help how to load presets
2006-09-21 by martyj125
i screwed up and deleted all the factory presets and songs how do i put
them back from the e-loader disk ?  it looks like all the files are on
the disk.  what do i do to transfer them from my computer to the xl7
please anybody? i just got this and i cant believe i did this.
Re: help how to load presets
2006-09-21 by tonyhoneyford
I am nowhere as capable/experienced as others in this group but
basically you need to get a  'midi-sport' box or (similar) and connect
this box to the USB port on your computer....then get a midi lead and
put one end in the 'out 1' on your midisport and connect the other to
the 'in A' midi socket on the back of your CS.....Install the e-loader
software and follow the instructions for 'uploading patches'....if you
have any glitches getting the xl7/midi-sport/computer to communicate,
these can often be overcome by restarting everything (can't remember if
the order of start ups is important....but you can experiment....)
A cheaper option for one way midi communication is a simple cheap USB
to midi lead...
(cheap as chips!!)
One other thing is if you have problems getting your computer to
recognise the new midi lead, simply right click on 'my computer' go to
properties and let go....then click the 'hardware' tab and click
on 'device manager'.....highlight 'USB controllers' by clicking on it
once.....then go to the top and hover over the symbols....one will
say 'scan for hardware changes' click on this......do this whenever you
have problems with your midi set-up...
Also....if you get a midi box that has two in/two out, you can download
your song/patch files on to your computer for safe keeping.....you can
also then import the patches into cubase for very eassy arranging of
songs....As a guitarist that is a bit of slow when it comes to
computers etc. I have learned the bare basics of cubase to allow me to
programme my XL7....Its the best thing since they invented a machine
that slices bread!!
Good Luck
Toe..
PS...if you go to emus website you can download preset patches for all
the Command stations(MP7 PX7 etc......if you download them to your own
XL7 they wont play straight away.....if you press the preset button it
will give a message "no preset loaded".....simply move the cursor ,&
spin the jog wheel to select one of your own user sounds or an XL7
preset sound....you can have some interesting fun using the downloaded
patterns as sequence templates for your own sounds......  --- In
put
on
thanks alot for the reply i actually figured it out i didnt realize
there was a pdf manual.. duh.also i have a few more questions....emus
site only deals with the souncards and software now where can i find
these patches you speak of also can anyone help me find the 2.0 os for
the xl-7? the emu site doesnt seem to deal with these anymore those
bastards!  also one more question ...ill actually probably have alot
more as the manual reads like a friggin science textbook...but anyway
how do i change drum sounds while playing the presets for instance
right now as i change presets the synth sounds change but the drums are
staying bongos how do i switch the drum sounds.any help would be great
thanks again....martin
2006-09-21 by martin
i found the 2.0 os on this site but do i need to upgrade incrementally
from other os first? i currently have an xl-7 with 1.31 os is the 2.0
zip file the right one? and where do i zip it to to get e-loader to
recognize it? also still dont know how to change drum sounds while
playing the presets.could anyone help?
Re: [xl7] Re: help how to load presets
2006-09-21 by Aaron Eppolito
If you had an older revision you might need to download flashprep
first, but 1.31 already included it.  Other than that, you can go from
any revision to any other revision (at least forward).
Just download the 2.00 OS and you'll be fine.  Do note that you need
MIDI, not USB, for OS downloads.
-Aaron
> incrementally from other os first? i currently have an xl-7
Do You Yahoo!?
http://mail.yahoo.com
2006-09-22 by tonyhoneyford
Look "legacy hardware" when choosing tabs on the emu site....
Other than that.....Stay calm....there is a real learning curve with
this thing......be patient, and you will be rewarded..(didn';t
churchill once say that?
To cancel the sound editing you have just done....simply press the
preset edit button and scroll to the page 'restore preset' I've ad a
drink but I think it says something like that....then press
enter.....to save changes you need to sroll through the save options
and ask yourself which ones might work? the wording of the save options
is a bit ambiguous.....(tricky)it is maybe a good idea to experiment
saving, turning the xl7 on/off and see if its worked(this is the hard
way, but it might help you understand the various save options....)once
you fully understand all the different save options....Can you tell
me ....cos I'm foooooked if I understand this machines capabilities
Good luk...
Toe...
for
are
great
