Korg DW8000, Mono/Poly, MS-20...
Questionably functional DW-8000...?
2006-02-05 by altamontunion
Heyo,
I just recently acquired a DW8000 for $15. Solid! However, the owner
said that while the keyboard had been in storage, it has sustained
heavy water damage. The keyboard looked mint, so I scooped it up
anyways. If it didn't work, no worry, was worth a try.
Well, I get it home and realize he'd left the old C or D batteries in
the back, and they'd leaked everywhere. I took them out, plugged the
machine in, and fiddled around. I've never used a DW8000 before.
It was making noises, but the only noises it would make when I
pressed any key was this siren-esque descending BBEEEEEOOOOOOOO. I
decided to crack it open and replace the CR2032 battery.
Ouch.
The case was literally filled with rust, but it appeared that every
single component was still in the right place. It looked like the
only damage done was to the metal bottom! I spent all day cleaning it
out, and I replaced the CR2032 battery. (I hope my amateurish
soldering jobs were okay!)
I fired it up -- yep, still powers up and looks fine -- and I tried
using a SysEx program to load on patches. I can tell that MIDI is
working, because I can control the DW8000 with my computer.
Unfortunately, I've tried loading a bunch of different SYX sets, and
still all I get is that obnoxious siren noise. Any ideas?
Re: [DW8000] Questionably functional DW-8000...?
2006-02-06 by Mark B
altamontunion wrote:
> I just recently acquired a DW8000 for $15. <SNIP>
It would seem that you still haven't used a DW8000, as the DW8000 does not
run off C or D battery power.  You probably have a Poly800.
Maybe take a look at the top, see what it really is and write back?
2006-02-07 by Mike Henry
Dw8000 did have a battery that looked like a D cell that was soldered in. Sounds like he has it back but doesn't have the sounds in right
Sent: Monday, February 06, 2006 4:34 PM
Subject: Re: [DW8000] Questionably functional DW-8000...?
2006-02-07 by Mark B
Um, no.  There are no D cell batteries or any battery even remotely the size
of a D battery in a DW8000, much less "batteries [plural] in the back".
There is a CR2032 battery on the mainboard, but he also mentioned that in
the same email.
He's got to be talking about a Poly 800 or similar, which can actually run
off C batteries.
Re: Questionably functional DW-8000...?
2006-02-07 by altamontunion
D'oh!
Sure enough, I jumbled my words a bit. I acquired a DW-8000 AND a
Poly-800 at the same time; the corroded C cells were found in the
back of the Poly-800, not the DW-8000.
My DW-8000 has no compartment for C or D cells. The battery I
replaced (or attempted to) was the 3V CR2032 that was soldered onto
the one of boards inside.
Anyone know where WAV versions of the tape backups are? I'm still not
having any success w/ the SYSEX, and I haven't got around to checking
to see if the key contacts are corroded.
--- In DW8000@yahoogroups.com, Mark B <Bugsi@...> wrote:
soldered in.
the size
back".
that in
> the same email.
actually run
> off C batteries.
The cr2032 was a replacement but the original battery looked like a d cell battery that was soldered to the board.
Sent: Monday, February 06, 2006 10:33 PM
the same email.
off C batteries.
the same email.
off C batteries.
2006-02-07 by Stefan Rinass
Possible-as long the voltages are correct it doesn\ufffdt matter which type
of Batteries are in use (why it should?). But, shame on me, what is
difference between a "c" and a "d" cell? I only know aa/aaa, then their
typical "german" designations: Mono, Baby, Mignon, Micro (Photo?) etc...
Greetings
Stef
>     ----- Original Message -----
>     *From:* Mark B <mailto:Bugsi@...>
>     *To:* DW8000@yahoogroups.com <mailto:DW8000@yahoogroups.com>
>     *Sent:* Monday, February 06, 2006 10:33 PM
>     *Subject:* Re: [DW8000] Questionably functional DW-8000...?
>     soldered in.
>     remotely the size
>     back".
>     that in
>     the same email.
>     actually run
>     off C batteries.
