MOTM
Echoes revisited
Echoes revisited
2000-05-03 by james holloway
I'm thinking of buying either a Vox echo unit or an Echoplex unit. even the
Roland may be a possibility. Any one of the learned minds out there have an
opinion as to which would be better or are they both about the same? I want
the old analog (tape loop) type of effect. Also how much would be a fair
price?
Thanks.
________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
RE: [motm] Echoes revisited
2000-05-03 by Dave Bradley
The Roland kicked butt. I had an RE-201 for years, wish I still did. It is
much more hi-fi than the echoplex, and had a much longer length tape which
lasted longer. I think the echoplex could do longer delays, however, cause
you could move the head farther from the record head. The Roland also had a
spring verb unit as a bonus.
Be careful buying an old mechanical tape unit - the heads are probably no
longer replaceable, and you'll have to make your own tapes when they need
replacement. Use a tape with a heavy backing.
I'm not familiar with the Vox, so I can't speak about it.
Dave Bradley
Principal Software Engineer
Engineering Animation, Inc.
daveb@...
> From: james holloway [mailto:jimh54@...]
> Sent: Wednesday, May 03, 2000 8:40 AM
> To: motm@egroups.com
> Subject: [motm] Echoes revisited
> unit. even the
> there have an
> same? I want
> price?
> Thanks.
Re: [motm] Echoes revisited
2000-05-03 by Charles Stella
I would also recommend the Roland units. I currently have an RE-201 and
an SRE-555. There is really nothing like them. Far more versatile than
an Echoplex. Than Roland line breaks down more or less like this:
1. RE-101 First unit introduced. Six different echo modes. 3 single and
3 with feedback.
2. RE-201 Like the 101 but with spring reverb.
3. RE-301 Includes all the above plus a BBD chorus. Footpedal control of
tape speed.
4. RE-501 All the above plus Sound on Sound and Balanced I/O. Companding
for Noise reduction.
5. SRE-555 Identical to the 501 but rack mountable. Weighs a ton!
6. RE-150 Similar to the 101 but produced later. Mostly IC design.
As david mentioned be careful when purchasing. Due to the mechanical
nature machine condition can vary enormously. Try before you buy if at
all possible. You often see these units on Ebay and they can get quite
expensive. Check local vintage guitar shops as well. Prices seem to
range from about $200.00 to $800 depending on model and condition. I
have the Manuals and service docs for all units should you or any other
person on this list ever need them. Feel free to email me privately if
you have more questions. Also check this link at Music Machines for more
info. Music Machines: Roland/effects . Charles.
> It is
> which
> cause
> had a
> no
> need
> Dave Bradley
> daveb@...
> > unit. even the
> > there have an
> > same? I want
> fair
> > price?
> > Thanks.
