European suppliers for monochrome inks and continuous flow systems for Epson printers
2010-10-05 by ekng532
I recall someone mentioning a supplier of monochrome inks from a
supplier in the EU (I think maybe Germany) on one of the lists I follow,
but now can't find the relevant post anywhere. Does anyone know an EU
supplier for either MIS or Piezography inks in an EU country please. (I
want to avoid hassles with import duties taxes and VAT collection, so US
is not an option).
mike
Re: [Digital BW] European suppliers for monochrome inks and continuous flow systems for Epson printers
2010-10-06 by Terry Ritz
I believe that Jon Cone has an EU based reseller. I suggest that you get in
touch with InkjetMall.
Terry.
> is not an option).
> Thanks,
> mike
2010-10-06 by Michael King
Mike,
In the UK the VAT/Duty process is pretty much hassle free.
Either you give the courier a cheque when they deliver the item or if you
use post the post office sends you a bill that you pay online and then they
deliver next day. Couldn't be easier. Mike
> is not an option).
> Thanks,
> mike
2010-10-06 by Ernst Dinkla
> is not an option).
> Thanks,
> mike
Image Specialists has an agent in The Netherlands. You probably can
create a set from the monochrome inks available in the other sets.
Either talk with them.
http://www.image-specialists.com/about_us_global_dis.aspx
Another option is to get HP Z3100-Z3200 monochrome carts in 130 ml size.
Paul describes a way to change the density somewhere on his pages, at
least there were messages here on the subject.
Met vriendelijke groeten,   Ernst
Try: http://tech.groups.yahoo.com/group/Wide_Inkjet_Printers/
|      Dinkla Grafische Techniek      |
|         www.pigment-print.com        |
|                 ( unvollendet )                 |
Re: [SPAM] Re: [Digital BW] European suppliers for monochrome inks and continuous flow systems for Epson printers
2010-10-06 by ekng532
maybe things have changed since I last ordered something from the USA,
which was some years ago, when I had to collect from the depot and pay
not only VAT and duties, but also a substantial handling charge.
On 06/10/2010 09:16, Michael King wrote:
> Mike,
Its got easier, but not cheaper :)
They still charge a handling charge.
But one in every three of four shipments slips through without charges and
that's offsets the handling charge :)
Mike
> > Mike,
> they
An addition: Image Specialists is the rumored source of MIS inks. Robert
Grafton of Gemini mentioned in the link above probably can help you with
MIS like quad sets.
The HP Vivera OEM inks are also available in 68 ml sizes and 130 ml twin
packs. So there is a choice considering price and volume.
|                 ( unvollendet )                 |
2010-10-06 by colingruk
A parcel I received in September from MIS had a ‘UK Border Agency’ receipt affixed which stated as follows:
“Goods purchase and imported into the EU with a value over £18 (for VAT purposes) and over £135 (for import duty purposes)… are subject to customs charges”  There are some exceptions such as tobacco products and alcohol.
I was told that if the value of less than £18 is observed not only is the consignment not liable to tax nor handling charges but it is less likely to be delayed in clearance.
Not using this system for buying inks I reckon I saved 50% as against buying from Tom van de Wakker at Refill Ink B.V.  I emailed him and told him so but had no response.
I reckon I would save even more by keeping the value of orders from MIS below£18/=.
Colin Conway
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, ekng532 <ekng532@...> wrote:
> > Mike,
2010-10-06 by Mark Tomlinson
I am in the UK , but still buy ink from the US. It still usually works
out cheaper than any EU source I have found (for me at any rate since
Mwords closed down). Bear in mind that postage is often added to the
'value' of imports so it is pretty easy to go over the £18.
I now just buy a large bottle of eboni black from MIS and mix my own
inks. It is not that difficult thanks to Paul Roark's sterling
generosity and openness. A large bottle will last an awfully long time
and save you a lot of money even after paying postage and import duty.
I think Lyson/Marrutt and Permajet sell monochrome ink in the UK, but I
have never tried them for ink although I do buy refillable carts from
Marrutt.
Best
Mark Tomlinson
On 06/10/2010 16:02, colingruk wrote:
> A parcel I received in September from MIS had a âEUR~UK Border
> AgencyâEUR^(TM) receipt affixed which stated as follows:
> âEURoeGoods purchase and imported into the EU with a value over £18
> (for VAT purposes) and over £135 (for import duty purposes)âEUR¦ are
> subject to customs chargesâEUR? There are some exceptions such as
> MIS below£18/=.
