--- In DTXpress@yahoogroups.com, "Keith" <keith@...> wrote:
> --- In DTXpress@yahoogroups.com, "doxxon3" <doxxon3@> wrote:
> > Using stock settings on my DTXIII with the TP65S, I'm get rim 2
sounds
> > on rim 1, which I am sure I'm striking. It happens occasionally,
but is
> > becoming more frequent. My kit is only about 5 mo. old so I
wouldn't
> > think anything is loose in there. I couldn't find anything in
archives
> > on this...anyone had this issue?
> Both the rims use a switch, with the rim 2 switch having a 10k
> resistor in series with it. If you are getting rim2 sounds from rim
> 1, it suggests the rim has a higher resistance than it should have.
> This could be due to a bad connection (or cable) or, more likely, a
> faulty rim switch. As it is fairly new it would be worthwhile
getting
> it swapped under warranty after eliminating the cable as a possible
cause.
> Keith.
Thanks Keith, I will do that.
Corey
