MOTM
FW: [motm] Re: Please proofread this!
2001-01-08 by Tkacs, Ken
It's not 15 because you can't use the switching jacks in that configuration;
if you did, it would break the normalization down and you would have a 4x4.
Make sense?
To: motm@egroups.com
Sent: 01/07/2001 9:29 PM
Subject: [motm] Re: Please proofread this!
h3y,
i concur  with chaz, however, couple quick questions.
under the 410, should "vocal formants" be changed to "tunable to
vocal formants"?
under 820, 4th bullet, should that be "bypass: switch or remote"?
using the colon symbol to denote either/or?
on the 910:  there are 16 plugs, so would it not be 1 in - 15 out,
dual 1 in - 7 out, dual 1 in - 3 out and 1 in - 7 out?  or did i miss
somethin' in my math?
on the 940: should "passive modules" be singular?  so it's "passive
module, requires no power"
peace,
doc
--- In motm@egroups.com, imorpheusl@a... wrote:
> minor errors:
> -the MOTM410 description has a wording error (I think): When the
same
> old.......the MOTM 410 makes your track stand out. I think it
should be  "the
> MOTM 410 will make your track stand out" (this is just a wording
thing...I
> think I'm right)
> -the dimensions on the motm 700 bullet list (bullet #7) is one
space to the
> right of       the bullet, but none of the other model descriptions
are like
> this
> - I belive "useage" on the 800 description should be spelled usage
(bullet #6)
> - the motm 910's description has an error:  "1in" should be "1 in"
(bullet #2)
> -Chaz
> [morpheus]
2001-01-08 by doc pendergast
oh,
duh!  i should eat before i proof, what was i thinkin'.  thanks ken...
peace,
doc(who is makin' sustenance now)
configuration;
have a 4x4.
> Make sense?
