DOES ANYONE HAVE...
DOES ANYONE HAVE...
2003-06-29 by phonix5mics
DOES ANYONE HAVE A E4 ULTRA LINE OF SAMPLER AND USE IT IN CONJUNCTION
WITH THE MP-7.  I'M CONSIDERING GETTING ONE, BUT I NEED TO KNOW A LIL
BIT MORE BOUT BURNING SAMPLES TO ROMS, AND OF YOU CAN BURN PRESETS
ONTO EM. THANKS FOR ANY RESPONSE. PEACE!!!
RE: [xl7] DOES ANYONE HAVE...
2003-06-29 by Patrick Dohman
I find the combo pretty sweet. You need a flash simm to burn presets.
For example your E6400 ultra would burn the presets you wanted to the
flash simm you would then power down the sampler open it up remove the
simm open up your MP7 load the simm power up and bada bing bada boom you
have your own custom presets in the MP7.
Later
Patrick
Sent: Sunday, June 29, 2003 11:18 AM
To: xl7@yahoogroups.com
Subject: [xl7] DOES ANYONE HAVE...
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=251812.3170658.4537139.1261774/D=egroupweb/S=1707
709865:HM/A=1564415/R=0/SIG=11t6t7kdo/*http:/www.netflix.com/Default?mqs
o=60164784&partid=3170658>
<http://us.adserver.yahoo.com/l?M=251812.3170658.4537139.1261774/D=egrou
pmail/S=:HM/A=1564415/rand=971496238>
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/>  Terms of Service.
Re: [xl7] DOES ANYONE HAVE...
2003-06-29 by [Mowah]
As a matter of fact, the sampler only "burn" the samples (and it's own
EOS format presets). The presets for the Proteus engine have to be
programmed and stored on the flash from the Command Station itself.
That what I understand from the Sound Authoring Guide at E-Mu's:
http://www.emu.com/products/e4xtUltra/Sound_Author.pdf
> you have your own custom presets in the MP7.
Sebastien,
Why doesn't DOS ever say "Excellent command or filename!"
Hmm I am not sure I understand your post. Page 4 of sound authoring
guide states
In creating Proteus Instruments, only the following EOS preset
parameters
are used. All other EOS preset parameters are ignored.
Preset Name
(becomes the Instrument name in Proteus)
Voice/sample key and velocity windows
Voice/sample fine tuning, volume and pan
Voice amplifier envelope settings
Sample original key
If your saying that the programming of the preset is lost you are
probably correct.
Sent: Sunday, June 29, 2003 11:47 AM
Subject: Re: [xl7] DOES ANYONE HAVE...
Sebastien,
ADVERTISEMENT
<http://rd.yahoo.com/M=244522.3313099.4604523.1261774/D=egroupweb/S=1707
709865:HM/A=1595053/R=0/SIG=124orar12/*http:/ashnin.com/clk/muryutaitake
nattogyo?YH=3313099&yhad=1595053> Click Here!
<http://us.adserver.yahoo.com/l?M=244522.3313099.4604523.1261774/D=egrou
pmail/S=:HM/A=1595053/rand=480686767>
Yes, since presets are not fully compatible between the EOS and the
Proteus. Once you have the basic working "instruments" generated by
the sampler, it seems you still have to re-program the patches on the
Proteus to make proper use of the filters, modulations and so on...
If you're after complex sounds that is. :)
EOS generated Proteus instruments would be okay for custom drumkits I
suppose.
Sorry about the lousy english.
> probably correct.
Sebastien,
please help new xl7 member.
2003-06-29 by maianmusic
hello group.
my name is ANDY i just got the xl7 at the guitar center to day,i am
 very happy with it, i check on the box  my xl7 it verson 1.31 can
some one tell me how to down load the  new verson 2.0 to xl7
                 how to down loads sounds and pattern,thank you very
much for all your help,sorry .. i am get so excited with my new toy.
                                         best wishes.
                                           andy.
Re: please help new xl7 member.
2003-06-30 by M2
Andy,
There should have been a CD that came with your XL.  On it you will
find a program called E-loader.  Install that program on your
computer and make sure that you have a midi interface that will
connect to the XL.  Read the E-loader quick start manual to get you
going quickly.  Below is a link for the 2.0 OS
http://www.emu.com/products/xl7/osdownload.html
Good luck.
--- In xl7@yahoogroups.com, "maianmusic" <maianmusic@y...> wrote:
>       hello group.
very
toy.
>                                          best wishes.
>                                            andy.
2003-06-30 by maianmusic
Is there any way we can use USB port to update the OS or only MDI
port is possible? Thank you very much!
--- In xl7@yahoogroups.com, "M2" <mmcquay@s...> wrote:
> Andy,
> Good luck.
> >       hello group.
am
can
> very
> toy.
> >                                          best wishes.
> >                                            andy.
hello "M2"
thanks for your help,my xl7 now is 2.0 os
i try to downloads p2500.zip to my xl7 but when i play it back it
dont have no sounds i dont know what happen? please let me know..
                                               thanks.
                                                andy.
> Andy,
> Good luck.
> >       hello group.
am
can
> very
> toy.
> >                                          best wishes.
> >                                            andy.
2003-06-30 by M2
Andy,
No problem, I'm glad it worked out for you.  The reason you have no
sounds for the 2500 zip is that you do not have the "POP" ROM that
the presets, patterns and songs look for.  The same goes for the MP-7
information as well, you have to have the ROM to make the sounds play.
Later,
M2
>  hello "M2"
>                                                thanks.
>                                                 andy.
> > Andy,
will
you
> > Good luck.
> > >       hello group.
day,i
> am
> can
> > very
> > toy.
> > >                                          best wishes.
> > >                                            andy.
hello "M2"
 thank you for your help...
                      best wishes.
                        andy.
> Andy,
7
play.
> Later,
> M2
> >  hello "M2"
> >                                                thanks.
> >                                                 andy.
> > > Andy,
> will
> you
> > > Good luck.
wrote:
> > > >       hello group.
> day,i
> > am
1.31
> > can
you
> > > very
new
> > > toy.
> > > >                                          best wishes.
> > > >                                            andy.
