XL7 as a slave
XL7 as a slave
2005-11-26 by xl7mo
I have a problem and if I can't fix it my xl7 will be worthless to me so please help.
My brother and I are in the same band he is on a 'Electribe ER-1' and I'm on the 'xl7'. My
brother is the drummer and the 'Electribe ER-1' is the master so he controls the tempo(BPM).
My xl7 is the slave. so far so good. He controls start/stop and sets the tempo.
My problem is that when I want to record something in realtime, the midi data from the
'Electribe ER-1' is recorded too. The er-1 is on channel 16. I'm not using channel 16.
Rechannelize input is set to off. Enable midi for channel 16 is set to off. But still it is
recording the mididata from the 'Electribe ER-1'.
After a day work and 3 times reading the manual we could not fix this. Please help!
EMU xl7 version 2.0
Re: XL7 as a slave
2005-11-26 by vibesart
I have an ES-1 and the XL7 here..interesting. It seems as though you
cannot stop the E-tribes from sending out MIDI note data (at least I
cannot find that).
On the XL7 in the MIDI menu - have you tried assigning the XL7 to a
different MIDI Sysex device ID? Have you tried setting MIDI Enable on
XL7 MIDI Channels 1-15 to "off"?
Just a few thoughts...not sure it will work or not.
me so please help.
the tempo.
midi data from the
using channel 16.
this. Please help!
> EMU xl7 version 2.0
Re: [xl7] XL7 as a slave
2005-11-26 by Mibrilane
> me so please help.
> sets the tempo.
> midi data from the
I had an ER-1 ages ago. As far as I can recall, there is no way turn
off the note transmission - the MIDI filter in the ER-1 only applies
to bank/start/stop messages, sysex, and NRPN knob data.
I'm assuming you are in MULTI mode on the XL-7 with Channel 16A
turned off.
Maybe if you set MIDI IN CHANNELS to "B" it won't route the incoming
MIDI notes to any of the A channels in the sequencer. That's what I'd
try at this point. If rechannelize is off and your sequencer tracks
are all set to 01A through 16A, rerouting the MIDI in to B should
keep the incoming data from reaching the sequencer. This would
exclude clock and MIDI start/stop, as I believe these are global
messages regardless of the channel.
This all assumes you're not controlling the XL with an external
keyboard. If that's the case, I don't know what to tell you. :-|
Mibrilane
Re: XL7 as a slave
2005-11-27 by lifeistheformofenergy
I 2 have a similar problem when using the XX7 as a "slave" while
recording in realtime for some reason the preset information switches
on me or something else changes during the recording and it messes
everything up ... I assume it is the CC sysex information from the
other device triggering something on the xx 7 CC sysex - how do we
turn this off (make it just stay as is) during recording ?
to
> > me so please help.
1'
he
> > sets the tempo.
> > midi data from the
set
turn
applies
> turned off.
incoming
I'd
tracks
> Mibrilane
RE: [xl7] Re: XL7 as a slave
2005-11-27 by Apekop Gapekop
No, I'am not controlling the XL with an external keyboard. I hope the sysex
thing whil fix someting because I tried everything else. I don't know
annything about sysex. Is it possible to turn it of?
Thanks
Tim
__________________________
to
me so please help.
1'
he
sets the tempo.
midi data from the
set
turn
applies
turned off.
incoming
I'd
tracks
Mibrilane
Welcome
2005-11-27 by K4d4w3r
Please be welcome to visit the site of my project)
Artificial Sound Lab - Project
http://www.asl-project.net
And please leave your opinions on the music...)
Cadaver Cum Spiritus Corpus Non Est!
Yahoo! Mail - PC Magazine Editors' Choice 2005
http://mail.yahoo.com
Re: XL7 as a slave
2005-11-27 by steve_the_composer
This problem seemed at first glance an easy one to diagnose. However,
since I haven't done much with E-Mu sequencer recording, it took a
while. Since I don't have an electribe, I used Sonar to send data on
16 channels to my E-Mu sequencer [P2500].
I hope this helps:
Relevant MIDI settings:
---BASE TEMPO: ext
---RECHANNELIZE INPUT: off
---EXTERNAL SONG START/STOP: accepted
---MIDI IN CHANNELS: 1 to 16: A
---MIDI ENABLE channel 16A: off
---RECEIVE PROGRAM CHANGE channel 16A: off
PATTERN EDIT settings [I used T01]:
---CHANNEL ASSIGN Channel: MultiA Dest: Int
NOTE:
ALL Notes were recorded, including those on channel 16, but on
recording and playback, the channel 16 data was not sent to the
internal synth engine.
If you don't mind having the channel 16 data recorded as long as it
doesn't play your E-Mu, the solution above should work for you.
If this doesn't meet your specific needs, I'd recommend getting some
kind of programmable filtering device. For  example, I have see MOTU
8x8 midi routers [Express XT] (among others) on e-bay. The parallel
port version used to go for around $70-$85. The usb port version is
more expensive. With either you have 8 user slots to configure
different routings using computer software.
--Steve
My
controls the
tempo(BPM).
sets the tempo.
midi data from the
this. Please help!
> EMU xl7 version 2.0
Re: XL7 as a slave
Hmmmm. This might work, too. Since mine is the P2500 [no pads], I
can't test it. If it works for you, it is better than my solution, as
it requires fewer steps to achieve. I assume the settings are as
follows:
MIDI settings:
---BASE TEMPO: ext
---MIDI IN CHANNELS: 1 to 16: B
The incoming clock/start/stop still works, but the incoming data is
routed to B which is not routed to the sequencer.
