xl-7 headphone hum fixed
2002-02-28 by qwanta
Someone mentioned this problem awhile back.  I didn't have any
problems with this until I added a rom chip.  Then I noticed a low
but noticable hum.  Since I do most of my work with monitors it was
no big deal and I just chalked it up to more xl-7 weirdness and
forgot about it.
Then I added a second rom chip.  When I tested it with phones before
screwing it completely back together the hum was very bad at that
point.  I thought maybe there was some kind of current draw problem
with the chips so I removed both of the roms I had added and listened
again and it was still very bad.  It sounded 60 hz and only happened
when the panel button leds were on or flashing.  The lcd display and
backlight didn't seem to have any effect.
I'm not an electronics engineer but years of tinkering with audio
equipment has taught me that 60 hz noise of that kind is usually
caused by some component not being grounded correctly.  Either
something is fried or there's a bad connection somewhere.  The only
connection between the panel, where the phone jack and leds are, and
the main chassis are a few ribbon cables.  So I juggled and reseated
all of the connectors and powered it up again.  Sure enough that
fixed it!  No more hum.
So it would appear that the design of some grounding connection
between the panel and the chassis is defective.  Like maybe a ribbon
cable wire is not totally adequate for the load the leds are
drawing.  Or maybe they're just el-cheapo cables.  Whatever it is if
it happens to you try pulling the panel off and reseating all of the
ribbon cable connectors one at a time.  It probably wouldn't hurt to
clean the pins with electro-wash or something like that either.
cheers,
qwanta
