Help!
Help!
2004-02-18 by Jimmy Manfredi
Does anyone have the recommended settings for the combination of the
DTXpress II module with Pintech ConcertCast pads? I had them at one
time, but have since replace them. Thanks.
Jim
Re: Help!
2004-02-18 by emf
--- In DTXpress@yahoogroups.com, "Jimmy Manfredi" <jmanfred@r...>
Jim,
I may not be getting exactly what you want, but I remember having my
best luck setting the pad types to the "DT" options, the trigger
setup to DT10/20 (which eventually evolved into a user setting), and
the relevant DIP "attentuation" (a misnomer) switches on the back of
the module to the high position. Gain, min. velocity, rejection, etc.
varied with a pad's position on the rack and its desired response.
The dynamic range of the Pintechs through the DTXpress is not to
everyone's liking; some people complain that it shortchanges the
lighter touch. Insertion of 200k pots between the pads and the
module's inputs may help. Brian LaRue told me that Pintech may
consider adding a sensitivity adjustment on its pads themselves to
tame the high gain with Yamaha modules.
Ed
Re: [DTXpress] Re: Help!
2004-02-18 by Jim Manfredi
Ed,
I'm selling off the kit that I have been using to a mechanical engineer friend at work and that is where the previous question on trigger setting comes from. Also... Is there another input on the DTXII module that will produce the rim sound for the Pintech snare beside 9/10? He would kind of like to leave that input free for other things if possible. I decided to hold on to the DTXtreme module, just in case I feel the need to expand the ddrum4 kit, which is supposed to be delivered tomorrow. Thanks for your reply.
Jim
Sent: Wednesday, February 18, 2004 2:39 PM
Subject: [DTXpress] Re: Help!
Jim,
Ed
Community email addresses:
Post message: DTXpress@yahoogroups.com
Subscribe: DTXpress-subscribe@yahoogroups.com
Unsubscribe: DTXpress-unsubscribe@yahoogroups.com
List owner: DTXpress-owner@yahoogroups.com
Shortcut URL to this page:
http://groups.yahoo.com/group/DTXpress
Alternate DTXpress site:
http://www.dtxpressions.com
Re: Help!
2004-02-18 by emf
--- In DTXpress@yahoogroups.com, "Jim Manfredi" <jmanfred@r...> wrote:
> Ed,
Jim,
The rim would have to take up its own input. Suggest that your friend
look into a discontinued Kat MIDIkiti or Roland PM-16 trigger-to-MIDI
devices to expand the module cheaply (under $100). Roland's current
TMC-6 can be had these days for a little more than $200. If you want
more info, contact me offline. Good move holding onto the DTXtreme.
I'll wager that you find a use for it.
Ed
Ed
