[motm] Possible 410 Triple Filter add on module
2001-01-29 by elhardt@aol.com
Going from memory, Paul said that changing one resistor (per channel) would allow a person to change the amount of resonance on the 410 triple filter module. How about a 1U module with 3 knobs to control the amount of resonance. The wires that attach the pots from the add on module could have a connector in the middle for easy separation. It's a no-brainer design, just needs a professional looking panel. -Elhardt
2001-01-29 by Paul Schreiber
Nit so (read the theory section). It's set by the ratio of 2 capacitors. Paul S. ----- Original Message ----- From: <elhardt@...> To: <motm@yahoogroups.com> Sent: Sunday, January 28, 2001 6:10 PM Subject: [motm] Possible 410 Triple Filter add on module > Going from memory, Paul said that changing one resistor (per channel) would > allow a person to change the amount of resonance on the 410 triple filter > module. How about a 1U module with 3 knobs to control the amount of > resonance. The wires that attach the pots from the add on module could have
> a connector in the middle for easy separation. It's a no-brainer design, > just needs a professional looking panel. > > -Elhardt > > > >
2001-01-29 by Cary Roberts
>Nit so (read the theory section). It's set by the ratio of 2 capacitors. > >> Going from memory, Paul said that changing one resistor (per channel) >would >> allow a person to change the amount of resonance on the 410 triple filter >> module. How about a 1U module with 3 knobs to control the amount of >> resonance. The wires that attach the pots from the add on module could >have >> a connector in the middle for easy separation. It's a no-brainer design, >> just needs a professional looking panel. I had a blast with the Technosaurus modular at NAMM because of the triple resonant filter in it. The unit features multiple audio inputs, seperate frequency, level, Q, and fm amounts per band, and three fm seperate inputs to the cutoff frequency. No offense to the MOTM-410, but this module rocks! Of course, to put the same features in a MOTM module it'd be 4U wide. http://www.technosaurus.ch/modules/tres.htm -Cary
2001-01-29 by jhaible@t-online.de
> I had a blast with the Technosaurus modular at NAMM because of > the triple resonant filter in it. The unit features multiple audio > inputs, seperate frequency, level, Q, and fm amounts per band, > and three fm seperate inputs to the cutoff frequency. No offense > to the MOTM-410, but this module rocks! Of course, to put the > same features in a MOTM module it'd be 4U wide. To offer a different point of view, parametric equalizers (or similar filters) surely have their use (I'm glad my mixing desk has semi parametric bands), but you wouldn't really want to convert a carefully optimized musical filter into just one more of these. It's really two different things completely - I doubt these modules have much more in common than a similar name. JH.
cary.roberts@... writes: >>I had a blast with the Technosaurus modular at NAMM because of the triple resonant filter in it. The unit features multiple audio inputs, seperate frequency, level, Q, and fm amounts per band, and three fm seperate inputs to the cutoff frequency. No offense to the MOTM-410, but this module rocks! Of course, to put the same features in a MOTM module it'd be 4U wide. http://www.technosaurus.ch/modules/tres.htm<< I was mentioning the same thing on AH a few weeks back. I was considering getting a couple of them especially after seeing the 15% off sale Technosaurus was having and calculating the price, they seemed reasonable. But then came the info about odd operating voltages and Mickey's (form Drummachine.com) price was considerably higher. The Doepfer version is also just about as flexible but I don't have room for a second one. I might order a second MOTM anyway, but it would be nice to see some kind of future MOTM module that is good for general tone altering and setting up formants. -Elhardt
jhaible@... writes: >>To offer a different point of view, parametric equalizers (or similar filters) surely have their use (I'm glad my mixing desk has semi parametric bands), but you wouldn't really want to convert a carefully optimized musical filter into just one more of these. It's really two different things completely - I doubt these modules have much more in common than a similar name.<< I won't be caught without a parametric EQ next to my synth. They are great for fine tuning. But triple bandpass filters and fixed filter banks are better for drastic sound changes. In fact, the Polyfusion modular had both a 3 band Variable Formant Filter (freq, Q, level) and a 5 band Parametric EQ module. None of the parameters were voltage controllable though. -Elhardt
