Werd to your whole setup
2002-07-23 by David Jones
Ok, I asked it before, and maybe i didn't explain my situation well enough.
I'm running an A4000 (yamaha sampler) out of my MP-7. I also have my computer plugged into the Mp-7. I have MIDI MERGE ON on the MP-7. When I use a sequencer, the Note data goes right to my A4000 no problem. But when I try to get SYSEX data to it (from BZONE), it doesn't work! It works fine when I run right out of my computer into the A4k. So I figure there must be some filtering going on... ANYONE?"
Re: [xl7] Werd to your whole setup
2002-07-23 by Ravi Ivan Sharma
Based on what you say, I think you are right. There is no mention of this or anything like it in the manual or addenda that I can see. Have you sent an e-mail to E-mu directly?
Til then it looks like you will have to patch/repatch or use a different external merger or a separate usb->midi box like a small midiman or something.
Sent: Monday, July 22, 2002 10:27 PM
Subject: [xl7] Werd to your whole setup
RE: [xl7] Werd to your whole setup
2002-07-23 by Byron
I just wish they would add sysex string editing capabilities into the XX7's next OS, or any OS for that fact...that would truly make it a Command Station in all aspects of the term (HINT! HINT!). I unfortunately have a number of older analog synths that can't be controlled via just control changes (other than the basic pitch wheel, sustain, and PGC ya know), and I would simply die to be able to do filter sweeps and what not via live control. Of course, I could just buy a Peavey controller (cant remeber there name), but I'm fairly at my finacial brink....and will end this message as I slowly drag this topic farther and farther off topic, hehehe...
Byron
Chaos exists as raw material from which to create order.
-Reverend Mother Superior Darwi Odrade
Sent: Monday, July 22, 2002 9:28 PM
To: xl7@yahoogroups.com
