Lpc2000
flashing an elf-file to internal Flash
2005-10-17 by Klaus
I am downloading an elffile to the internal Flash. I write the
sections with IAP. So far everything works. But after reset, the
program doesnt start. I set the valid User Code Signature and i
reserve the top 32 bytes of the internal Ram. Has anybody experience
with that topic or a clue, what could go wrong?
Thanks in advance, Klaus
Re: flashing an elf-file to internal Flash
2005-10-17 by bdmlpc
Hello Klaus,
if you have a bootloader flash tool you can check at UART0 if you can
connect with that tool after RUN command to your bootloader without
asserting P0.14 and /Reset. If your bootloader responses your user
signature is wrong.
Another solution is to start the IC and stop it with your JTAG tools
to see "where" it is running. Check if this address is in bootloader
section or in user code (maybe bad exception).
  Sten
Re: [lpc2000] flashing an elf-file to internal Flash
2005-10-18 by Alexandre PETIT
During the reset, you would like to verify the state of pins which give the boot mode : internal flash, external peripherical on CS0 or other.
good luck
Alexandre
  To: lpc2000@yahoogroups.com
  Sent: Monday, October 17, 2005 3:25 PM
  Subject: [lpc2000] flashing an elf-file to internal Flash
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2005-10-18 by Tom Walsh
Alexandre PETIT wrote:
>Hi,
yeah, this got me too.  I misread the user manual of the LPC2xxx and had
a pullup on the wrong pin.  The LPC2xxx processors don't have internal
pullup resistors.  You have to make sure that P0.14 is pulled high with
something like a 10K resistor.
TomW
>good luck
>Alexandre
>  ----- Original Message -----
>  From: Klaus
>  YAHOO! GROUPS LINKS
>Yahoo! Groups Links
