patchcord destinations
2005-09-08 by mike_melon
do any of them generate midi CC data? for example would lfo >
keysustain send midi CC 64 would sine wave > midi controller P output a
controller stream for an external synth?
Wishful thinking probably
Mike
Re: patchcord destinations
2005-09-08 by malik
was wondering the same thing. i hope we get an answer!!
output a
> Mike
2005-09-08 by piaziker
They indeed do : I used to have my XL-7 to control my PC based
Emulator X, and it's very fine. (though I'm using a BCR-2000 now).
Set the CC data for the knobs in the setup you want, and voila.
the best thing is to creat a "MIDI" setup to load quickly so you can
discard it when you do not need it.
Piaz
> output a
> > Mike
2005-09-09 by steve_the_composer
(1) Several thoughts on this most worthwhile thread.
Think of the command stations/P2500 in terms of separate but
interrelated systems, especially (as concerns the original question):
--(a) the sequencer
--(b) the synth engine
--(c) the controllers
I could be wrong, but the synth engine system [which
include "patchcords"] cannot output midi data. The sequencer and
controllers can.
Even though each preset has settings for arps and riffs, those are
really sequencing functions.
When you use the knobs (for example) to send CC data to external
gear, you are using the knobs as controllers. The synth engine and
the sequencer can also do stuff with the knobs, but that doesn't
mean that the patchcords can be used to take synth engine
functionality and generate a stream of midi data.
I agree with the original post--it is wishful thinking to be able to
use an lfo [synth engine function] to generate midi data, such as
CCs.
The thought is so compelling, I would love to find a work around to
trick the CS/P2500 into doing that.
(2) Don't forget, you can embed sysex commands (with external
software) into patterns.  As I wrote previously, you can--for
example--embed sysex commands that change the CC assignments for all
16 knobs.
One application is that if you create a song by chaining together
patterns and manipulate the knobs on the fly in a performance, each
section [pattern] can have the knobs do different things.
2005-09-09 by malik
yeah i always did like the idea of that. but i have only figured out
triggering it by buttons. i've tried looking for that post but i get no
replies. seems  you've all grown tired of me again :)
im gonna have to filme that  gate problem to protect my innocence lol
> 16 knobs.
2005-09-09 by mike_melon
Hello Steve,
You got my point exactly. The potential to male 'midi' patches to
modulate other gear would have been brilliant- tempo synced random
lfo's, velocity switched envelope sweeps etc. I imagine the strain on
the processor would have been too much for practical implementation.
There must be some workarounds using third party devices. The clever
folks at Midi Solutions have designed a box to process midi. It is
like a tiny hardware version of Midiox programmed via sysex and
powered via the midiline.
http://www.midisolutions.com/prodepp.htm
This box can do every midi msg manipulation imaginable! For instance
i'm sure it could remap arpegiator notes to midi controllers in real
time allowing us to harness the power of the arp at least.
Incidentally I intend to buy one to simply remap the  quick
programming knobs A-P to CC's of my choice for ease of recording into
patterns. This overcomes the gaps in the controller destinations
allowed.
I also have a Peavey PC1600x. This fader box contains 2 CV > midi
convertors so I am wondering if I routed a bright, loud patch via sub
outs into one of these, if I could capture the fancy note retriggers.
I really love this machine (MP-7)!
Mike
> on the processor would have been too much for practical
> implementation.
[snip]
> Incidentally I intend to buy one [Midi Solutions box] to simply
> remap the  quick programming knobs A-P to CC's of my choice for
> ease of recording into patterns. This overcomes the gaps in the
> controller destinations allowed.
I assume you know:
(1) you can program the controller destinations for the knobs from
CC = 1 -> 119
(2) when you save a multiseup, the controller destinations are saved.
I am curious to know what gaps you might want a workaround for.
> sub outs into one of these, if I could capture the fancy note
> retriggers.
I haven't done anything with CV and triggers since working with the
original Moog.
I am partial to E-Mu; I have the P2500 and really like the
felibility the design provides. Raised on the Moog, I
love "patchcords." The take me back to my synth roots.
If you want to embed a small sysex to change controllers (or
anything else for that matter), check out:
(1) http://launch.groups.yahoo.com/group/xl7/message/16542
(2) Files | Controller Midi File (for a demo file that will change
controller settings.
If you run the file, I suggest you save your current settings in a
multisetup first.
I used cakewalk software to create the file and e-loader to put it
into my e-mu.
--Steve
2005-09-09 by vibesart
Just checking to confirm what I already think I know is true - the
Command Station Track Enable/Mute Buttons cannot send out MIDI data -
is this correct?
I need something that does (send Mute/Unmute commands) if anyone has
any recommendations....
I concur this is a great axe - I have been using it live with my band
lately - it is so cool that I have been planning for what to do when
it is time to replace it
anyone ever worked with the AKAI boxes?