If you were merging an external midi device with the electribe into
the E-Mu, then I think my solution should work.
--Steve
incoming
I'd
tracks
> Mibrilane
Re: [xl7] Welcome
2005-11-27 by Mibrilane
Your MP3 links don't work - they point to a sever called "www.asl.tam.by" -
the links work if this is replaced with " www.asl-project.net". ;D
Mibrilane
Re: [xl7] Welcome
heh...) THX i'll tell the programmer)
Whats about music?
Start your day with Yahoo! - Make it your home page!
http://www.yahoo.com/r/hs
Re: XL7 as a slave
2005-11-28 by zerolatencyproductions
Hello,
The Problem:
This problem has nothing to do with SysEx Data.  Here is what is
happening.  You are sending information over MIDI chanel 16 from the
Electribe to the XL-7.  The XL-7 recieves the information; but since
MIDI Enable is off on channel 16 of the XL-7, the XL-7 doesn't play
it.  So, what you get is information received and recorded, but not
heard.  Also, if you have all 16 channels being received by the
Command Station, it will record all 16 channels on one track.  It
doesn't matter if you have the MIDI in set to B, are recording on
Channel 1A, and have everything else set to off in MIDI Enable; the
XL-7 is still going to record the information of all 16 channels
onto that one track. There's no way around this on the XL-7.
The Solution:
Though you might not want to at first, the solution is to use the
Command Station as the Master and the Electribe as the slave.  I say
this becuase I know you can setup the MIDI Channels the way you
would need to on the XL-7.  To do this Go into Pattern or Song menu
and go to the Channel Assign menu.  Select the channels you want to
transmit, turn the Dest: to External or Both.  Select the channels
you don't want to send, turn the Dest: to Internal or None.  If you
don't want to send keyboard information go to Keyboard Outputs MIDI
in the MIDI menu and set it to Don't Transmit.  Same with the
knobs.  This will allow the XL-7 to be effected by the Keyboard and
knobs, but not send the information to others. With this setup you
can record on the XL-7 in realtime and not get all the extra info.
You say your brother is the drummer and he sets the start and stop
and tempos of the XL-7 from the ER-1.  Well, I don't see any reason
why you shouldn't set that up on the Command Station and send it to
the ER-1.  Really, in this case I can see more of a reason to use
the XL-7 as the master and the ER-1 as the slave.
GoodLuck,
Brandon
me so please help.
sets the tempo.
this. Please help!
> EMU xl7 version 2.0
Re: Welcome
2005-11-28 by lifeistheformofenergy
your site is unable to load the "sound" page and I therefore was unable
to review your sounds ...
2005-11-28 by Apekop Gapekop
Thanks for all the response!
I've tried everything but I'm afraid Brandon is right. There is no solution.
The xl7 is not usable as a slave. Making it the master is not an option for
me cause I realy want my brother to set the tempo. I'am playing the bass too
so let him do that job.
I can do several things. Wat do you guys think is the best:
1 buy a midi filter.
2 buy a "masterclock tempo controler thing" and let the electribe be slave
of that too.
3 buy another sequencer.
4 My brother wants to buy a mac mini and use ableton live for his
drumsounds. I wait for that and see if I can fix things then.
Thanks for your help!
Tim
>From: "zerolatencyproductions" <zerolatencyproductions@...>
>Reply-To: xl7@yahoogroups.com
>Subject: [xl7] Re: XL7 as a slave
>Date: Mon, 28 Nov 2005 00:26:36 -0000
>Hello,
>The Problem:
>The Solution:
>GoodLuck,
>Brandon
>me so please help.
>sets the tempo.
>this. Please help!
> > EMU xl7 version 2.0
Re: [xl7] Re: Welcome
2005-11-28 by K4d4w3r
The site is working correctly now...)))
the problem was after transfer to the other doman))
I hope i'll hear your opinions
Re: XL7 as a slave
2005-11-30 by zerolatencyproductions
I think you should definately wait for the Mac Mini.  Sequencing on
a computer is almost always easier than on a peice of dedicated
hardware.  Funny, hunh?  It might be a little more expensive,
though.  Chances are your gonna have to buy a professional soundcard
to go with it, and since you're getting the Mac Mini you'll have to
get a soundcard that connects via USB2.0.  Since you're using
several MIDI instruments at once, you'll need either a soundcard
that comes with more than 16 channels of in\out, or get something
like a MIDISPORT2x2 or MIDISPORT8x8.  Setting up a computer based
system is a little more expensive, but it will definately be worth
it in the long run.  You'll end up with a more complete production
studio that does a lot more than just filtering MIDI.
Later,
Brandon
solution.
option for
the bass too
be slave
> of that too.
> Tim
> >From: "zerolatencyproductions" <zerolatencyproductions@y...>
> >Hello,
> >The Problem:
since
play
not
> >The Solution:
say
menu
to
you
MIDI
and
reason
to
> >GoodLuck,
> >Brandon
worthless to
> >me so please help.
1'
so
> >sets the tempo.
I'm
fix
> >this. Please help!
> > > EMU xl7 version 2.0
Re: [xl7] Re: XL7 as a slave
2005-11-30 by Rich Williams
It's a much better idea to use Firewire for audio, especially if
you're using your USB bus for MIDI
