My patches
2004-06-30 by Rocky Rodenbach
As promised, here are some of my patches I wrote many years ago, let me know what you think I omited some names, but you should figured it out. Example "Vibrato" wave 1 Delay 2, etc Echo Synth Line select 1+1 Ring/noise off/off Detune + 0 00 10 Vibrato 1 07 53 20 Oct +1 DCO1 Wave form First 4 Second 1 Rate 00 Level 00 DCW1 Key follow 0 1 Rate 99 Level 99 2 Rate 83 Level 96 3 Rate 37 Level 83 SUS 4 Rate 41 Level 00 END DCA1 Keyfollow 0 1 Rate 99 Level 99 SUS 2 Rate 87 Level 48 3 Rate 48 Level 99 4 Rate 41 Level 00 END Resno Synth Line Select 1+1 Ring/Noise off off Detune + 0 00 06 Vibrato 1 00 00 00 Octave 0 DC01 Waveform First 7 Second 4 1 Rate 99 Level 33 2 Rate 68 Level 00 END DCW1 Keyfollow 0 1 Rate 76 Level 99 2 Rate 47 Level 96 3 Rate 37 Level 52 SUS 4 Rate 26 Level 00 END DCA1 Keyfollow 0 1 Rate 99 Level 50 2 Rate 77 Level 99 3 Rate 67 Level 91 SUS 4 Rate 79 Level 59 5 Rate 33 Level 00 END Filer Sweep Line Select 1+1 Ring/Noise off off Detune + 0 00 10 Vibrato 1 07 53 18 Octave 0 DCO1 Waveform First 4 Second 4 1 Rate 00 Level 00 END DCW1 Keyfollow 8 1 Rate 42 Level 99 2 Rate 34 Level 00 END DCA Keyfollow 0 1 Rate 93 Level 87 SUS 2 Rate 41 Level 00 END Panic in Detroit Line Select 1+2 Ring/Noise off off Detune + 0 00 06 Vibrato 1 07 53 19 Octave +1 DCO1 Waveform First 2 Second 4 1 Rate 97 Level 64 SUS 2 Rate 26 Level 29 3 Rate 40 Level 99 4 Rate 50 Level 00 END DCW1 Keyfollow 5 1 Rate 99 Level 99 2 Rate 83 Level 96 3 Rate 37 Level 83 SUS 4 Rate 41 Level 00 END DCA1 Keyfollow 0 1 Rate 99 Level 96 SUS 2 Rate 16 Level 00 END DCO2 Waveform First 5 Second 6 1 Rate 30 Level 99 SUS 2 Rate 49 Level 27 3 Rate 50 Level 00 END DCW2 Keyfollow 0 1 Rate 43 Level 99 SUS 2 Rate 25 Level 62 3 Rate 37 Level 83 4 Rate 41 Level 00 END DCA2 Keyfollow 0 1 Rate 93 Level 99 2 Rate 21 Level 00 END. 1