>     SPONSORED LINKS
>     Electronic instrument
>     <http://groups.yahoo.com/gads?t=ms&k=Electronic+instrument&w1=Electronic+instrument&w2=Korg+synthesizer&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=148&.sig=rAs5mrkvyis7q-WZRneFzA>
>     	Korg synthesizer
>     <http://groups.yahoo.com/gads?t=ms&k=Korg+synthesizer&w1=Electronic+instrument&w2=Korg+synthesizer&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=148&.sig=SbYYKdNCJzkuxY-pwIsB7A>
>     	Synthesizer music
>     <http://groups.yahoo.com/gads?t=ms&k=Synthesizer+music&w1=Electronic+instrument&w2=Korg+synthesizer&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=148&.sig=MsKtImh4uPk1GrzIhlDf_Q>
>     Electronic music
>     <http://groups.yahoo.com/gads?t=ms&k=Electronic+music&w1=Electronic+instrument&w2=Korg+synthesizer&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=148&.sig=JnJky7zeTDbfMnWIQ0g6pA>
>     	Music sampler
>     <http://groups.yahoo.com/gads?t=ms&k=Music+sampler&w1=Electronic+instrument&w2=Korg+synthesizer&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=148&.sig=XCY6Jj_zx1t-Ti774-yx2g>
>     	Electronic musical instrument
>     <http://groups.yahoo.com/gads?t=ms&k=Electronic+musical+instrument&w1=Electronic+instrument&w2=Korg+synthesizer&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=148&.sig=GI3Zlhi2q8YSDLoaiY2XXA>
>     YAHOO! GROUPS LINKS
>         *  Visit your group "DW8000
>           <http://groups.yahoo.com/group/DW8000>" on the web.
>         *  To unsubscribe from this group, send an email to:
>            DW8000-unsubscribe@yahoogroups.com
>           <mailto:DW8000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>         *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>           Service <http://docs.yahoo.com/info/terms/>.
Ah, "c" is "baby", "d" is "Mono", right?
Stef
> Greetings
> Stef
> >     soldered in.
> >     remotely the size
> >     back".
> >     that in
> >     the same email.
> >     actually run
> >     off C batteries.
> >     SPONSORED LINKS
> <http://groups.yahoo.com/gads?t=ms&k=Electronic+instrument&w1=Electronic+instrument&w2=Korg+synthesizer&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=148&.sig=rAs5mrkvyis7q-WZRneFzA>>
> >           Korg synthesizer
> <http://groups.yahoo.com/gads?t=ms&k=Korg+synthesizer&w1=Electronic+instrument&w2=Korg+synthesizer&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=148&.sig=SbYYKdNCJzkuxY-pwIsB7A>>
> >           Synthesizer music
> <http://groups.yahoo.com/gads?t=ms&k=Synthesizer+music&w1=Electronic+instrument&w2=Korg+synthesizer&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=148&.sig=MsKtImh4uPk1GrzIhlDf_Q>>
> >     Electronic music
> <http://groups.yahoo.com/gads?t=ms&k=Electronic+music&w1=Electronic+instrument&w2=Korg+synthesizer&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=148&.sig=JnJky7zeTDbfMnWIQ0g6pA>>
> >           Music sampler
> <http://groups.yahoo.com/gads?t=ms&k=Music+sampler&w1=Electronic+instrument&w2=Korg+synthesizer&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=148&.sig=XCY6Jj_zx1t-Ti774-yx2g>>
> <http://groups.yahoo.com/gads?t=ms&k=Electronic+musical+instrument&w1=Electronic+instrument&w2=Korg+synthesizer&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=148&.sig=GI3Zlhi2q8YSDLoaiY2XXA>>
> >     YAHOO! GROUPS LINKS
> SPONSORED LINKS
> 	Korg synthesizer
> 	Synthesizer music
> Electronic music
> 	Music sampler
> YAHOO! GROUPS LINKS
Re: [DW8000] Re: Questionably functional DW-8000...?
http://www.pallium.com/bryan/dw8000.php#TapeDumps
Stef
> D'oh!
> soldered in.
> the size
> back".
> that in
> > the same email.
> actually run
> > off C batteries.
> SPONSORED LINKS
> 	Korg synthesizer
> 	Synthesizer music
> Electronic music
> 	Music sampler
> YAHOO! GROUPS LINKS
2006-02-07 by Garold Carson
Everything is on the website!
