interface.
No it wasn't me. It was the Robert Ansett, the compiler of newlib_lpc.
I'm not sure if he has rolled my SPI module into his latest newlib_lpc
release as yet, but if necessary I can email it to you.
Yes, it is good to conform to a common interface, and due to other
newlib_lpc modules being available it significantly cut down my overall
effort, even though I coded the SPI, and added some zero-copy options to
the the uart modules.
The easiest way to code a new module is to copy an existing one and
modify the bottom end. In this way I have also created an IIC module,
but haven't had a chance to test as yet. Robert also has a copy of that,
but beware it is probably buggy.
Bruce
> > Care to enlighten me about that last comment....
> >  <snip>
> Cheers,
> Bruce
Great, thanks for the feedback. Perhaps I'll get to play with this
stuff over the weekend and get to look at Robert's stuff.
Cheers
Dave
2005-10-13 by Robert Adsett
At 12:52 PM 10/13/05 +1000, Bruce Paterson wrote:
> > Hey Bruce,
> > common interface.
It was probably my post you saw David.  And I haven't rolled Bruce's stuff
in yet.  I've been distracted with clients work.  It is high on my todo
list as well as a way to allow contributed code out in the wild more
quickly especially drivers so they don't get stalled like this.  It'll
probably be simple but I have to actually get it done.
I haven't explicitly addressed re-entrancy but I did try to structure
things so it could be taken care of in the future.  As far as how
successful that's been well the proof of the pudding will be in the eating.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
Hey Robert,
> Bruce's stuff
> the eating.
If I get a chance to look at it, and can either contribute bug
fixes, or new drivers, I will.
I haven't looked at your driver layer, but out of interest, what
did you base it on? I've got an Altera Stratix II DSP kit, and
the Altera NIOS II development software comes with a nice driver
layer for newlib and their HAL, which is then interfaced to uCOS-II.
There is also an eCOS port for the NIOS II processor, but I'm not
sure if the HAL used there is identical. I've only just started
tinkering with that kit - problem was you need an FPGA implementation
of the processor before you can even start, and it was
missing from their 1.0.0 CD! I've just received the 1.1.0 CD and
the 'standard' processor reference design is there.
Seems like newlib has a new driver layer ported to every
time someone decides it needs one. I just want one layer
thats fairly processor agnositic (ie a HAL) so that I can run
similar application tests on the various processor to
see what meets my needs.
Thanks!
Dave
Hey Robert,
> restrictions,   be
or 'look through a radio telescope'
people are always disappointed when they find out that they can't.
www.mmarray.org
www.ovro.caltech.edu
Cheers
Dave
Senior Scientist
Caltech's Owens Valley Radio Observatory.
2005-10-14 by ee_gary
--- In lpc2000@yahoogroups.com, "Bruce Paterson" <bruce.paterson@b...>
> > until the
> > interrupt
> > > > successfully???
> > Hey Bruce,
> > common interface.
> Cheers,
> Bruce
I'd be interested in the newlib_lpc SPI module as well (interrupt
driven, of couse).
Gary
2005-10-17 by Guillermo Prandi
I'm a newbie, so don't take my comment too seriously, but... why are
you disabling SPIE interrupts in your enqueue function? Couldn't this
adversedly affect the expected behavior? If your intention is to
protect the buffer pointers while these are being updated, I'd go for
a full IRQ disable rather than a targeted masking; of course this is
acceptable only if you can afford a small lag between interrupts.
Also, as I read the pseudo-code example in the LPC2138 user's manual,
the SPI control register should be written to before writing onto the
data register (which in some way may suggest that it should not be
written to after the data is set in the shift register). Yhis is what
I'd do:
uint16_t temp;
unsigned cpsr;
cpsr = disableIRQ(); // disable global interrupts before atempting to
read spi0_tx_insert_idx (in case of multitasking being used)
// Avoid using modulo operator in ARM7 for performance reasons
//temp = (spi0_tx_insert_idx + 1) % SPI0_TX_BUFFER_SIZE;
temp = spi0_tx_insert_idx + 1;
if( temp == SPI0_TX_BUFFER_SIZE ) temp = 0;
  // add to queue
else{
  S0SPCR |= SPCR_SPIE; // enable TX interrupts before writing to
SOSPDR
return (uint8_t)ch;
Hope this helps.
Guille
SPIF bit
this occur
set up?
that
(SSEL
board.
SPI is
> > > appreciated.
> unbelievable.
> >   Sten
> void spi0Init(void)
>   uint16_t temp;
>   unsigned cpsr;
>     // add to queue
>   else{
>   return (uint8_t)ch;
> void spi0ISR(void)
>   ISR_ENTRY();
>   S0SPINT = 1;
>   ISR_EXIT();
> Thanks,
> Gary