> I assume you know:
> CC = 1 -> 119
RE: [xl7] Re: patchcord destinations
2005-09-09 by BEAUFILS Adrien
I know that the trigger button can take place of the button track enable / mute by assigning them to the same canal ( i know it is possible in fruityloops by checking the canal enable to mute the track and select it like to the same canal in your command station ). But i don't know if it's possible with a hardware product ( perhaps by selecting the omni reception midi in your module but it may create others problems ).
Bye
 Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
 Téléchargez le ici !
> I assume you know:
> CC = 1 -> 119
Well I thought the programmable knobs could not be recorded in the
sequencer. Perhaps I've got this wrong.
The quick edit knobs record fine but are limited to CC 1>31 then 64>95.
If I want to sequence tone changes on my novation drumstation I need
some controllers located after 31 and before 64 and also some above 119.
Mike
2005-09-09 by malik
yeah you can use it to trigger hardware if you have it setup right.
sometimes it may mean using additionnal hardware/software to make it
happen tho.
for instance i'm using midi ox to recieve note on messages from the
trigger button to send info back to the mp-7 to change multisetups.
--- In xl7@yahoogroups.com, BEAUFILS Adrien <fatalojyxvsfacial@y...>
> Bye
Messenger
I am in the CONTROLLERS menu >Trigger Buttons Function>Play Note
Events>(go to next page)TRIGGERS - Note# - Vel amount - Ch# -
Destination (int-ext-both-seq)...but I see no MIDI data flowing from
the XL7...and noting rec'd either....
request furter input, if anyone knows
thanks!
Ed
> happen tho.
2005-09-09 by malik
ok so you have midi plugs connected to outputs a and b? also do you
have the xl set to triggers or track enable. do you have the
triggers set to estenal?
you pretty much stated all that there should be to it in your
message but nothing that really told me about how your xl is setup
(in that menu)
from
> thanks!
> Ed
right.
make it
> > happen tho.
multisetups.
track
2005-09-10 by vibesart
>also do you
THAT'S IT! MIDI is now being transmitted and rec'd!
>do you have the
**in this example yes - external
Thank You Malik
EM
> from
> > thanks!
> > Ed
> right.
> make it
> > > happen tho.
> the
> multisetups.
> track
2005-09-10 by steve_the_composer
My P2500 (OS2.0) is off now, but I believe I can record the full
span of CC data into the sequencer.  If I remember correctly the
programmable knob control settings have several destinations--int,
ext, both, and seq. I think its described in one of the OS addendums
and the latest pdf that covers OS2.0 systems. Also, check out the
flow diagrams for routings between the various sub-systems
[controllers, sequencer, synth engine, and external midi].
Hope I remember correctly and if so, hope this helps.
--Steve
> > I assume you know:
from
> > CC = 1 -> 119
saved.
64>95.
need
above 119.
> Mike
2005-09-11 by malik
apart from sampling and all that stuff wich one do you like better?(mpc
or command station)
--- In xl7@yahoogroups.com, "gonzinigonz" <gonzini@f...> wrote:
> Hi
> MPC2000XL
> Gonz
2005-09-13 by gonzinigonz
Like them both for there strengths..
MPC sounds fantastic, the timing is rock solid the thing pumps away.
Crap interface though, it really gets in the way for me.
Command station is a lot more hands on and creative i believe. Guess
you have alot more to hand with the synth and stuff. The real time
controllers are something that the akai cant touch.
At the moment its the command station for me. If i want to sample l'll
dig out the S3000XL
I found that the MPC2000XL would crash alot, even seem to corrupt its
own data. Ive had the command station do odd things at times but i seem
to get more done with it.
just my 2 cents
Gonz
(mpc
> or command station)
> > Hi
> > MPC2000XL
> > Gonz
dig out the S3000XL
just my 2 cents
Gonz
(mpc
> or command station)
> > Hi
> > MPC2000XL
> > Gonz
2005-09-13 by malik
kinda what i expected just a bit worse!! damn im glad i made the
right choice!!
away.
Guess
l'll
> dig out the S3000XL
its
seem
> just my 2 cents
> Gonz
better?
> (mpc
> > or command station)
> > > Hi
> > > MPC2000XL
> > > Gonz
2005-09-14 by gonzinigonz
shame akai didnt finish the job with the 2KXL, seems a waste of
decent hardware.
Guess it works for a lot of people though, hiphop styles and the like.
We used to take 2 of them out live doing psy trance type stuff, that
was a few years ago now..
Anyway better stop taliking about akai round these parts! ;O)
Gonz
> right choice!!
> away.
> Guess
time
> l'll
> > dig out the S3000XL
> its
i
> seem
> > just my 2 cents
> > Gonz
> better?
> > (mpc
> > > or command station)
> > > > Hi
> > > > MPC2000XL
> > > > Gonz