2001-01-29 by mate_stubb@yahoo.com
So what's the difference? Parametric cuts and boosts, formant only passes the bands? Moe --- In motm@y..., elhardt@a... wrote: > I won't be caught without a parametric EQ next to my synth. They are great > for fine tuning. But triple bandpass filters and fixed filter banks are > better for drastic sound changes. In fact, the Polyfusion modular had both a > 3 band Variable Formant Filter (freq, Q, level) and a 5 band Parametric EQ
> module. None of the parameters were voltage controllable though. > > -Elhardt
>To offer a different point of view, parametric equalizers (or similar >filters) surely have their use (I'm glad my mixing desk has semi parametric >bands), but you wouldn't really want to convert a carefully optimized >musical filter into just one more of these. > >It's really two different things completely - I doubt these modules have >much more in common than a similar name. Huh?? The Technosaurus triple resonant filter is not an simple EQ. It's a resonant VCF x 3. So it's like using several VCFs in parallel. Each band has it's own CV input so you can do cool things like using different rate LFOs (kinda like the 410), or EGs, or audio rate VCOs as modulation sources. If it were just a parametric EQ I'd be yawning, as I have good EQ on my console as well as outboard. Multiple filters are cool. Especially when you start mixing them in parallel and in series. -Cary
mate_stubb@... writes: >>So what's the difference? Parametric cuts and boosts, formant only passes the bands?<< That's basically it. The formant bank can totally cut out chunks of the sound spectrum or just allow one or more single bands of sound to pass through, however you want to think of it. The Parametric as you say just allows you to cut and boost bands by small amounts like +/-12db. -Elhardt
> >To offer a different point of view, parametric equalizers (or similar > >filters) surely have their use (I'm glad my mixing desk has semi parametric > >bands), but you wouldn't really want to convert a carefully optimized > >musical filter into just one more of these. > > > >It's really two different things completely - I doubt these modules have > >much more in common than a similar name. > > Huh?? The Technosaurus triple resonant filter is not an simple > EQ. It's a resonant VCF x 3. So it's like using several VCFs in > parallel. Each band has it's own CV input so you can do cool things > like using different rate LFOs (kinda like the 410), or EGs, or audio > rate VCOs as modulation sources. If it were just a parametric > EQ I'd be yawning, as I have good EQ on my console as well as > outboard. Multiple filters are cool. Especially when you start > mixing them in parallel and in series. Ok. There is a difference between a parametric EQ and the Technosaurus filter, there is a difference between the Technosaurus filter and the MOTM 410, and there is a difference between the MOTM 410 and a phaser. A phaser ? Yes, a 6-stage phaser has 3 resonant peaks which are controlled by one Feedback or Resonance control. Which is a nice feature just as it is, and people rarely complain that they cannot control each peak individually in a phaser. (There's a whole more circuit parameters that give different 6-stage phasers a different sound, such as FETs, Vactrols, OTAs, transistor ladders etc. You get the idea.) The MOTM-410 has a single Resonance knob like a phaser, but you can individually position the peaks on the frequency axis. Internally, it's not built like a phaser, and not like a parametric EQ or VCF either. (It uses an optoelectronic control that is responsible for the smooth sound of some phasers, however.) So I really think comparing the 410 with paremetric EQs (or parametric BPFs which are quite similar, circuit wise) is comparing apples and oranges. IMO, parametric VCFs or EQs are very much on the "perfect control - multi parameter" side, while (resonant) phasers are on the very opposite side where a certain "character" is designed-in and the user is offered a limited, ergonomic interface. And I'd place the 410 somewhere in between these extremes. Best of both worlds if you like, or at least a deliberate choice to place it where it is. That's what I wanted to say with short words - it's different, and you would loose something if you wanted to change it in either direction. The smoothness of optoelectronic control and the precision of fully parametric stuff would not fit nicely together - at least I don't see how they could. I hope it came thru better this time (;->) JH.
