Automation to remain the multi setup?
2005-11-05 by fatalojyxvsfacial
Hi, I post today for an information about how to restore a multisetup in a pattern. Some peaple say that you just have to insert a program change in a track with the value pgrm=number of the multi you want to remain msb=00 lsb=80. So i test this feature but it don't work. In fact i work with different arp master and there aren't reminded when i change the pattern. Perhaps the featutre don't work to change the setup of the arp, i don't know. So i've tested to combine my pattern in a single multicanal but nothing change. Here is my normal set up: Each track is assign to each canal ( T1>C1A...T16>C16A ) The fx are routed to one channel for example to channel 1 in pattern 1, to channel 9 in pattern 2 so all the sends are recorded in the preset in channel 1 / 9( preset sends to 0 and control of the sends with real time controler like it's done in the beat garden card or in the Techno Synth ) The other channels are routed to differents sends ( C2A...C8A>send sub1, these channels are used for rythmic preset and the other are send to send sub 2 or send main 1 or 4. One of theses channel use a master arp which is different for each pattern. What i want to do is to change the arp master and the fx channel assignment of each pattern but this program change don't work. Maybe i have to do a program change with a lsb value of 79. I don't know. If someone have an idea or a solution...Any help would be appreciated. Good week end Adrien
