Scanning b&w negs, revisited
2010-07-03 by Michael
I'm back to scanning for a 2nd round of learning and could use some additional perspectives. I'm scanning old 35mm Plus-X negs. and would like them to be as sharp as possible. The question I have is how do I best evaluate - on screen - scans of the same frame made at two different resolutions? While the answer seems to be to view them at "actual pixels" size, when doing a side by side comparison the larger (full optical rez) scan is more "zoomed in" in appearance than the smaller scan and is softer with more grain showing in the sky. My scene for this test is a winter landscape with fully overcast sky and leafless trees about 150+ feet in the distance. I'm looking at the smallest branches, trunk detail, and sky grain. My largest scan is at full optical resolution and the smaller is one step down. Does it make sense to look at these side by side at actual pixel size or should I go further and make prints of the same size? While making prints is a necessary final step, I'd like to first make the best onscreen, side by side evaluation that I can. Thoughts?
