CZ-101 freezes up on powerup
2007-04-10 by lextoevs
Index last updated: 2026-04-28 22:42 UTC
Hi, Just joined to see if i could get some help. My CZ-101 started to freeze up on me on a few seconds after power-up. When i add power its fine then a few seconds later i hear a high pitched click come from the inside right near where the AC adapter plugs in. Any Ideas? thanks! alex
2007-04-10 by Simon Beck
That click is a mechanical sound rather than an electronic one and is probably coming from a relay or some kind of thermal cutoff device. Are you using the correct power supply? Simon
----- Original Message ----- From: lextoevs To: CZsynth@yahoogroups.com Sent: Tuesday, April 10, 2007 11:14 PM Subject: [CZsynth] CZ-101 freezes up on powerup Hi, Just joined to see if i could get some help. My CZ-101 started to freeze up on me on a few seconds after power-up. When i add power its fine then a few seconds later i hear a high pitched click come from the inside right near where the AC adapter plugs in. Any Ideas? thanks! alex ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.446 / Virus Database: 269.0.0/754 - Release Date: 09/04/2007 22:59 [Non-text portions of this message have been removed]
2007-04-10 by narfman96
There is also a classic sound a bad capacitor makes. It whines as it tries to charge then it snaps when it finally shorts. Best to have a look. Make sure you have glasses on if you power it up sometimes they blow up. Fran --- In CZsynth@yahoogroups.com, "Simon Beck" <simon@...> wrote: > > That click is a mechanical sound rather than an electronic one and is probably coming from a relay or some kind of thermal cutoff device. Are you using the correct power supply? > > Simon > > ----- Original Message ----- > From: lextoevs > To: CZsynth@yahoogroups.com > Sent: Tuesday, April 10, 2007 11:14 PM > Subject: [CZsynth] CZ-101 freezes up on powerup > > > Hi, > > Just joined to see if i could get some help. My CZ-101 started to freeze up on me on a few > seconds after power-up. When i add power its fine then a few seconds later i hear a high > pitched click come from the inside right near where the AC adapter plugs in. Any Ideas? > > thanks! > > alex > > > > > > > -------------------------------------------------------------------- ---------- > > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.446 / Virus Database: 269.0.0/754 - Release Date: 09/04/2007 22:59
> > > [Non-text portions of this message have been removed] >
2007-04-11 by lextoevs
i agree that it is likely on the mechanical end of things. i do have the correct power supply but when i found it, it had a 13v instead of a 9v plugged into it. thanks! alex --- In CZsynth@yahoogroups.com, "Simon Beck" <simon@...> wrote: > > That click is a mechanical sound rather than an electronic one and is probably coming from a relay or some kind of thermal cutoff device. Are you using the correct power supply? > > Simon > > ----- Original Message ----- > From: lextoevs > To: CZsynth@...m > Sent: Tuesday, April 10, 2007 11:14 PM > Subject: [CZsynth] CZ-101 freezes up on powerup > > > Hi, > > Just joined to see if i could get some help. My CZ-101 started to freeze up on me on a few > seconds after power-up. When i add power its fine then a few seconds later i hear a high > pitched click come from the inside right near where the AC adapter plugs in. Any Ideas? > > thanks! > > alex > > > > > > > ---------------------------------------------------------------------------- --
> > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.446 / Virus Database: 269.0.0/754 - Release Date: 09/04/2007 22:59 > > > [Non-text portions of this message have been removed] >
that might be it. i do not really hear the whine but it does snap after as if it just charged up. when i found it a 13v instead of a 9v adapter was plugged into it, i got the 9v now... can't say i can id a capacitor on a board, when i opened it up nothing showed damage. thanks! alex --- In CZsynth@yahoogroups.com, "narfman96" <narfman96@...> wrote:
> > There is also a classic sound a bad capacitor makes. It whines as it > tries to charge then it snaps when it finally shorts. Best to have a > look. Make sure you have glasses on if you power it up sometimes they > blow up. > > Fran > > --- In CZsynth@yahoogroups.com, "Simon Beck" <simon@> wrote: > > > > That click is a mechanical sound rather than an electronic one and > is probably coming from a relay or some kind of thermal cutoff > device. Are you using the correct power supply? > > > > Simon > > > > ----- Original Message ----- > > From: lextoevs > > To: CZsynth@yahoogroups.com > > Sent: Tuesday, April 10, 2007 11:14 PM > > Subject: [CZsynth] CZ-101 freezes up on powerup > > > > > > Hi, > > > > Just joined to see if i could get some help. My CZ-101 started to > freeze up on me on a few > > seconds after power-up. When i add power its fine then a few > seconds later i hear a high > > pitched click come from the inside right near where the AC > adapter plugs in. Any Ideas? > > > > thanks! > > > > alex > > > > > > > > > > > > > > -------------------------------------------------------------------- > ---------- > > > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.446 / Virus Database: 269.0.0/754 - Release Date: > 09/04/2007 22:59 > > > > > > [Non-text portions of this message have been removed] > > >
