256e and 210e arent they doing the same thing?
2008-11-14 by cray5656
arent the 256e and 210e doing the same thing with regards to voltage mixing ? If I use the 210e and have 3 CV inputs sent to output 1 thats voltage mixing isnt it? I have 6 panels left and I am trying to decide what I need Cynthia Zoe Model 225e Model 256e Model 285e I like the idea of the 225e but am not interested in playing it in a conventional note system..has someone done a youtube vid of the 225e not set up like an abstract piano?
2008-11-14 by Chris Muir
On Nov 14, 2008, at 4:01 AM, cray5656 wrote: > arent the 256e and 210e doing the same thing with regards to voltage > mixing ? Not really. The 256e allows for many different transformations of a CV, but mixing isn't its strong suit. It can mix two sources but I don't think that it can mix at full scale (the inputs are scaled somewhat when the xfade knob is in the middle). It can invert, scale and can act like a crossfader/VCA on a control signal. It's handy, for sure. > If I use the 210e and have 3 CV inputs sent to output 1 thats > voltage mixing isnt it? Yes, the 210e can mix any proportion of its inputs to any of its outputs. > I like the idea of the 225e but am not interested in playing it in a > conventional note system..has someone done a youtube vid of the 225e > not set up like an abstract piano? Not a video, but many of my drones involve using controller Buss J-P on the 225e and a custom program to create arbitrary shapes for slow "LFO's". A good example is BattleDrone, found on the bottom of http://www.xfade.com/Buchla It has many different shapes and lengths of cycle. 17YearGuest and, to a lesser extent, VoxGong also illustrate this. From my B-Sides page http://xfade.com/Buchla/B_Sides.html Drrrrone uses this technique. I also use a little DJ control surface to send knobs and switches to the 225e. -C Chris Muir cbm@well.com http://www.xfade.com
2008-11-14 by ezra buchla
On Fri, Nov 14, 2008 at 4:01 AM, cray5656 <amni56@tpg.com.au> wrote: > arent the 256e and 210e doing the same thing with regards to voltage > mixing ? If I use the 210e and have 3 CV inputs sent to output 1 thats > voltage mixing isnt it? the 210e allows fully arbitrary but basically non-dynamic mixing of mabny sources and destinations (8x5) the 256e can do dynamic (cv-controlled) scaling, inversion, and fades between (two) cv sources. pretty different... > I have 6 panels left and I am trying to decide what I need > > Cynthia Zoe > Model 225e > Model 256e > Model 285e the 256e seems kindof useless here because you have very few cv sources. i guess i would go with a 291e, which does lots of stuff. > I like the idea of the 225e but am not interested in playing it in a > conventional note system..has someone done a youtube vid of the 225e > not set up like an abstract piano? i don't have any videos, but i've used it for all kinds of stuff. with a computer, it becomes simply a means to produce arbitrary externally-controlled pulses and cvs (limited by MIDI resolution). i used it as the brains for a pretty gnarly abstract 4panel feedback patch at the last NAMM...
2008-11-14 by amnesia
sorry for wasting peoples time I meant the 222e Kin Port not 225e I like the idea of the 222e but am not interested in playing it in a conventional note system..has someone done a youtube vid of the 225e not set up like an abstract piano? > >
With all this talk of new modules do you think we may see a 24 WLS? > >
Is it at all possible that in the future we may see a 222e that doesn't need the touch plates you can just use the rings? Saves loosing 4 spaces. > >
2008-11-15 by damon
Yes, it is called the Lightning 3.
On Nov 14, 2008, at 1:52 PM, amnesia wrote: > Is it at all possible that in the future we may see a 222e that > doesn't > need the touch plates you can just use the rings? > Saves loosing 4 spaces. > > > > > >
2008-11-15 by Alessandro Cortini
oohhhhh snap!
