My XL7 won't power up
2006-09-09 by tonyhoneyford
I have read a few threads about power supply problems....my unit is not
switching on at all...checked internal fuse, and thats okay....I rarely
use the standby switch so I doubt that anythings overheated (240volts
won't be helping though)....I just wonder how the standby switch
actually works? Is there a known issue with this standbye switch? I've
tried re-seating everything internally that could have come loose but
no joy...we were just about to book our first gig in 6 months, and our
set is based around trax we've written on our XL7.....Please
heeelllpppp!!!
Re: My XL7 won't power up
2006-09-09 by gonzinigonz
Not 100% sure how the standby switch tie's in the the PSU but there
will be a sense line on the PSU somewhere that detects when it needs to
power up and down.
In fact the standby must be a part of the XL's hardware and firmware or
you wouldnt get the "powering down in xx" time in the LCD.
So when in standby the PSU must be working you see?
A bit like your PC when you turn it off but its still got live mains on
it and theres still some voltages left on the motherboard.
If your 100% convinced that it is the PSU there is a link to a supplier
on a thread further back, someone managed to get hold of one.
Im sure the old one could be repaired, id have go. I do electronics for
living.
Another thing is that a lot of people including myself run the XL's on
110v with a 240v to 110v transformer.
It runs alot coolier that way :o)
Hope that helps
Gonz
not
rarely
I've
our
> heeelllpppp!!!
Thanks Gonz....
Is the psu the bit inside with a grey cage around it? I'm a carpenter
by trade and I know JS about electronics....If I had a circuit tester
I could at least see if the thing is somehow stuck in standbye
mode....but for that to be the case the psu must be okay...is that
what you mean?...I could maybe borrow a circuit tester...would that
help me source the problem? is this common psu fault easy to
repair....I know someone else who repairs TVs etc...maybe they could
do it? I know I'm rambling on here but there aint an emu repair
centre this side of the ocean (that I know of!)and our whole show is
now stopped dead in its tracks--- In
needs to
> power up and down.
firmware or
mains on
supplier
for
> living.
on
> Hope that helps
> Gonz
is
> not
> rarely
(240volts
> I've
but
and
> our
> > heeelllpppp!!!
Thanks Gonz....
needs to
> power up and down.
firmware or
mains on
supplier
for
> living.
on
> Hope that helps
> Gonz
is
> not
> rarely
(240volts
> I've
but
and
> our
> > heeelllpppp!!!
> Thanks Gonz....
Yes
> what you mean?...
Hummm.. to a point i guess. You could certainly test for any voltages
on the supply rails that are present.
Dont think anyones got any schematics for the xl so where a bit in the
dark about that one..
The only other way is to get the model No. of the PSU, track down that
company that sells them and try to get some tech data for the supply.
That should help no end.
As long as you know what your doing with it and know where to look!
>is this common psu fault easy to repair....
Not done one myself, but i dont think it will be anything to major.
There are a few classic problems with SMPS (The PSU)
> do it? I know
Might well be able to. Theres SMPS's in TV's these days, if he knows
those he shouldnt have to much difficulty in fault finding the XL's PSU.
There are a few synth repair places about, proberly a few in london and
i know of 1 up north.
If your near Portsmouth area, southcoast i could have a look for you.
Re: [xl7] Re: My XL7 won't power up
2006-09-09 by Bob S.
Sorry for asking something obvious, but is the power switch on the back of the unit (next to the power cord) on ?
I remember myself trying to figure out why the front button was not working when the back switch went off inadvertently....
Bob
El Segundo, CA
  To: xl7@yahoogroups.com
  Sent: Saturday, September 09, 2006 6:49 AM
  Subject: [xl7] Re: My XL7 won't power up
  Thanks Gonz....
  needs to
  > power up and down.
  firmware or
  mains on
  supplier
  for
  > living.
  on
  > Hope that helps
  > Gonz
  is
  > not
  > rarely
  (240volts
  > I've
  but
  and
  > our
  > > heeelllpppp!!!
Good call! try to never forget the obvious, it does happen all the
time..
Can you remember where that message regarding the source of spare PSU's?
Gonz
> Bob
> El Segundo, CA
>don't apologise...but yes its switched on....
> Bob
> El Segundo, CA
>   ----- Original Message -----
>   From: tonyhoneyford
>   Thanks Gonz....
carpenter
tester
that
that
could
is
there
>   needs to
>   > power up and down.
>   firmware or
>   mains on
>   supplier
electronics
>   for
>   > living.
