Yamaha CS80 group photo
Yamaha CS80
Index last updated: 2026-04-28 23:44 UTC
CS-80 keybed aftertouch resistors
2011-05-19 by Max Fazio
Hi all
With your kind help , I need to know something about the variable resistors put in the keybed and bound to the aftertouch: according to the big diagram there are 3 of them for each key: in case I'm happening to service an 80 what should be the replacement for them? Ohmic value/tolerance?
Thanks for your help!
M
Re: [yamahacs80] CS-80 keybed aftertouch resistors
2011-05-19 by Laurie Curry
are they really variable??? I thought they were fixed resistors Max...and the carbonised rubber bridge piece squished down to bring them all into the circuit.
To: yamahacs80@yahoogroups.com
Date: 05/19/2011 17:40
Subject: [yamahacs80] CS-80 keybed aftertouch resistors
Hi all
M
2011-05-19 by Andrew Kirkby
Hi Max,
Are you talking about the FSR (force sensing resistor)?
Those are the key and aftertouch sensor...
Andrew
On 20/05/2011, at 8:40 AM, Max Fazio wrote:
> Hi all
> M
Andrew Kirkby
(e) kirkbyte@optusnet.com.au
(m) 0416 000 070
2011-05-20 by Max Fazio
Hi Laurie
yea, I mean, what if one sensor breaks? Could I be able to replace them? Also, my only doubt is that on the diagram it looks like there are three resistors put in series but I'm not sure what yamaha was trying to show there...??!!
+____+
M
  Sent: Friday, May 20, 2011 1:41 AM
  Subject: Re: [yamahacs80] CS-80 keybed aftertouch resistors
  Hi all
  M
Hi Andy
Yes, the FSR , I was referring to the aftertouch sensors anyway...just I
find it odd that yamaha is reporting three resistor symbols for each key on
the diagram, where the aftertouch contacts are drawn...what could that mean?
M
To: <yamahacs80@yahoogroups.com>
Sent: Friday, May 20, 2011 1:45 AM
> Hi Max,
> Andrew
>> Hi all
>> M
> Andrew Kirkby
> (e) kirkbyte@...
> (m) 0416 000 070
2011-05-20 by Andrew Kirkby
Max,
Unless they are not functioning properly i wouldn't try and replace
them. In any case, i have not come across a suitable part in two years
of casual searching. Sensitronics in the USA might be able to make
them - but they would be expensive and a substantial custom order
would be required.
Andrew
On 20/05/2011, at 10:03 AM, Max Fazio wrote:
> Hi Andy
> anyway...just I
> key on
> that mean?
> M
> From: "Andrew Kirkby" <kirkbyte@...>
> > Hi Max,
> > Andrew
> >> Hi all
> >> M
> > Andrew Kirkby
> > (e) kirkbyte@...
> > (m) 0416 000 070
> > Yahoo! Groups Links
Andrew Kirkby
(e) kirkbyte@...
(m) 0416 000 070
Thx Andrew
I understand that, as Sensitronics is one of the few manifacturers who
builds them I could be forced to get a stock of them! just for the record :
are the aftertouch sensors printed on the board? I think yes...any chance to
get the stand-off resistance value for the specific aftertouch resistor in
the CS80? By looking at David's experiment on the aftertouch I can see that
the value can go from 0.00oz---> -0.2V to  90oz-->6.95V, but I think it
doesn't help me findin that value...
M
Sent: Friday, May 20, 2011 2:18 AM
> Max,
> would be required.
> Andrew
>> Hi Andy
>> anyway...just I
>> key on
>> that mean?
>> M
>> ----- Original Message -----
>> > Hi Max,
>> > Andrew
>> >> Hi all
>> >> M
>> > Andrew Kirkby
>> > (e) kirkbyte@...
>> > (m) 0416 000 070
>> > Yahoo! Groups Links
> Andrew Kirkby
> (e) kirkbyte@...
> (m) 0416 000 070