> Cheers,
> Colin Conway
> <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>, ekng532
> > > Mike,
> if you
> then they
2010-10-06 by robert fallis
> MIS below£18/=.
> The main problem with shopping from the states is the cost of postage,
> I used to buy ortho film from there. the postage doubled the cost of
> the film. $25 became $50, never had to pay any duty on it though, and
> when the $ to£ exchange rate was good then it was ok and worth while.
> but the dollar needs to drop a little more it's a bit too high at the
> moment
bob
2010-10-13 by santonov2you
You may be rejected it too soon. You could use HP inks together with MIS/Image Specialists Eboni for matte paper. HP ink will print on matte, but it will not give your DMax that Eboni will give. From the other side it is more neutral than Eboni. Search this forum for various combinations of HP/Eboni inks solutions with C6 base.
> Thanks Ernst, but I'd already rejected that as Paul recommends it only
> for glossy papers, which I hardly ever use!
2010-10-13 by Ernst Dinkla
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, ekng532<ekng532@...>  wrote:
Of the normal OEM pigment  inksets the HP Vivera MK scores the highest
Dmax on matte papers in (not only) my experience. At least with HP Z
models. It runs in my humble HP K5400 too with a homemade CIS. Printed
500 A4 sheets some days ago without a single hiccup.
|                 ( unvollendet )                 |
2010-10-14 by john
My HpZ3100 Mk Vivera reads an everyday 1.80 d-max on Photorag 308 for nearly 4 years now. I'd like to see Ebony or anything else equal that! Epson is 1.66, same with most of the others including Canon Lucia MK. And these inks have outstanding longevity. HP is kind of a strange giant corporation but I don't think they get enough credit for the really fine quality these inks can exhibit with black and white on matte rag media.
john
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla <edinkla@...> wrote:
> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, ekng532<ekng532@>  wrote:
> |                 ( unvollendet )                 |
2010-10-14 by santonov2you
Hmm, I was writing about combination Eboni with HP PK (which probably was the ink that Paul refered as glossy only). HP PK in my experience gives less DMax than Eboni on matte papers. I didn't mean to compare it to the HP MK -- I never used it.
--Sergei
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "john" <deanwork2003@...> wrote:
> john
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla <edinkla@> wrote:
> > |                 ( unvollendet )                 |
2010-10-14 by john
I see. PK should never be used on matte media it isn't designed for it. It has a great dmax on gloss media.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "santonov2you" <drumscanner@...> wrote:
> --Sergei
2010-10-17 by ekng532
However, that just brings this back to the starting point of this thread
... European Suppliers - if I had a European supplier for the MIS inks I
wouldn't have asked the question in the first place
2010-10-17 by Ernst Dinkla
Write Robert Grafton of Gemini and Refill inks a message and explain
that you want MIS Eboni etc. I'm sure he will tell you that Image
Specialists delivers the inks to MIS and to his shop.
This is the link on Image Specialists page:
Gemini Colours B.V.Western Europe
De Steeg 4-6
AP Schimmert 6333, The Netherlands
Tel: 0031-(0) 45-5419722
Fax: 0031-(0) 45-5431190
E-mails: gemini@...
Web links: www.gemini-colours.com
Contact: Robert Grafton
Products: Desktop and Wide Format Inkjet Inks
There's also a Slovakian and an Italian agent of Image Specialists products.
On the other hand it is clear that HP Vivera pigment inks include a
matte black + photo black + grey + light grey + a gloss enhancer that
could double act as a extender to dilute the grey inks if you do not
like Paul's dilutions. Forget the message you quoted above, it is based
on a misunderstanding.
|                 ( unvollendet )                 |
2010-10-17 by piezobw
If you would like a turn-key system, and we do not have a distributor in your Country, we will sell you a system with a discount that should be at least the equivalent of your VAT taxes. Right now the Euro is very strong compared to the dollar - and this should provide you with an excellent value in trying Piezography®.
You can contact me off line at jon (at) inkjetmall (dot) com
If we support your printer, you simply need to pull down a menu selection in QTR to one of our supplied curves to get a perfect result - without having to mix your own inks, etc...
Jon Cone
Piezography