> Stef
> > D'oh!
> a DW-8000 AND a
> were found in the
> The battery I
> was soldered onto
> are? I'm still not
> around to checking
> wrote:
> cell that was
> > soldered in.
> the sounds in right
> > the size
> [plural] in the
> > back".
> he also mentioned
> > that in
> > > the same email.
> similar, which can
> > actually run
> > > off C batteries.
> > SPONSORED LINKS
> > 	Korg synthesizer
> > 	Synthesizer music
> > Electronic music
> > 	Music sampler
> > YAHOO! GROUPS LINKS
> the web.
> email to:
> Yahoo! Terms of
Do You Yahoo!?
http://mail.yahoo.com
Awesome, you nailed it -- thank you Stef. Let's see if I can get this
$15 DW-8000 to rock!
> Stef
> > D'oh!
onto
not
checking
> > --- In DW8000@yahoogroups.com, Mark B <Bugsi@> wrote:
> > soldered in.
right
remotely
> > the size
> > back".
mentioned
> > that in
> > > the same email.
> > actually run
> > > off C batteries.
> > SPONSORED LINKS
> > 	Korg synthesizer
> > 	Synthesizer music
> > Electronic music
> > 	Music sampler
> > YAHOO! GROUPS LINKS
2006-02-09 by altamontunion
Well, I've just about given up. I've tried the TAPE reloading as the
manual explains, and it's not hearing anything, no matter what the
source of the sound is -- I've used different volume levels,
different known-working cables -- no luck. SysEx loading of patches
doesn't work, either, but I've only tried using one DW8000 software
that looks like it was coded for Win 3.1.
I think the contacts might not be in such good shape. Any suggestions
on cleaning / replacing 'em? And anybody got any good DW8000 SysEx
software?
--- In DW8000@yahoogroups.com, "altamontunion" <altamontunion@...>
this
> > Stef
> > > D'oh!
a
> onto
still
> not
> checking
> > > soldered in.
> right
> remotely
> > > the size
> > > back".
> mentioned
> > > that in
> > > > the same email.
> > > actually run
> > > > off C batteries.
> > > SPONSORED LINKS
> > > 	Korg synthesizer
> > > 	Synthesizer music
> > > Electronic music
> > > 	Music sampler
> > > YAHOO! GROUPS LINKS
of
2006-02-10 by Stefan Rinass
Well, i would suggest you to check out Midi-OX, a fantasic program for
SysEX-Files and Midi-Monitoring. It's possible to check out with a
speaker the signals itself, specially those which are coming from the
CPU-Board in order to find out where the problem is, but that's too
complex to explain. No sound can come from everything: Defect DCO's,
VCA's, VCF's..or a simple defect Volume potentiometer. The VCA can be
tested relative simple: Just turn the Volume 100% on the DW and 100% on
your amplifier (as loud as possible, so you'll only hear some backroudn
noise from the amplifier), then press a key on the DW. If you hear a
quiet "noise-shot", then the VCA's should be ok; maybe you'll even hear
a quiet sound from the VCO's. If the VCA won't work Even check out the
System Parameters #87 and #88, as far as i remember, one of them make
the play-range of the keyboard. Midi-OX has afair also a simple built-in
keyboard, just try to play a Midi-note to your DW.
While loading the tape files, do you see that the DW begins to write the
values into the memory (the DW -must- run/display -by itself- through
the programs 11-88 and some parameter Values while loading the wave
file)? If not, check out if your PC is loud enough while playback.
Greetings
Stef
> software?
> this
> > > Stef
> > > > D'oh!
> a
> the
> > onto
> still
> > not
> > checking
> > > > soldered in.
> > right
> > remotely
> > > > the size
> the
> > > > back".
> > mentioned
> > > > that in
> > > > > the same email.
> > > > actually run
> > > > > off C batteries.
