MOTM
Re: [motm] Passive footpedal control? - Cable Attenuator Tip
2002-06-11 by elhardt@aol.com
ixqy@... writes:
>>I'm getting ready to do some recording (needed by tonight) and thougt I'd
ask the list this question... Is there anyway to use my Yamaha FC-7
(sweepable & passive) footpedal as a modulation signal attentuator?<<
Yes, but it would be rather messy.  You'd need a couple of 1/4" cables and a
bunch of alligator clips that won't easily slip off the 1/4" connectors, and
you'd hook up the FC-7 and maybe another resistor in the proper way inbetween
the two cables so you could attenuate the voltage with the pedal.  Or look
around your setup for a battery operated pedal and you can hook it up
anywhere without the 850.  My battery powered Moog pedal works great.  No
longer needed since I just built my 850 over the weekend.
Along similar lines.  If you're like me, you've been frustrated when using
the oscillator FM input for vibrato (modulation from LFO).  It is so
sensitive that you have to work between the first and second knob tick marks,
and it's back and forth with either too much or too little vibrato, not to
mention trying to get the same amount on several oscillators running at once.
 A while back I made up a cable with a couple resistors built in as a voltage
divider to chop a signal in half.  I'm about to make up some similar cables
to divide a signal by 10.  Now I can use half the movement of the FM knob
with fine control.  No need to waste mixers as attenuators or to do permanent
oscillator mods since you may need the original range for other uses.
-Elhardt
2002-06-11 by ixqy@aol.com
Hi Ken,
 I really wanted to have some real time control that a pedal would have given
me, but I was a little short on time to fix something up. I should've planned
ahead! ; )  I wound up using the S&H out (with Slew) from my MOTM-101 to add
a some random changes to the Osc sync patch that I had going. It wasn't
ideal, but it worked out pretty well overall. It turned out to be a nice,
expressive patch.
 Thanks for the cable attentuator tip as well. I used my Expressionist to
play the MOTM, and the LFO intensity on it can be set to a very usuable
level. I'll keep the cable trick in mind though, it may come in handy with
other mod routings.
 Thanks again,
   Andrew
In a message dated 6/10/02 10:24:58 PM Central Daylight Time, elhardt@...
writes:
a
and
> inbetween
marks,
once.
> voltage
cables
> permanent
>  -Elhardt
