Subject: [xl7] Re: Suggested Carrying Cases?
Why not just buy one of the mp7 emu bags?????
--- In xl7@yahoogroups.com, "vibesart" <edmann@p...> wrote:
> Recommendation based on my own experience: the Rubbermaid (and
other)
> Tuff-Tote type plastic molded cases + some good foam. Get the
> "hardware grade" type that you find in places like Home Depot - they
> have a reinforced double layer lid - super tough sculpted-molded
body.
> I have used this type of case for sensitive electronics many times
> including flights all over Europe and the US - never a problem - the
> cases cost about $20, and if for some reason your gear does not fit
as
> expected - you can return it locally. The 2 that I have here hold
> XL-7 perfectly - with about 3" on either side which I stuff with
> modular blocks of 3" high quality rigid case-foam. I also put
blocks
> of the foam above and below the XL7, and there is room on the bottom
> for wires, etc.
Yahoo! Groups Links
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of , or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