> > > > SPONSORED LINKS
> > > >       Korg synthesizer
> > > >       Synthesizer music
> > > > Electronic music
> > > >       Music sampler
> > > > YAHOO! GROUPS LINKS
> of
> SPONSORED LINKS
> <http://groups.yahoo.com/gads?t=ms&k=Electronic+instrument&w1=Electronic+instrument&w2=Synthesizer+music&w3=Electronic+music&w4=Music+sampler&w5=Electronic+musical+instrument&c=5&s=126&.sig=j3TK8h6GNpD5AMFN0TJA3A>
> 	Synthesizer music
> <http://groups.yahoo.com/gads?t=ms&k=Synthesizer+music&w1=Electronic+instrument&w2=Synthesizer+music&w3=Electronic+music&w4=Music+sampler&w5=Electronic+musical+instrument&c=5&s=126&.sig=tmTLRMUurlUEhehue_lx3A>
> 	Electronic music
> <http://groups.yahoo.com/gads?t=ms&k=Electronic+music&w1=Electronic+instrument&w2=Synthesizer+music&w3=Electronic+music&w4=Music+sampler&w5=Electronic+musical+instrument&c=5&s=126&.sig=PkktJzelnl06zWnwP49VaA>
> Music sampler
> <http://groups.yahoo.com/gads?t=ms&k=Music+sampler&w1=Electronic+instrument&w2=Synthesizer+music&w3=Electronic+music&w4=Music+sampler&w5=Electronic+musical+instrument&c=5&s=126&.sig=gWsxSSKEGxZQckBqBLtSXg>
> <http://groups.yahoo.com/gads?t=ms&k=Electronic+musical+instrument&w1=Electronic+instrument&w2=Synthesizer+music&w3=Electronic+music&w4=Music+sampler&w5=Electronic+musical+instrument&c=5&s=126&.sig=0ggbCcIf2B7r1P8g9cEGtw>
> YAHOO! GROUPS LINKS
2006-02-12 by Glen Stegner
The DW-8000 editor/librarian made by Anthony Ruggieri (win 3.1) is still
a much better option than generic SysEx software, and it will run on
95/98/Me/2000/XP systems just fine.  It allows you to do whole bank
transfers, as the DW8000 SysEx capability only allows for single patch
transfers (the software automatically loops 64 patch transfers by
itself, you'd have to code that yourself or do it manually using a
generic SysEx utility).
Also the DW8000 does not have DCOs or VCOs, it's purely digital
oscillators (DOs, if you will) or single-cycle SAMPLED waveforms.
on
backroudn
hear
built-in
> Greetings
> Stef
suggestions
> > software?
> > --- In DW8000@yahoogroups.com, "altamontunion" altamontunion@
> > this
> > > > Stef
> > > > > D'oh!
AND
> > a
> > the
> > > onto
> > still
> > > not
> > > checking
was
> > > > > soldered in.
> > > right
> > > remotely
> > > > > the size
> > the
> > > > > back".
> > > mentioned
> > > > > that in
> > > > > > the same email.
can
> > > > > actually run
> > > > > > off C batteries.
> > > > > SPONSORED LINKS
> > > > > Korg synthesizer
> > > > > Synthesizer music
> > > > > Electronic music
> > > > > Music sampler
> > > > > YAHOO! GROUPS LINKS
> > of
> > SPONSORED LINKS
<http://groups.yahoo.com/gads?t=ms&k=Electronic+instrument&w1=Electronic\
+instrument&w2=Synthesizer+music&w3=Electronic+music&w4=Music+sampler&w5\
> > Synthesizer music
<http://groups.yahoo.com/gads?t=ms&k=Synthesizer+music&w1=Electronic+ins\
trument&w2=Synthesizer+music&w3=Electronic+music&w4=Music+sampler&w5=Ele\
> > Electronic music
<http://groups.yahoo.com/gads?t=ms&k=Electronic+music&w1=Electronic+inst\
rument&w2=Synthesizer+music&w3=Electronic+music&w4=Music+sampler&w5=Elec\
> > Music sampler
<http://groups.yahoo.com/gads?t=ms&k=Music+sampler&w1=Electronic+instrum\
ent&w2=Synthesizer+music&w3=Electronic+music&w4=Music+sampler&w5=Electro\
<http://groups.yahoo.com/gads?t=ms&k=Electronic+musical+instrument&w1=El\
ectronic+instrument&w2=Synthesizer+music&w3=Electronic+music&w4=Music+sa\
mpler&w5=Electronic+musical+instrument&c=5&s=126&.sig=0ggbCcIf2B7r1P8g9c\
EGtw>
> > YAHOO! GROUPS LINKS
2006-02-12 by Stefan Rinass
Am Sonntag, den 12.02.2006, 14:55 +0000 schrieb Glen Stegner:
Hm....