XL's
>   on
>   > Hope that helps
>   > Gonz
unit
>   is
>   > not
okay....I
>   > rarely
>   (240volts
switch
switch?
>   > I've
loose
>   but
months,
>   and
>   > our
>   > > heeelllpppp!!!
--- In xl7@yahoogroups.com, "gonzinigonz" <gonzini@...> wrote:
Hi gonz....sifted through the messages and found one that said the
psu was mentioned in audiofanzine as being manufactured by a firm
called powdec ref.CMG9-01
Thanks again for your help and advice here.....its sites like this
and people like you that make me realize the world really is a good
place full of basically good people..........(hang on ....while I get
my hanky)
Cheers
toe
> time..
PSU's?
> Gonz
not
> > Bob
> > El Segundo, CA
Been on powdecs website and discovered there is no cmg9-01-c.....but
there is a pte43-xx-c (this was referenced in the audiofanzine
message thread)...this unit is identical in size...but has only 6 out
pins instead of the 10 on my unit....also, some of the vents have
been covered with a thin plastic screen.....i aint a scientist, but
why would you design a cover with ventilation gaps and then cover
them up? ...maybe when they did the 240v switch unit for the uk
market it buzzed or something, so they maybe covered the vents with a
screen (the screen covers just the wire coil thingys
(transformers?..) which woulde make sense....of course they must have
known that this covering of the vents would probably shorten the
working life of the unit from 100,000 hrs to say 10% of that..
Anyway, I am hoping that the 6 pin version (pte 43-xx-c) will still
work (surely not connecting the standbye pins will mean that only the
proper on/off switches will turn it on/off?)...
what do you think of all this...
Toe
> time..
PSU's?
> Gonz
not
> > Bob
> > El Segundo, CA
Im looking into now. Ive just opened up my XL and will meter a few
things to see what happens.
Quick look at those other SMPS's on powerdecs site arnt the same
after all.
Theirs seem to be triple rail type so hence the less cables..
The XL has got 4 :-
    3.3v
      5v
    +15v
    -15v
And 2 other lines that do the remote power up/down.
This has more incommon with a ATX PC supply at the moment. (now
theres an idea..)
l'll get my scope on there and try to reveal once and for all the
mystery of the PSU...
Gonz
c.....but
out
a
have
> Toe
2006-09-10 by gonzinigonz
Ok ive had a look.
Nothing that strange about it at all. Theres nothing ive seen on
powdec's web site thats close to this though.
I've just sent them an email, see what comes back next week...
There is something you can do Tony.
If you can get hold of a multitester you can check some things.
Set it on a suitable range to measure 12v DC VOLTS.
Connect the black ( - , com) to one of the black wires.
This is ground. You could also connect to some bare metal on the
casing, this is ground as well.
Then meter the purple wire. You should see +10vdc on it with mains
connected.
This is the wire that always supplies the board, regardless of the
power switch on the front panel.
If you see 10vdc thats good :o)
Now meter the green wire. This is the switching line. I measured
around  ~ 2vdc here when the unit was powered down (in standby)
Then if you press the front power switch it drops to near 0vdc.
(this is how the PSU switches on. If you ground this line it should
fire up)
If this is happening and it stays low then meter the other cables.
The voltages are screen printed to the side of the connector on the
PCB.
So:- Pins 3,4,5,6,9,10 (7 & 8 being ground)
Pin 1        PWM on/off Active Low - Green
Pin 2        +10v Always on        - Purple
Pin 3 & 4    +3.3v / 3A            - Orange
Pin 5 & 6    +5v / 2A              - Red
Pin 7 & 8    GND                   - Black
Pin 9        -12v / 0.4A           - Blue
Pin 10       +12v / 0.6A           - Yellow
Obviously be carefull while your doing all this. Dont let anything
short out or touch the metal case work by accident.
Let us know how you get on.
Cheers
Gonz
Model No. CMG9-01
100-240VAC 0.85A
H04615
E158470
www.powdec.com
2006-09-10 by Aaron Eppolito
Gonz, you're a rockstar.
I believe Powdec was the OEM, so if you can get a matching unit from them, it'd be what originally was in your XL-7.
-Aaron
gonzinigonz <gonzini@...> wrote: Ok ive had a look.
connected.
fire up)
PCB.
