Can we reinstall older OS then 1.31(even that 1.31 is allready there)
Re: Can we reinstall older OS then 1.31(even that 1.31 is allready there)
2002-06-28 by emufreak1
Yes you can but why would you want to do that?  You would lose more
(as far as features)than you would gain.
M2
--- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote:
> Can we reinstall older OS then 1.31???(even that 1.31 is allready
> installed)
> NiR
Re: [xl7] Re: Can we reinstall older OS then 1.31(even that 1.31 is allready there)
2002-06-28 by Aaron Eppolito
WARNING!  Be aware that downgrading will most likely cause all of your
user data to be lost.  I would *very* much not recommend this, though
yes, it is possible.
-Aaron
>>installed)
2002-06-28 by nbaryosef100
I know that, the only reason I ask because after I installed Rob
Papen synth rom something got fucked (maybe I told you about it, I
don't remember) but I thought maybe to try installing again the 1.31
by going back first.
NiR
your
though
> -Aaron
> >>installed)
I'd try reinitializing the unit before trying to reinstall the OS.
 Start up with the cursors held down and select "Reinit except Seq"
(resets all global settings and all user presets) or "Reinit all user
data" (careful, this also ERASES ALL sequences!).
If all else fails, I'd call service.  It's pretty much impossible to get
a corrupt OS without having faulty hardware.
-Aaron
PS. you didn't metion what the problem was.  if you let me know, maybe I
could help.
Re: [xl7] Can we reinstall older OS then 1.31(even that 1.31 is allready there)
2002-07-01 by erik_magrini@Baxter.com
Why would you want to?
rEalm
nbaryosef100 <nir.baryosef@...>
06/28/02 10:55 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Can we reinstall older OS then 1.31(even that 1.31 is allready
there)
installed)
NiR
2002-07-01 by nbaryosef100
After I installed new Rob Papen ROM and tried to update it with new
patterns & instruments it fucked up something (When I want to create
new pattern on every channel (1-16) usually when you open you get
already instruments, but when I change channel it says present
name ??????. so I thought maybe I can fix it like that. by installing
the OS again.
NiR
> rEalm
> nbaryosef100 <nir.baryosef@v...>
> 06/28/02 10:55 AM
>         To:     xl7@y...
>         cc:
> there)
> installed)
> NiR
> xl7-unsubscribe@y...
2002-07-01 by anhdang@mobile.att.net
or visa is ok for you?
> the OS again.
> NiR
> > rEalm
> > 06/28/02 10:55 AM
> >         To:     xl7@y...
> >         cc:
> > there)
> > installed)
> > NiR
2002-07-01 by Aaron Eppolito
Did you remove the native sound ROM?  If so, all the pattern's presets
point to a sound simm that is no longer there.  Make sure that you can
select all the sound ROMs that you think you have in the box.
 Reinstalling the OS will not have an effect on this problem.
-Aaron
>the OS again.
2002-07-02 by dbaryosef
I can select them; will you recommend putting them out and the put
the Rom back again??
What do you think?
By the way the error massage I got is:
C02A V045 P00 A:P ????
         (Not installed)
Can anyone from emu comment on this problem.
Thanks
Nir
presets
can
> -Aaron
new
create
installing
> >the OS again.
2002-07-02 by Scott Ruda
> What do you think?
>          (Not installed)
> Thanks
> Nir
You have a preset selected in your MultiMap for a ROM preset on a Sound
SIMM that is not installed. At least the OS doesn't think it is
installed.
This is not an error in the OS, so there would be no value in changing
the OS. It is doing what it is supposed to do.
When you cursor to that top right field can you scroll to the name of
the new Sound Set you installed? If yes, then the presets that you have
installed are not right. Either they're corrupt, or just not appropriate
for any of the Sound SIMMs you have installed. If not, then you have a
hardware problem, because the OS doesn't see the SIMM as installed.
If the Sound Set doesn't show in the display, it is either a bad SIMM
socket, a bad Sound SIMM, or the SIMM is simply seated poorly.
You can try moving the Sound SIMM to a different socket and see if the
problem goes away. If that fixes things, it is a bad socket. If that
doesn't help, then the SIMM is probably bad.
Scott
2002-07-02 by David Jones
You can actually test the simm in diagnostics mode. I think it's the two arrow keys that you need to press when you turn on the power. I had an XK-7 with a bad rom that had to get returned for waranty repair. With the way static electricity works, i'm sure it's happened more than once - maybe you have a faulty rom!
peace
davey jones
Sent: Monday, July 01, 2002 11:10 PM
Subject: Re: [xl7] Re: Can we reinstall older OS then 1.31(even that 1.31 is allready there)
> What do you think?
> (Not installed)
> Thanks
> Nir
installed.
Scott
