Someone Please Help MP7 Drivers ?????????
2007-06-15 by Carlos
I love my MP7 I had one that broke unfortunately. I bought one on eBay
with an empty ROM. I connected my MP7 via usb but my PC says it needs
drivers  I am running Windows XP with sp2 someone please help I would
love to start using my MP7 again  .........Thanks in advance
Re: Someone Please Help MP7 Drivers ?????????
2007-06-15 by gonzinigonz
You will need to install EMU's E-Loader software that installs the
drivers and the data transfer software.
Not sure what the latest is with XP as some people had a few issues.
Try it i guess, see what happens.
Re: [xl7] Re: Someone Please Help MP7 Drivers ?????????
2007-06-15 by Carlos Reyes
Thanks For the info Tried but still not working... Don't know ???
gonzinigonz <gonzini@...> wrote:                                  You will need to install EMU's E-Loader software that installs the
Food fight? Enjoy some healthy debate
in the Yahoo! Answers Food & Drink Q&A.
2007-06-16 by gonzinigonz
I think this is what the problem is,im sure others here will know.
I think its an issue with SP2. I think it works with SP1.
If i recall SP2 broke a lot of music software in other areas at the
time.
I thought i had my XL7 working with my laptop with XP/SP2 though.
l'll have a look over the weekend.
Not sure what would happen if you made XP use the drivers, guess it
would flag an error and still not work.
Does the software actually run ok?
If you search back through the achives theres loads on the subject.
Have you tryed it on a USB V1.0 port? say use an older hub on a USB 2
port.
--- In xl7@yahoogroups.com, Carlos Reyes <carlos_m_reyes_jr@...>
issues.
on eBay
needs
would
2007-06-16 by Carlos Reyes
The software runs but XP doesn't recognize the MP7 drivers are not working ????
Thanks for all your help so far
gonzinigonz <gonzini@...> wrote:                                  I think this is what the problem is,im sure others here will know.
 I thought i had my XL7 working with my laptop with XP/SP2 .
 issues.
 on eBay
 needs
 would
Sick sense of humor? Visit Yahoo! TV's Comedy with an Edge to see what's on, when.
Have you tryed it on a USB V1.0 port? say an old USB hub in a USB2
socket if thats all you've got?
working ????
it
>  --- In xl7@yahoogroups.com, Carlos Reyes <carlos_m_reyes_jr@>
>  issues.
one
>  on eBay
it
>  needs
I
>  would
what's on, when.
Yea I tried on my laptop on usb 1 but and it installed but it wouldn't install the OS it shows the MP7 but the download OS file to target never comes up?? Any suggestions ?
gonzinigonz <gonzini@...> wrote:                                  Have you tryed it on a USB V1.0 port? say an old USB hub in a USB2
 working ????
 it
 >  issues.
 one
 >  on eBay
 it
 >  needs
 I
 >  would
 what's on, when.
 Get your own web address.
 Have a HUGE year through Yahoo! Small Business.
2007-06-16 by Aaron Eppolito
You can't download OSes with USB, you must use MIDI.  Only thing you can do with USB is up/download songs and patterns.
-Aaron
----- Original Message ----
To: xl7@yahoogroups.com
Sent: Friday, June 15, 2007 7:35:56 PM
Subject: Re: [xl7] Re: Someone Please Help      MP7 Drivers ?????????
 working ????
 it
 >  issues.
 one
 >  on eBay
 it
 >  needs
 I
 >  would
 what's on, when.
Yahoo! Groups Links
8:00? 8:25? 8:40? Find a flick in no time
with the Yahoo! Search movie showtime shortcut.
http://tools.search.yahoo.com/shortcuts/#news
2007-06-16 by steve_the_composer
Every couple of years I try to install the usb drivers on an XP
computer. I have never been able to get it to work--despite several
attempts to trick Windows into accepting the drivers. Others here have
reported success, though. Not sure if its the usb 1.0/usb 2.0 issue or
the SP1/SP2 issue.
One option would be to use a Win98SE computer. You can probably find
one for $5.00 - $10.00, less than the price of a usb cable.
If you don't mind a slow transfer rate for backing up patterns and
sequences, you can use midi on the XP machine.
2007-06-17 by gonzinigonz
Just tryed this quickly on my XP laptop and E-Loaders not working
anymore.
Its having problems picking up the USB midi ports, in and out looking
at the log file.
On mine in the midi setup you can select USB '0' as the input port but
i only USB '0'is in the list, USB '1' doesnt appear.
If i select USB '0' for the output port it drops it and says none.
What was all that USB '0' and '1' port thing about i cant remember?
Should port 1 be the output?
In device manager when the command station is plugged in via USB both
emu usb midi ports show up, '0' and '1' and the command station appears
as a USB composite device.
Plugging in a Midiman 1X1 USB to midi interface works fine, everything
seems to be working.
Like Steve says it might be slower but at least you can back the
machine up and dump to it. Repluging things might be a pain though,
depends how you've got things plugged up i guess.
So there must be some sysex strings you can send to initiate either a
pattern / song dump request all or single?
So i wonder if its the EMU midi USB drivers are at fault seeing as the
Midiman USB port works?
This should be repairable should'nt it?
I wish i could code better, maybe its time learn..
have
or
> the SP1/SP2 issue.
Ive got E-Loader working on the win2K SP4 machine here.
Seems to be working fine with USB.
Might be a better option than win98, which is the last O/S i used E-
Loader on myself as it goes.
Im going to have another go with XP on the laptop when i get a chance.
have
or
> the SP1/SP2 issue.
find
