Ok here is a good one...
2004-03-16 by gatormikeb
Is it just me or dose yamaha not know how to setup the cymbal pads
to do rolls... I use to have a roland TD7 Kit and could do rolls on
the cymbals.  Is this because of the brain or the triggers, or
both?  Do I need to look into a roland module for my cymbal triggers.
Re: Ok here is a good one...
2004-03-17 by moosetication
> the cymbal pads to do rolls... Is this because of
> the brain or the triggers, or both?
It's Yamaha, and it's the module. It retriggers the sound
from "scratch" (that is, from zero volume) every time the cymbal is
triggered.
Stewart
2004-03-17 by emf
triggers.
Are you saying that the TD-7 conquered the machine-gun effect? Hard
to believe. As Stewart says, it's largely the module, but basically
all Roland, Yamaha, and Alesis modules in the past have suffered from
the same disease; the more expensive ones are able to mitigate it
better. The new Roland TD-20 is a major advance, but the ten-year-old
ddrum4 module is pretty good, too. Don't go buying a TD-3 or TD-6
expecting to hear perfect cymbal swells. As for the DTXP module,
different companies' cymbals can reduce the effect a little, as can
certain voices with the decay set just right.
