To: CZsynth@yahoogroups.com
Sent: Thursday, 21 June 2012, 16:52
Subject: Re: [CZsynth] Re: Any help with an old CZ1000?
Then again, I'm not absolutely sure. There may be tactile switches in there. Your only recourse then, would be to unsolder them, and install new ones. Whenadding the 101 cartridge memory doubling circuit, I did not go in deep enough to make sure.
rig
Sent: Wednesday, June 20, 2012 12:52 PM
Subject: [CZsynth] Re: Any help with an old CZ1000?
Thanks for your replies! They at least give me something to ponder. I'll have some time next week to look into trying the foil trick and will let you know how I fare!
Thanks again, Scott
--- In CZsynth@yahoogroups.com, Lee Borrell <templarser@...> wrote:
> Hahah - the tin foil in the hole punch - I confess to being a poor man - I have got a few remote controls and Yamaha PSS going with that trick!
> From: bill bigrig <billbigrig@...>
> To: "CZsynth@yahoogroups.com" <CZsynth@yahoogroups.com>
> Sent: Wednesday, 20 June 2012, 14:00
> Subject: Re: [CZsynth] Any help with an old CZ1000?
> Â
> Yes, this is a problem with older Alesis sequncers. You take the switches apart. If they have little black "hockey pucks", you can buy a liquid to brush on and restore them. The poor man's solution is to use a paper punch, punch out a bunch of tin foil disks, and glue them to the black "pucks".
> Rig
> From: Lee Borrell <templarser@...>
> Sent: Wednesday, June 20, 2012 3:45 AM
> Â
> I've not actually looked into that - but I daresay trying to solve that one will be not the easiest thing in the world.Perhaps it would be possible to rip it out altogether and replace the whole thing with proper switches - a la CZ101?
> From: Scott <gl2tgr@...>
> Sent: Tuesday, 19 June 2012, 21:58
> Subject: [CZsynth] Any help with an old CZ1000?
> Â
> Hi folks, I just joined hoping for some help. A friend made me a "permanent loan" of an old CZ1000. It works but some of the membrane switches are either iffy are just don't work at all.
> I did search this forum for "membrane" and a couple of other things. While I did find a few posts like this one, I found no responses or help.
> So I'm just wondering, is there any conventional wisdom on this? Anything like "spray this stuff on them" or "you can replace them but it's a hassle" or "forget it, it's not worth it" etc.
> All opinions are welcome.
> Thanks! Scott