Quote:
"Oscillator operation
The PAI (phase angle increment) value and PAR (phase
angle register) value are added and the result is stored again
in the PAR. The PAR value is used as the wave table ad-
dress. The wave table stores different -harmonic- configura-
tion data for each octave on the keyboard.
IC47 (MB64H129) performs the processing needed to use
the PAR value as the wave table address.
Finally, data read from the wave table is converted to an
analog waveform by a D/A converter.
Time division multiplexing enables dual oscillator 6-voice
sound source capability.
Maximum simultaneous output of this system is 8 voices
x 2 oscillators.
Note: Given a sampling frequency of 50 kHz, PAI data
N = 2" x f/50 x 10\u2018 (where f is the pitch frequency)
is rounded to an integer value for N and converted
to a hexadecimal number."
________________________________________________________________________
2006-02-13 by Glen Stegner
> Hm....
> Quote:
> x 2 oscillators.
> N = 2" x f/50 x 10‘ (where f is the pitch frequency)
Is this supposed to contradict what I said?  Whom are you quoting?  As
far as I can tell this just gives info about how the circiuts
interpolate the digital waveforms.  Of course all digital waveforms come
out as analog in the output stage.  Everything is analog at the output
stage or else you wouldn't be able to hear it.  It doesn't mean the
oscillators are analog.
2006-02-13 by Stefan Rinass
I know that they� re not analogue, but the way how they build their
sound-"data" seems to be not the typical "sampling" (or "rompler" or
whatever). Harmonic Synthesis (as the DW6/8000 seems to use) isn�t the
typical "sample" Playback. After the signal leaves the CPU=>DAC-08 it is
-of course- analogue processed, but the DW (and also my EX-8000) seems
to use harmonic waveforms/synthesis in order to generate waves/signals,
-not- 1:1 Samples from a wavetable. I -know- the differences between
VCO/DCO/ROMPler (i have here 15 Synthesizers which working with
different type of Oscillators incl. "Rompler" and a few analogue
Drummers incl. Korg Mp7 and a CR78).
I�ve also built a few little Synths by my own, they�re working at the
moment with Microcontrollers and the digital output is also being
processed by a DAC-0800 (there i -also- use wavetables inside the
program to create waveforms). They are all connected with -one- slightly
better Microcontroller for choosing different waveforms/frequency
settings,/keyboard decoding blahblahblah, but they are -for me- also
DCOs, because they are -controlled- by another Processor, even they�re
in fact "wavetable-Oscillators".
Greetings
Stef
Am Montag, den 13.02.2006, 18:02 +0000 schrieb Glen Stegner:
> come
> SPONSORED LINKS
> Synthesizer music
> Electronic music
> Music sampler
> Electronic musical
> instrument
> cases
> YAHOO! GROUPS LINKS
>      1.  Visit your group "DW8000" on the web.
>      2.  To unsubscribe from this group, send an email to:
>      3.  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>         Service.
2006-02-14 by Glen Stegner
Yes, I realize I simplified things by just calling them "sampled"
waveforms. You are right, the waveforms are built from the ground up (in
real time) using harmonic additive synthesis, however the basic
components of these waveforms (presumably sine waves) must themselves
have been sampled, just as they are in the DX7 and other FM synths.
> I know that they´ re not analogue, but the way how they build
their
> whatever). Harmonic Synthesis (as the DW6/8000 seems to use) isn´t
is
waves/signals,
> I´ve also built a few little Synths by my own, they´re working
at the
slightly
they´re
> Greetings
> Stef
> > come
output
> > SPONSORED LINKS
> > Synthesizer music
> > Electronic music
> > Music sampler
> > Electronic musical
> > instrument
> > cases
> > YAHOO! GROUPS LINKS
> > Service.
