MOTM
Re: Main Output Mix
Re: Main Output Mix
2003-07-12 by paulhaneberg
When recording I always record everything on individual tracks,
usually in stereo, sometimes when I want a really fat sound I'll
record a sound several times and combine them later in the mix.
When just fooling around I use the 830 mixers.
At present I am using a number of cables I made up special with 20db
attenuators built in to drop the output level.  Without those the
MOTM overdrives my Avalon even with the pads in and the gain all the
way down.  I am building an output module (stooge panel on order :))
which will have the attenuation built in as well as a master volume
and balanced line outputs.
As a system grows the need for mixer modules seems to increase
exponentially.
