Newbie OS Requests
2002-07-02 by Byron
I've only been digging into my XL7 for about 2 weeks now (and DO love it), but so far as yet, these are a few of the seemingly 'possible' things that I think would greatly benefit the xx7's sequencing powers and ease of use... 1. Make the 'repeat' button functional at all times, including changeing the quantize factor of it in realtime (as it's still being used)...and if it were more sensitive to continuous changes in aftertouch pressure, it would be much more fun (it may be somewhat continuously sensitive, I'm not very used tp these pads pressure points yet). 2. Add a 'replace' or 'overwrite' function to the recording mode, instead of just overdub....I think you could even squish into the REC screen if you abbreviate the QUANT function a bit more :) 3. More in depth midi editing options, such as track compress/expand by quantized structure or something, midi echo, groove quantize, force into Key (oooh, that would rock!)...you know, stuff that could take you a half an hour to do manually through that microwave sized screen? 4. Recordable notes from arpeggios instead of being able to record only key on/key off for them. 5. Being able to assign arpeggios 'specifically' to external gear, so that you dont have to have another new preset with it's volume pumped all the way down just to arpeggiate another ext synth. This problem could be partially eliminated if you could do as stated in #4 (record arp notes)...since you could then record a presets pattern, and then change to external midi connection, by that not having to exile a preset to a life with no volume that you cant change the arp on if you want to retain your pattern. Even just being able to assign the master arp externally would be nice. 6. Saveable external midi assigments in individual patterns without having to record on a track in order to get it to save as 'ext'....this making it much easier to make a few different pre-configured blank patterns that suit your studios vast capabilities without re-editing 16 track assignments every single pattern. 7. This is a wierd one, because it seemed to stop happening to me....being able to save seperate track assignments of presets for seperate patterns. When I first started changing them, it was changing ALL of the patterns presets per track, but now it seems not to be...could easily be a mis-understanding on my part. ***a few requests that, well, just arent really very likely if even possible, just things that would be nice... 1. A half transpose button to the side of the transpose....would be odd considering the pads are layed out to a major octave already, but it would be nice to be able to split an octave on the fly for drum recording particularily. I know I can trigger everything on one keyboard externally, but the pads are much better for drums, and heat of the moment midi scribbleing! 2. A bigger display with more lines at once! Maybe an external mini one that can rest over this one and be attached via USB? 3. A USB disk drive zip drive or something similar, would be a godsend. I bought an external midi sequencer in order to further myself from my computer, now I rely on it more! 4. An optionally colored replacement carcass :)) All in all, it may sound as though I'm complaining alot, but I'm not really, I love the XL already, but think that input from a fresh user as to its possible drawbacks could give a different perspective. I bought the XL7 with plans on using it solely as an external sequencer (only to find myself supremely impressed by it's internal synthesis capabilities), and think that some of these features would definately draw in more people looking for the same thing. Sincerely, ByronE -- Chaos exists as raw material from which to create order. -Reverend Mother Superior Darwi Odrade