Cheers
Gonz
Model No. CMG9-01
100-240VAC 0.85A
H04615
E158470
www.powdec.com
Yahoo! Groups Links
Get your email and more, right on the  new Yahoo.com
2006-09-10 by tonyhoneyford
Hi gonz...
the website is a bit ambiguouis.....if you go to the home page, then
click on the tab for the lowest voltage internal PSUs ...you will
find a PTE43-??-c, and this is the one that is referred to in the
audio fanzine magazine....and though it is only 6pin output...its
dimensions exactly match the psu in my xl7 & it looks
identical....surely this is the replacement psu for the faulty one?
or is this what they used in the later comand stations.....did they
somehow change the circuitry for the standbye mode? why does the emu
psu have so many different voltage outputs anyway....no wonder they
never used a wall wart transformer thingamajiggy....
 I will mail you a photo of the psu showing what I think are
symptomns of minor meltdown/overheat....
> Ok ive had a look.
> connected.
> fire up)
> PCB.
> Cheers
> Gonz
> Model No. CMG9-01
> 100-240VAC 0.85A
> H04615
> E158470
> www.powdec.com
then
> identical....
Looks can be deceiving
Nop.. only a tripple rail not a quad :o( ( 5 if you include the
constant 10v rail..)
Also dosent supply enough current (or not to the same spec)as the
original
Wouldnt of thought so, i think its just a differant model that
someone on the audio fanzine site decided that was the one because it
looked the same.. which ain't! (though its in the same case and IEC
connection and power switch are the same)
> why does the emu
These are the voltage rails it needs to work, thats the way it is.
3.3v and +5v for logic, ram, DSP, CPU, LCD etc
+/- 12 for the analogue audio stuff (and the 12v gooseneck lamp on
the front!)
Please do, high res photos good. upto say 6mb fine.
You've got the email.
Cheers
Gonz
Lets see what comes back from the email..
I asked them for service data as well..
> -Aaron
Hya gonz
it seems my sony digital camera won't do close ups....so no
photo's....anyways I might be wrong about the minor meltdown...its
just that one of the round black (tin can shaped) module type
duberries thats wrapped in rubber has a gap in the top like its
swelled up, and the yellow tape around the transformer coils seems
like its a bit too crinkly (due to overheating?) but obviously this
is all supposition.......I recently changed a fuse in my boilers'
circuit board and discovered it had a secondary fuse on the board
(encased in a black module type of thing)......surely there might be
a secondary fuse on the psu board??? I do not think I want to go down
the multimeter route just yet (not having a multimeter isn't helping)
But if I am getting nowhere with all this by tommorrow I might try
and borrow one and do as you suggested earlier....
Also...I think I read on an earlier thread that you can't get
replacement PSUs for xl7s any more?...unless the place you mentioned
in the midlands knows different....so it looks like the repair route
is looking the best one......My old freind the tv repair man might be
able to help us out here.....especially if I can get a dialogue going
between yourself and him???
I also emailed powdec yesterday, but I sent my query to the sales
guy..and I assume you sent your email as a technical query?  so i
guess between us we should get some answers tommorrow.... really
appreciate your help here....In fact if your ever up north you are
welcome to come and visit our little studio set-up or see one of our
gigs for free...if you want you can hear one of our old tracks by
visiting valentine records' free download section on their
website....ours is no. 12 (I think?) its called morning calls by
mellowstone(thats our old name) and you can hear some of my xl7
programming on the track (thats everything except the vocals and
guitars.....its not a bad track, in fact it was used by a small
manchester production co. for one of their travelogue films....hope
you like it....
Enjoy the sunshine while its here....
 ..toe
> then
> > identical....
> original
they
it
> > why does the emu
they
> the front!)
> Cheers
> Gonz
Sure you cant do close ups, no macro or anything like that.
How about a high res picture from the shortest distance you can get
it to focus?
If it looks like somethings really fried then all effort could be
made into sourcing a replacement.
> be a secondary fuse on the psu board???
Usually only on the mains input side of the SMPS board.
If this fuse has blow its normally bad news..
> going between yourself and him???
He should be able to repair it as long as the hi frequency
transformer or other obscure parts havan't failed.
Its usually a filter cap or resistor failed. If its bad then the
switching transistor / IC can self distruct leaving a bit of a
mess..
hummmm been out in it fixing electrics on some crazy german camper
bus thing.. thats in i right old mess. It never stops.
I'll read up on my cameras' instructions to see if there is a macro
mode.....if not, I'll just do the best I can with it and send it to
you hopefully later.......cheers...toe
> it to focus?
might
dialogue
> mess..
ok cool. maybe we should take this of the list now as where having
personal conversions!
gonzini@...
Guess we can post any results we have to help other people
Cheers
Gonz
