midi remote control
midi remote control
2005-02-20 by totaim23
hi!
i've waste a lot of time trying to configut=re my mp7 to control
reason or greater, but that was vain.
Please somebody tell me how thats possible.
does reason learn from mp7 midi input or do i have to configure all
singles channels and how<????
pleaaaase HELP
CHEARS
Re: midi remote control
2005-02-20 by malik
im running linux at the moment so i cant tell you exactly how but you
can set up reason to midi learn. you can right click on a a parameter
in almost any device and select the oertaining option and i think the
option to select one or all devices is in the menu. i cant show you
now tho maybe when i install reason again on my fresh partition or use
xwin here:)
--- In xl7@yahoogroups.com, "totaim23" <totaim23@y...> wrote:
> hi!
> pleaaaase HELP
> CHEARS
Re: [xl7] midi remote control
2005-02-20 by Mibrilane
On Feb 20, 2005, at 6:56 AM, totaim23 wrote:
> hi!
> pleaaaase HELP
> CHEARS
Just download the Reason instrument multi-setups from the group's files
section:
http://launch.groups.yahoo.com/group/xl7/files/
Command%20Station%20Data/Soft%20Synth%20Multisetups/
Multi-setups configure the general setup of the knobs, the MIDI setup,
the effects structure of the instrument, etc. Load these into your MP-7
using a sys-ex dump and use the "Restore Multisetup" function (first
thing in the Global menu) to make each one active.
Mibrilane
2005-02-20 by malik
niiiiiiiiiiiiiiice
files
> section:
setup,
MP-7
(first
> Mibrilane
2005-02-25 by totaim23
thanx a LOT LOT LOT!
and other question is it possible to control live and fruity too???---
 In xl7@yahoogroups.com, "malik" <malik_martin@h...> wrote:
> niiiiiiiiiiiiiiice
> files
> > section:
> setup,
your
> MP-7
> (first
> > Mibrilane
2005-02-26 by malik
fruity has a midi learn function called auto accept controller what i
plan on doing is putting a freuity send plug on the end of 16 fx
channels and mapping each channel to the mp-7 and saving that as a
templat ein fruity and mp-7
if i do it i can send the files to you if you'd like.
> > niiiiiiiiiiiiiiice
> > files
> > > section:
> > setup,
> your
> > MP-7
> > (first
> > > Mibrilane
2005-02-26 by malik
oh yea i can only do it this way cause i have the fruityloops edition
and not producer.
as for live, i havent installed it since i formated the comp.