On Nov 14, 2008, at 6:57 PM, damon wrote: > Yes, it is called the Lightning 3. > > > On Nov 14, 2008, at 1:52 PM, amnesia wrote: > >> Is it at all possible that in the future we may see a 222e that >> doesn't >> need the touch plates you can just use the rings? >> Saves loosing 4 spaces. >>> >>> >> >> > > > ------------------------------------ > > Yahoo! Groups Links > > >
2008-11-15 by amnesia
I am confused...Isnt the Lightning 3 a huge touch pad..i was asking about the rings only in a system. Alessandro Cortini wrote:
> > oohhhhh snap! > > On Nov 14, 2008, at 6:57 PM, damon wrote: > > > Yes, it is called the Lightning 3. > > > > > > On Nov 14, 2008, at 1:52 PM, amnesia wrote: > > > >> Is it at all possible that in the future we may see a 222e that > >> doesn't > >> need the touch plates you can just use the rings? > >> Saves loosing 4 spaces. > >>> > >>> > >> > >> > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > >
2008-11-15 by JB
Lightning is a very advanced midi controller that translate gestures in three dimensional space into midi but its not just X,Y,Z like the 222e, Lightning is a much more versatile programmable instrument. You can divide space into individual zones, it detects strikes in different directions tha can trigger notes, you can do "strums" and pitch can be set to follow certain scales etc etc etc. Lightning can be controlled with the wands its usually pictured with, but i think the 222e rings will work as well, there were some other kinds of devices to swing in air as well made for the first two versions of Lightning. This is a description of Lightning II: http://www.buchla.com/lightning/descript.html 2008/11/15 amnesia <amni56@tpg.com.au>:
> I am confused...Isnt the Lightning 3 a huge touch pad..i was asking > about the rings only in a system. > > Alessandro Cortini wrote: >> >> oohhhhh snap! >> >> On Nov 14, 2008, at 6:57 PM, damon wrote: >> >> > Yes, it is called the Lightning 3. >> > >> > >> > On Nov 14, 2008, at 1:52 PM, amnesia wrote: >> > >> >> Is it at all possible that in the future we may see a 222e that >> >> doesn't >> >> need the touch plates you can just use the rings? >> >> Saves loosing 4 spaces. >> >>> >> >>> >> >> >> >> >> > >> > >> > ------------------------------------ >> > >> > Yahoo! Groups Links >> > >> > >> > >> >> > > ------------------------------------ > > Yahoo! Groups Links > > > >
2008-11-16 by amnesia
Ahhh I was thinking Lightning was the marimba..oops
2008-11-17 by cuari7
What about one with a chromatic 12-note scale (no offense to the Fire Bird....) like the original Kinesthetic Input Port? A frequently underestimated value of touchplates is the fact that they trigger with minimal effort, thereby decreasing repetitive stress and risk of tendinitis. As a long-time tendinitis and carpal tunnel sufferer, I would love to have one of these. Ezra? jd > Is it at all possible that in the future we may see a 222e that doesn't
2008-11-17 by ezra buchla
most of the function of the panel is to configure and create complex routings of the huge amount of data sent frmo the touch pad (velocity, position, pressure, and key numbers...) the rings just send pretty much raw x/y/z out the banana jacks ...so if you threw out the touchplate there wouldn't be much left for the module to do. arguably not worth its space... lightning 3, on the other hand, is focussed on letting the user create arbitrary and sophisticated carvings-up of the physical and gestural spaces perceived by the x/y/z sensor...
On Fri, Nov 14, 2008 at 1:52 PM, amnesia <amni56@tpg.com.au> wrote: > Is it at all possible that in the future we may see a 222e that doesn't > need the touch plates you can just use the rings? > Saves loosing 4 spaces. >> >> > >
well, i gess the answer to all these kinds of questions of "how about xyz module" is that don is going to continue designing the things that HE wants, pretty much regardless of demand. and he shows no signs of running out of ideas... i played a lot of Thunder as a kid. piano too. fact is, it's a lot easier than you might expect to play chromatic music on that layout, once you consider the ability to create arbitrary scale mappings and transposition toggles. fwiw, ymmv
On Mon, Nov 17, 2008 at 3:00 PM, cuari7 <cuari7@comcast.net> wrote: > What about one with a chromatic 12-note scale (no offense to the Fire > Bird....) like the original Kinesthetic Input Port? A frequently > underestimated value of touchplates is the fact that they trigger with > minimal effort, thereby decreasing repetitive stress and risk of > tendinitis. As a long-time tendinitis and carpal tunnel sufferer, I > would love to have one of these. > Ezra? > > jd > >> Is it at all possible that in the future we may see a 222e that > doesn't >> need the touch plates you can just use the rings? >> Saves loosing 4 spaces. >> > >> > >> > >
2008-11-17 by Chris Muir
On Nov 17, 2008, at 3:28 PM, ezra buchla wrote: > i played a lot of Thunder as a kid. piano too. fact is, it's a lot > easier than you might expect to play chromatic music on that layout, > once you consider the ability to create arbitrary scale mappings and > transposition toggles. fwiw, ymmv I played a lot of Thunder when Ezra was a kid, too. :-) He's absolutely right about the transposition toggle thing. It's a really interesting way to slide up and down in pitch space. My main complaint with Thunder (which I think has gotten better on the 222e) is that the touch went from feather-light to lightweight. Within its range it was smooth, but it was really easy hang out at the top of the dynamic range. -C Chris Muir cbm@well.com http://www.xfade.com
